Old Oct 29, 2011, 03:35 PM
TBolt is offline
Find More Posts by TBolt
TBolt's Avatar
United States, AZ, Chandler
Joined May 2004
Thanks Jeremy.
TBolt is offline Find More Posts by TBolt
Old Oct 30, 2011, 12:21 AM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
OK. Do they sell a 4 to 1 servo connector?
I think my harness for my stuka flaps is bad. Not even sure what you would call it. 4 servos to one channel.
I need a resource.
neck is offline Find More Posts by neck
Old Oct 30, 2011, 02:11 AM
Quiet E. Flyer is offline
Find More Posts by Quiet E. Flyer
"Thumbs"
Quiet E. Flyer's Avatar
Gilbert, Arizona
Joined Jan 2007
I need a resource.
Alternative...3 double Y connectors. 1 for each pair and then another 1 to connect them together!
You are welcome.
Quiet E. Flyer is offline Find More Posts by Quiet E. Flyer
Old Oct 30, 2011, 04:14 AM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
You are welcome.
Great can't seem to find them online anywhere.
My F-86 is missing the plywood mounts for the wing also.
Old Oct 30, 2011, 01:50 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I can make one out of servo extensions.
You owe, you owe, so off to work you go...
rampman is offline Find More Posts by rampman
Old Oct 30, 2011, 05:54 PM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Well I figured it out. I purchased Hyperion extensions and apparently they aren't working with my quad connector. I thought it was unlikely to have 4 bad servos or extensions so I assumed it was the 4 to 1 connector. It looks like one of the pins in all 4 of the female ends of the extensions is bent. Opps. Not impressed with the Hyperion extensions.
Ricky D how much do I owe you for the new o rings?
Old Oct 30, 2011, 06:57 PM
TBolt is offline
TBolt's Avatar
Joined May 2004
That is odd, I use Hyperion extensions, and have never run across such a problem. What servos were you using?
Old Oct 30, 2011, 08:58 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Jeremy, you already paid me at the filed on Saturday
Old Oct 31, 2011, 12:38 PM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
HTX900's
Looking at them a bit more it looks like all the pins are sitting in there a little skewed. Maybe the cheapo servos don't have the proper angle to allow them to easily side in. Cheap to cheap in the future I guess.
Old Oct 31, 2011, 12:39 PM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
What the punch in the arm?
Oh and thanks for the controller. Works great. The bad channel is pretty odd. Really dim.
Old Oct 31, 2011, 02:11 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Acutally, the $20 I pulled out of your wallett when you were punching me in my arm.
IMO, all servo leads are a standard pitch. I don't know what you got but something went wrong somewhere. Are you sure someone did not plug them into a plug and pulled out sideways OR, more likely, have you ever crashed a plane? If so maybe these servos were pulled from the RX at an angle upon impact? LOL
Rick
Old Oct 31, 2011, 03:18 PM
TBolt is offline
TBolt's Avatar
Joined May 2004
Rick
That would be my guess also, I have used HXT900's with the Hyperion extensions with no problem. If you ask me you get a very good extension at a good price compared to the other leading brands. (Victor is not compensated in any way for his product endorsement)
Old Oct 31, 2011, 03:38 PM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Rick
Crashed me?? No way. It's really odd. The same pin on all the extensions are smashed or bent off to the side. 1 of them pushed thru the connector.
Old Nov 02, 2011, 03:23 PM
greenseaships is offline
Find More Posts by greenseaships
Registered Airplane Offender
greenseaships's Avatar
Scottsdale, Arizona
Joined Jun 2006
Has everyone seen the new darling of Airliners.net?
PLL LOT Boeing 767 lands safely despite landing gear failure (0 min 54 sec)
This is the signature Barrett Hochhaus 767. It takes 85 people to hand launch it. -_-
greenseaships is offline Find More Posts by greenseaships
Old Nov 02, 2011, 09:08 PM
TBolt is offline
TBolt's Avatar
Joined May 2004
I saw the stills, but man they really greased that landing, it was a thing of beauty.
