Old Apr 30, 2008, 01:40 AM
stefalo is offline
Find More Posts by stefalo
Joined Sep 2006
Wing attachment methods
Hey Groupers,
I need a little advice. I have been building small 30" sal gliders and am now wanting to try a bit larger plane. My previous method for attaching the wing was just to epoxy the carbon boom directly to the wing and then tape over the joint for good measure. This worked fine on small 3oz planes but I have had minimal luck making this work on larger planes. I am using a fiberglass pod epoxied to carbon rod so no real attachment point has me pulling what little is left of my hair out. Any methods or advice would be great.
Thank you in advance!
Stefan
stefalo is offline Find More Posts by stefalo
Old Apr 30, 2008, 08:41 AM
sporter is offline
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
About halfway down the page are some wing attchment pics for the SGII. I like this the best, it just looks super-clean. And the strength is amazing!
http://www.charlesriverrc.org/articl...SuperGeeII.htm
Others can chime in with more methods.
Sean
sporter is offline Find More Posts by sporter
Old Apr 30, 2008, 10:44 AM
stefalo is offline
Joined Sep 2006
That does look like a clean mount setup. Do you know if the tubes coming from the boom are epoxy filled and then tapped? Also do you happen to know what the pylon block is made of? Thank you Sean. I will read some of the build guides for this plane and see what I can do.
Stefan
Old May 02, 2008, 12:22 PM
kmj73us is offline
Find More Posts by kmj73us
SPOOOOOOON!
kmj73us's Avatar
Joined Oct 2006
This is the best description of SG2 wing mount process I've found so far...
http://www.rcgroups.com/forums/showp...1&postcount=23
kj
kmj73us is offline Find More Posts by kmj73us
Switchback Wing attachment? dpoles Parkflyers 2 Dec 05, 2002 07:38 AM
SB wing attachment uncled Parkflyers 12 Nov 29, 2002 12:20 PM
Miniflash wing attachment question ronrandle Parkflyers 4 Nov 04, 2002 07:22 PM
Wing attachment to 400 pylon Pritos High Performance 2 Aug 12, 2002 07:09 PM
Detachable Wing Joining Methods? martin johnson Electric Sailplanes 1 Jul 14, 2001 07:30 AM
