Old Jul 18, 2011, 06:08 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
What props did you run? These should be able to throw a 10" prop pretty easily, maybe an 11 incher; pending pitch.
I noticed they do not list a prop suggestion on that link. You answered your question though, get out the watt meter OR do a google search to see if someone already went through what you are going through and posted the results for everyone to see.
Dis
rampman is offline Find More Posts by rampman
Old Jul 18, 2011, 06:40 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yeah, he had GWS 3-bladers on there. While they are nice looking props, they are notoriously underpitched for most applications.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jul 18, 2011, 07:24 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
The motors sold at RCHotdeals used to be the basic suppo motors, also sold by LightflightRC, which has actual prop test data on their website. The motors now being sold by RCHotdeals have the same nomenclature, but look noticeably different. I've got a few of the newer 2208 sized motors, and while they pull "roughly" the same numbers as the old suppo's, I don't know if the maximums are the same.
I've been threatening to do a bunch of prop tests on the motors to figure efficiency #s, but found that they use a 10mm bearing tube, and everything I had set-up was for 8mm tubes.
carlsoti is offline Find More Posts by carlsoti
Old Jul 19, 2011, 01:18 AM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Barrett, I have a BUNCH of GWS 4 blade props, all sizes.
Rick
Old Jul 19, 2011, 12:16 PM
greenseaships is offline
Find More Posts by greenseaships
Registered Airplane Offender
greenseaships's Avatar
Scottsdale, Arizona
Joined Jun 2006
Rick
Thanks, Rick, but the Lanc had 3-bladed props and if anything, I would go 2-bladed props for the flight, then put 3 bladed GWS props on for display.
That said, it's a matter of finding the right 2-bladed props, but I'm still gonna start with the PZ 109 props, which are a full 1.5 inches greater in diameter AND still nice and stiff.
greenseaships is offline Find More Posts by greenseaships
Old Jul 19, 2011, 12:23 PM
Scott Todd is offline
Find More Posts by Scott Todd
TAFTS
Chandler, AZ
Joined Apr 2008
I think it has the potential to fly really well for a scale airplane. Just a few suggestions if you are going to fly it again....
Add a little more fin area. If you just traced it 3/4 of an inch bigger transitioning to maybe an inch taller, it would help.
Put the other rudder on.
Put the tail wheel on a separate channel so you can can 'lock' it or reduce the throw significantly for takeoff. Your TX can handle this with one mix assigned to a switch.
Secure the battery. Even a small strip of velcro glued to the floor to keep it from sliding or accidentally jumping the curb.
Check the thrust lines and incidences. It needed a LOT of rudder to keep it flying straight.
Let me know if you want help with anything. I can make myself available just about anytime for you.
Oh, BTW, reduce the Shuttle aileron to about 60%. You can use the D/R function.
Call anytime if you have questions. I really only look at this forum once every few months.
Scott
Scott Todd is offline Find More Posts by Scott Todd
Old Jul 19, 2011, 01:59 PM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
"......a full 1.5 inches greater in diameter AND still nice and stiff. ....."
Hey watch it there are kids on this FORUM.
Other Rick
swarick is offline Find More Posts by swarick
Old Jul 20, 2011, 10:11 AM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Opps
neck is offline Find More Posts by neck
Old Jul 23, 2011, 10:46 PM
brad hartman is offline
Find More Posts by brad hartman
If you fail once try harder
brad hartman's Avatar
USA, AZ, Queen Creek
Joined May 2010
Is there anything in the AMA rule book about flying under the influence of pain relievers for facial injuies?
brad hartman is offline Find More Posts by brad hartman
Old Jul 23, 2011, 11:40 PM
carlsoti is offline
carlsoti's Avatar
Joined Jun 2008
If you have to ask, it's probably not a good idea.
Old Jul 25, 2011, 01:48 AM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Brad, you look'in like a chipmonk still?
Old Jul 25, 2011, 06:45 PM
Gringostr is offline
Find More Posts by Gringostr
Trolls more than he flys.
Gringostr's Avatar
Joined Sep 2009
What'd you do? Crash into your face?
Gringostr is offline Find More Posts by Gringostr
Old Jul 25, 2011, 08:41 PM
Joined May 2010
Just alittle not as much as the day after.
No I had all 4 wisdom teeth pulled
Old Jul 25, 2011, 08:55 PM
Vlodek9 is offline
Find More Posts by Vlodek9
Vlodek9's Avatar
Joined Sep 2010
Hi all
Have a question. I have the Hyperion Stuka that I “upgraded” from a 3s 4000to a 4s 5000. Also replaced the prop to a smaller size. I did this to make it faster and it is. But since I did this, I’m having a bit of a problem keeping it level at high speed. At about 50% throttle (my cruise speed) I trim it and it flies straight and true. But as I increase throttle to 70-80%, nose goes up and it climbs quickly to the point I have to giving it almost 50% elevator down and keep it there to straighten it out. So, is that just a cause of too much power, bad trim, or is my CG off and the tail is to heavy??
I thought it was wind at first but I have the same issue upwind and down wind.
Vlodek9 is offline Find More Posts by Vlodek9
Old Jul 25, 2011, 09:10 PM
Joined May 2010
Maybe the thrust angle is to far up.
