Old Jan 15, 2003, 10:42 AM
Jim Young is offline
Find More Posts by Jim Young
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
DH-88 Comet Plans
Inspired by the EAM ARF DH-88 Comet, I thought some of you builders out there might be interested in a built up Comet. I talked with Keith Shaw at the November EFO meeting and got some input from him and have been playing around with this design.
Here's the specs:
Wing Span : 50"
Length: 36"
Wing Area: 300 squares
Airfoil: Clark-Y
Power: 2 x SP400 on 8 cells (800mAhr or CP1300)
I drew it from a set of 3-views and enlarged the wing tip to 150% of the scale size. It will have ~3 degrees of washout to tame tip stalls. Construction is basic 1/16" balsa and some ply. The wing will be fully sheeted with 1/8" spar/sheer web.
-Jim Young
Jim Young is offline Find More Posts by Jim Young
Old Jan 15, 2003, 10:47 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Fuse plans....
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Wing plan...
Old Jan 15, 2003, 11:57 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Very nice Jim! The microsport was my first rc plane, what a handful ...
Herb is offline Find More Posts by Herb
Old Jan 17, 2003, 08:49 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Herb,
Do you still have your Microsport? I went through 3 of them before I figured out that I had a cracked cap in my receiver. I'd get half way into a flight and then no control, snap, spin, crash. The post mortum would alway show no problem with the radio. Once I figured out the radio, it was a real blast. It's definitely not a beginners plane, and neither will this Comet. See the "Lunch with Keith" column this month.
-Jim
Old Jan 18, 2003, 12:59 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Jim, No I don't have the Microsport any more , can you imagine what it was like as the first rc plane ever (never flown rc gas in my life)? Too bad I did not take a picture of mine... But I did get it to fly and I learned a few lessons from it, the first one was that I should learn to fly first on a $20 foam slope plane...
Believe it or not I have been toying with the idea of building another one... Here's the link by the way for others to look at Jim's Microsport:
http://members.aol.com/KMyersEFO/microspt.htm
Old Nov 06, 2003, 11:32 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Laser cut parts
Hi,
Well the Comet went through a lot of revisions on paper this Summer. Many thanks to Keith Shaw for his input. The results I think will build into a light, nice flying model. I have had several "short kits" laser cut and I am in the middle of building the prototype. The prototype hasn't flown yet, but I thought I'd start posting some construction pictures.
Here are the laser cut parts. Basically you get the wing ribs, spars, fuse formers, and tail feathers. This takes care of most of the tough stuff.
-Jim
Old Nov 06, 2003, 11:41 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Wing Construction
The wing is fully sheeted and uses an 1/8" full depth balsa spar. All ribs are 1/16" balsa and there is an 1/8" sq. balsa rear spar.
I'm using an aluminum tube with music wire epoxied into the ends for aileron torque rods. With this set up I can use one servo and keep the control hookup simple. The holes for the tubes were laser cut into the ribs and it just slid in with no trimming necessary!
Here is the wing before the top sheeting is applied:
-Jim
Old Nov 06, 2003, 01:32 PM
hemna is offline
Find More Posts by hemna
php web app engineer
hemna's Avatar
Cool, CA
Joined Feb 2003
nice looking kit. A friend of mine and I were going to build a couple DH-88's over the winter. really kewl planes. I love planes of that era.
hemna is offline Find More Posts by hemna
Old Nov 07, 2003, 11:19 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
More Wing pictures
Here, one half is done and the second half is being built on to the first. Two 1/64" ply joiners connect the two halfs.
-Jim
Old Nov 07, 2003, 11:22 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Tail feathers
The tail is pretty simple, just 1/8" sheet.
Old Nov 08, 2003, 01:06 PM
Gravitysux is offline
Find More Posts by Gravitysux
What was that???
Gravitysux's Avatar
Colorado
Joined Oct 2002
Hi Jim!
So is this something you intend to offer as a kit? I'd be interested if you are!
Ray
Gravitysux is offline Find More Posts by Gravitysux
Old Nov 10, 2003, 02:42 PM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
kit
Hi Ray,
I hope to offer a short kit in the future. I've been keeping this one close to my vest because it hasn't flown yet. Once I get the prototype flying, I'm looking at a construction article and some kits.
-Jim
More pictures...
Old Nov 20, 2003, 11:14 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
More pictures...
Here the fuse is basically done and the tail and turtle deck sheeting are in place.
-Jim
Old Nov 20, 2003, 01:03 PM
What was that???
Gravitysux's Avatar
Colorado
Joined Oct 2002
Looking good Jim!
Go ahead, try my patience! Actually I have enough projects for now but that won't last!
Ray
DH 88 Comet warbird Scale Kit/Scratch Built 13 Nov 30, 2010 07:40 AM
EAM DeHavilland DH-88 Comet ARF dave_lilley Sport Planes 4 Nov 08, 2009 04:35 PM
DH-88 Comet EAMRC Scale Kit/Scratch Built 38 Jul 11, 2004 03:13 PM
FS: EAM DH-88 Comet Slope Nut Aircraft - Electric - Airplanes (FS/W) 3 Dec 09, 2002 10:48 PM
Has anyone done a DH-88 comet parkflyer? DesignGeek Parkflyers 5 Oct 14, 2002 06:31 AM
