Old Jul 25, 2011, 08:14 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Thrust angle would be my guess as well.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jul 25, 2011, 09:01 PM
Vlodek9 is offline
Find More Posts by Vlodek9
Vlodek9's Avatar
United States, AZ, Chandler
Joined Sep 2010
Ahh yes… the old thrust angle in the shoe trick. Researched a bit about it and I guess there are tests I can do to see if it is off. If it is, I guess the way to fix it is by putting a washer or two between the top engine screws and the firewall? This way I can drop the engine a bit right??
Vlodek9 is offline Find More Posts by Vlodek9
Old Jul 25, 2011, 09:08 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yes, that's what you want to do.
Pat
Old Jul 25, 2011, 10:10 PM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
I think you want to drop it down and to the right....at least that's what someone told me about the P-38. But maybe that's something to do with multi engine planes??
neck is offline Find More Posts by neck
Old Jul 25, 2011, 10:20 PM
Vlodek9 is offline
Vlodek9's Avatar
Joined Sep 2010
From what I read that is the standard trust angle down and to the right. In my case it is not pulling to the right or left just up, so I’m thinking just down. But next time I fly it I will do some tests that I read about on the net regarding this issue and we will see.
Thanks everyone for your help.
Rob
Old Jul 25, 2011, 11:18 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
More down, no right and maybe nose heavy too.
IMO, do NOT mix down elevator to throttle as some may suggest. Think about it. Coming in for a landing at 10 over stall speed. Coming up a bit short or going long and only 5' off the runway so you throttle up as it goes INTO the runway.
Rick (i don't like mixes)
rampman is online now Find More Posts by rampman
Old Jul 26, 2011, 09:33 AM
Vlodek9 is offline
Vlodek9's Avatar
Joined Sep 2010
One thing I don’t understand about this. Other then the battery and prop, I didn’t change anything. The prop size is still in the manufacturer’s recommendation even for a 3s. And since this is an ARF the firewall is already adjusted for the correct thrust angle. So why would the trust angle have to be changed/adjusted for a 4s battery?
Maybe it is just nose heavy, but then why don’t I see or feel it at cruise speed when I trim it?
Guess I’ll find out this Sunday if the weather permits it.
P.S.
Why do we say its nose heavy if the nose goes up? I read and understand the physics behind it so I’m not actually asking. Just making a point that it sounds backwards.
Old Jul 26, 2011, 09:41 AM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Because you are blowing a LOT more air OVER the top of the wing which generates a lot more lift.
If it is nose heavy you have up elevator dialed in to maintain level flight. Increase RPM and more air goes over the elevator which is already up some so that makes it climb more at WOT...
Rick (NOT an engineer so take this with a grain of salt)
Last edited by rampman; Jul 26, 2011 at 11:14 AM. Reason: Changed to ---> so after name
Old Jul 26, 2011, 10:16 AM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Rob,
Other Rick is absolutely correct. As your prop spins faster due to the higher cell count the airflow over your wing also increases(relative wind). This creates more lift and your airplane goes up. Now if your airplane isn't just climbing, but also pitching up then you may also have a thrust angle problem.
Other Rick
Aeronautical Engineering Degree
United States Air Force Academy
swarick is offline Find More Posts by swarick
Old Jul 26, 2011, 11:11 AM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
You guys are the best bunch of non engineers I've ever met. One of you needs to write a RC book for dummies. Even I understand the content.
Non engineer.
Horrible pilot.
The one the only JEREMY
Old Jul 26, 2011, 06:35 PM
TBolt is offline
Find More Posts by TBolt
TBolt's Avatar
Joined May 2004
I agree with Rick agreeing with the other Rick, who is not always very agreable.
TBolt is offline Find More Posts by TBolt
Old Jul 26, 2011, 07:25 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
OK Mr. Smarty Pants... answer me this one: If I have a plane on a giant treadmill.......
Or how about this.... is a 50CC Composite ARF louder at 6:00AM than at 10:00 AM?? I think noise travels better in the thin air!?!
chalmrast is offline Find More Posts by chalmrast
Old Jul 26, 2011, 09:00 PM
swarick is offline
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Actually noise travels better in thick air. That's why no one can hear you scream in the vacuum of space.
Other Rick
Old Jul 26, 2011, 09:02 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
He wouldn't know that one, he wasn't there!
Pat
Old Jul 26, 2011, 09:04 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Other Rick
And it travels even better under water!
