Old Jul 09, 2001, 03:17 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Build it exactly as Dave says and you won't be displeased. It's a phenomenal flier on just a 6v speed 400, leaves every other aerobatic multi-$$$ plane I have seen in the dust. Everybody I know around my field has built it stock, and it's a fantastic flier as is.
Check the DAW pages for some tips and his complete glue encyclopedia.
Occasionally the battery box will crack or split on a hard landing, but it is easily repaired. The LG bends occasionally but it's not a big deal either, I don't think you need titanium !
I would *strongly* recommend against folding your antenna. I had range problems on mine.
<img src="http://aeneas.ps.uci.edu/edf/extra/extra_300_1.jpg" width=500 height=345>
Herb is offline Find More Posts by Herb
Old Jul 09, 2001, 05:03 PM
KentM is offline
Find More Posts by KentM
KentM's Avatar
Dublin, CA USA
Joined Jul 2001
I don't see your antenna running out of the back, what did you do with it?
KentM is offline Find More Posts by KentM
Old Jul 09, 2001, 05:47 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Antenna wire is out at tail bottom and dangling as usual in the wind.
Old Jul 09, 2001, 06:03 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
I've also owned a couple of DAW Extras and consider them to be fine airplanes - ditto Herb's comments. I did however cut and fold my antenna on both aircraft, and never had a confirmed radio glitch. But - if I built a third one, I'd probably use a Dean's base loaded, or a music wire antenna.
Pete
SchiessCo is offline Find More Posts by SchiessCo
Old Jul 10, 2001, 12:17 AM
KentM is offline
KentM's Avatar
Dublin, CA USA
Joined Jul 2001
Dave's Aircraft Works Extra 300s or Staudacher Review?
I have just purchased the Extra 300s from DAW and I was hoping to contact someone who has built one. Any tips or tricks would be helpful. Also, I would like to know the flight characteristics of the aircraft. Thanks!
Old Jul 10, 2001, 01:52 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Some friends of mine folded the rec antenna inside the fuse and had no problems yet. I had range problems on my Hitec 555 receiver -so I preferred to go the safe route...
Old Jul 10, 2001, 02:48 PM
KentM is offline
KentM's Avatar
Dublin, CA USA
Joined Jul 2001
Thank you all for your input. I will definitely go with a base loaded antenna and the other suggestions that were made!
Thanks!!!
Old Jul 11, 2001, 12:18 AM
Bob K is offline
Find More Posts by Bob K
San Diego
Joined Jan 2001
Use larger control horns than Dave recommends and you will be a lot happier. The plane will fly sooo much smoother. His stated CG location is spot on! Also, a little bit of spackle and sanding before you cover makes a world of difference in the appearence and adds no measurable weight. Use a base loaded antenna. I had problems with a folded up antenna and a Hitech555, it got glitchy at distance. You are gonna love this plane.
Bob K is offline Find More Posts by Bob K
Old Jul 16, 2001, 12:52 AM
KentM is offline
KentM's Avatar
Dublin, CA USA
Joined Jul 2001
Herb,
FMA makes an 8 channel receiver that is almost identical in size and weight as the Hitec 555. I could then set up flaperons. Do you think that this would be beneficial?
Old Oct 15, 2009, 06:37 AM
RCWorks is offline
Find More Posts by RCWorks
Annuit cúptis
RCWorks's Avatar
Joined Aug 2003
I had one, missed it so much I made an updated vesion.
Balanced for a 3S 2100 pack. Same wing, just a few changes to the fuse and tail feathers. I wish I knew where he got the landing gear.
RCWorks is offline Find More Posts by RCWorks
Extra 300s (By Dave's Aircraft Works) Kilowatts Aircraft - Electric - Airplanes (FS/W) 8 Aug 29, 2003 07:44 AM
Extra 300S (By: Dave's Aircraft Works) cwany Aircraft - Electric - Airplanes (FS/W) 3 Aug 22, 2003 10:08 PM
FS: DAW (Dave's Aircraft Works) Extra 300 DaJudge Aircraft - Electric - Airplanes (FS/W) 6 Sep 17, 2002 01:22 AM
FS: Dave's Aircraft Works Extra 300S RTF rjoubenjr Aircraft - Fuel - Airplanes (FS/W) 4 Aug 14, 2002 10:37 AM
FS: Dave's Aircraft Works Extra 300S RTF rjoubenjr Aircraft - Electric - Airplanes (FS/W) 0 Aug 08, 2002 09:57 AM
