Old Nov 24, 2010, 05:57 PM
vienquach is online now
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Originally Posted by Dan Wait Jr. View Post
I run 7 volts!
to 85 MGs ?
vienquach is online now Find More Posts by vienquach
Old Nov 24, 2010, 05:59 PM
Dan Wait Jr. is offline
Find More Posts by Dan Wait Jr.
Anderson River Park Flyers
Dan Wait Jr.'s Avatar
Anderson, CA
Joined Jan 2010
Oh yeah!
Dan Wait Jr. is offline Find More Posts by Dan Wait Jr.
Old Nov 24, 2010, 06:18 PM
garrcass is offline
Find More Posts by garrcass
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
Originally Posted by vienquach View Post
to 85 MGs ?
he does ! but my 5085's are still faster on 6v and thats a regulated 7 volts there is a lot of guys plugging Hitec servos into a unregulated 2 cell lipo the owner of our local hobby shop does it on his turbine jet and other large planes right Dan
garrcass is offline Find More Posts by garrcass
Old Nov 24, 2010, 06:27 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
You sure those aren't something like the 7950TH or some other hv servos?
Safety Hawk is offline Find More Posts by Safety Hawk
Old Nov 24, 2010, 06:37 PM
Anderson, CA
Joined Jan 2010
Yup. That's what he does... Sounds crazy, huh? But it works.
Old Nov 24, 2010, 06:48 PM
garrcass is offline
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
if he had those he would probably use a 3s lipo
Old Nov 24, 2010, 06:55 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
It might work, but for how long ... before the servos burned up under high load. Just curious.
Old Nov 26, 2010, 09:34 AM
Kurtzz is offline
Find More Posts by Kurtzz
Pounding the Kool-Aid
Kurtzz's Avatar
First Hill of the Ozarks
Joined Dec 2008
DX 7 Programming
Just came over to the AJ Slick world from the Align TREX heli side of things and I am having bad times trying to program the ailerons on my DX7 and JR 921 receiver. Heck after reading the manual i'm so lost i'm not even sure which port to plug the ailerons in....I figure one goes in the AILE slot but not sure where the other one go. Transmitter settings/programming that work would be real helpful at this stage of the build.
Thanks in advance
Kurtzz
Kurtzz is offline Find More Posts by Kurtzz
Old Nov 26, 2010, 09:41 AM
grubby is offline
Find More Posts by grubby
grubby's Avatar
Denver Colorado
Joined Jan 2010
Thanks in advance
Kurtzz
If the reciever has an AUX port plug it into that and you have to do flap mixing. There is a video how to do and I believe Horizon Hobby has a check sheet on how to do it but I cant seem to find it.
You can also just use a Y harness on the ailerons as well.
grubby is offline Find More Posts by grubby
Old Nov 26, 2010, 09:45 AM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
As often, I try not to go with the y harness way. Had to do this on my old Futaba 6EX.
Using AUX port as mentioned above gives me the ability to adjust subtrim on the ailerons.
Vien
Old Nov 26, 2010, 09:46 AM
grubby is offline
grubby's Avatar
Denver Colorado
Joined Jan 2010
Found the horizon write up sheets.
http://www.horizonhobby.com/Articles...ArticleID=1798
I used this on my planes and it works fine.
Old Nov 26, 2010, 09:53 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Thanks in advance
Kurtzz
Set the wing settings to flapperons. Plug right aileron into the aileron slot and the left in ax 1. You may have to reverse one or both to get the throw direction right. I go into the flap settings and set the flaps to zero as the default is 100%....would not be good if you accidentally hit the flap switch.
GoldCraft is offline Find More Posts by GoldCraft
Old Nov 26, 2010, 10:06 AM
Kurtzz is offline
Kurtzz's Avatar
Joined Dec 2008
Dang that was easy TY!
Old Nov 26, 2010, 12:41 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
New ADC Vinyl design for the Red 51" Slick
Also, all 3DHS ARF VINYL GRAPHICS PACKAGES are on SALE - HERE
20% OFF regular pricing.
Rob
Fliprob17 is offline Find More Posts by Fliprob17
Old Nov 26, 2010, 03:05 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Rob that looks great!!! I really like it
losifanatic is offline Find More Posts by losifanatic
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
