Old May 01, 2008, 12:58 PM
DerKorb is offline
Find More Posts by DerKorb
Joined May 2008
Image problem - diagonal lines
I have a problem with my video stream. There is a pattern of diagonal lines over the whole image. I made two screenshots of it:
I'm not sure but i think the direction of the lines varies so I guess its not a fixed frequency.
Has anyone experienced such noise? Those lines can be realy anoying when they get stronger and i would be very happy fixing this.
I am using a TX40 from rc-tech.ch on a seperate 7.4V Lipo. I put two chokes in series with the cam and two capacitors parallel to the chokes to filter out noise.
DerKorb is offline Find More Posts by DerKorb
Old May 01, 2008, 01:24 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
And what happens if you kill the motor?
ian
Daemon is offline Find More Posts by Daemon
Old May 01, 2008, 01:25 PM
MrGlobeFlight is offline
Find More Posts by MrGlobeFlight
FirstPersonFlyer
MrGlobeFlight's Avatar
Bavaria/Germany
Joined Mar 2008
Hi,
looks bad, are you using 2,4GHz RC-equipment ?
Sebastian
MrGlobeFlight is offline Find More Posts by MrGlobeFlight
Old May 01, 2008, 01:29 PM
JMSTECH is offline
Find More Posts by JMSTECH
JMSTECH's Avatar
Canada, BC, Duncan
Joined Dec 2006
Yes.. like Ian said... what happens when you kill the motor? Geshhh I wish Kilrah would get his tooty back from military duties... he could also help you out in a flash!
JMSTECH is offline Find More Posts by JMSTECH
Old May 01, 2008, 02:00 PM
oxxyfx is offline
Find More Posts by oxxyfx
oxxyfx's Avatar
Joined Jan 2007
This is typical switching power regulator noice. What value are the chokes and the capacitors? Also it would be helpful if you would shoot a picture of the setup - so we can see how the chokes and caps are installed.
oxxyfx is offline Find More Posts by oxxyfx
Daniel Wee is offline
Find More Posts by Daniel Wee
Joined Aug 2005
Could be the switching power supply if you're using one. It may not be filtered well enough for the camera or the video TX. Alternatively, it could be the camera shielding isn't good enough. See if the problem goes away if you adjust your grounding for the TX and the camera. Lastly, it could be coming on your receiver side as well so you may want to check that.
Daniel
Daniel Wee is offline Find More Posts by Daniel Wee
Old May 01, 2008, 03:41 PM
DerKorb is offline
Joined May 2008
This was my setup:
I tried to remove the chokes and capacitors from the setup and the problem is gone now.
Thx for all the replies.
Image problem John Zook Life, The Universe, and Politics 3 Jul 30, 2002 10:42 AM
