Old Sep 10, 2009, 06:47 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Hi Guys,
Got my 51" AJ Slick!
I would like to use a scorpion motor with 4s 2700 30C+ lipos
would you suggest the 166g SII 3020-780KV or the 205g SII 3026 710KV?
http://www.scorpionsystem.com/catalo...II-3020-780KV/
http://www.scorpionsystem.com/catalo...II-3026-710KV/
cheers
Alex
like2fly! is offline Find More Posts by like2fly!
Old Sep 10, 2009, 07:23 AM
jfv61 is offline
Find More Posts by jfv61
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
Originally Posted by curtqn
Building a new Slick. I put the wings in and slide the elevator stabilizer in. Looking from the back of the plane the elevator stabilizer is not straight to the wings. it seems to lower to the left compare to the wings. Should I sand the opening to fix it or just leave it the way it is?
Minor mis-alignment is no problem but it's easy to fix. Often all it takes is a little bit of card stock wedged in on the low side. Kevin covers this in his build videos I believe.
jfv61 is offline Find More Posts by jfv61
Old Sep 10, 2009, 08:46 AM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
Originally Posted by like2fly!
Hi Guys,
cheers
Alex
using 30C 2700 packs, I might lean towards the lower kv version so that you have the option to run some larger props., but it's a bit heavy at 7.18oz, when most of the recommended motors are in the 6.3oz +/- range
the higher kv version is a bit light at 5.81 oz., but with 2700 packs you should be able to CG without any issues, and you will be leaning towards an overall lighter "feeling" setup.
My 2 cents would be the 780kv version, plan on running a 13x6.5E or 14x6E max.
Fliprob17 is offline Find More Posts by Fliprob17
Old Sep 10, 2009, 08:53 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Hi Guys,
cheers
Alex
i flew a 3026 on mine worked great.mucho power
Manta1 is offline Find More Posts by Manta1
Old Sep 10, 2009, 10:11 AM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I sand both sides until I am able to align the horizontal stab to the wings. I usually don't shim it, I just use thin CA to lock it in place and medium or thick CA to fill in the gap.
Daloaf is offline Find More Posts by Daloaf
Old Sep 10, 2009, 10:26 AM
curtqn is offline
Find More Posts by curtqn
United States, CA, Santa Ana
Joined Jan 2003
What video he coves it?
curtqn is offline Find More Posts by curtqn
Old Sep 10, 2009, 05:16 PM
jfv61 is offline
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
I know I've seen it in at least one of the videos, maybe not the Slick 51"? You can create small shim with a little card stock to get it level and then CA it in place. I always use a little medium or thick to fill in any gaps (whether I shimmed or not).
Old Sep 10, 2009, 09:52 PM
fall666 is offline
Find More Posts by fall666
To me, every day is Saturday
fall666's Avatar
DAL/FTW
Joined Jul 2006
Just got this from RCUnivers about my Slick
Photo of it is on their home page.
gb
fall666 is offline Find More Posts by fall666
Old Sep 10, 2009, 11:28 PM
FlyingDreams is offline
Find More Posts by FlyingDreams
FlyingDreams's Avatar
Acton, MA
Joined Sep 2008
Inexpensive motor recommendation:
My Torque 2812/720 developed some problems, so while I look at fixing it I had to replace it. The Torque has plenty of power for me, and I'm saving the GR45 for the 57" Extra 330, so I used this motor http://www.milehighrc.com/brushless4250-7.html. It is a low cost replacement for the torque. It weighs only about 1/2 oz more than the torque (including prop adapter, washer, and nut). With a Xoar 14x7 and Flightmax 4S, 3000 (20c) , I was getting about 750 watts with about 48amps. The pack I was using already had a few minutes of usage on it. 750 watts was what I was getting with the Torque and APCE 14x7.
I flew 8 packs with this setup, and I couldn't tell the difference between this motor and the torque. I did have to drill new mounting holes, because the motor is bigger in diameter then the torque, so the old holes were being blocked just enough to where I couldn't use the old X mount. It also comes with an 8mm bolt-on prop adapter, so I had to drill out the props. (I believe the GR45 has 8mm prop adapter, so now I can share the same 14x7 props between the Slick and the 57" Extra.) The new X mount/motor/adapater combination was a few millimeters longer than the Torque combination.
John
FlyingDreams is offline Find More Posts by FlyingDreams
Old Sep 11, 2009, 08:28 AM
birdie_in_texas is offline
Find More Posts by birdie_in_texas
Pro Bro #1008
birdie_in_texas's Avatar
USA, TX, Weatherford
Joined Sep 2003
I may actually keep the gr-45 in the box and go with my A30-12XL first..I have not decided..after reading everything Doc has posted about an easier time not having to wrestle with the throttle, that might be just the thing for me..
birdie_in_texas is offline Find More Posts by birdie_in_texas
Old Sep 11, 2009, 08:41 AM
davidsons is offline
Find More Posts by davidsons
davidsons's Avatar
Joined Feb 2004
A30-12XL is awesome. What esc are you going to use?
davidsons is offline Find More Posts by davidsons
Old Sep 11, 2009, 08:43 AM
jfv61 is offline
Go guerrilla
jfv61's Avatar
Austin, TX
Joined Jul 2005
Good question on ESC. I've been able to overheat the Hacker X-55 pretty easy in the 100 Texas heat depending on prop with the 12XL. I prefer the X-70 (Airboss 60 has been good in my Yellow Slick also).
Old Sep 11, 2009, 08:45 AM
davidsons's Avatar
Joined Feb 2004
I'm using a CC PHX 80 on mine....no probs. Pretty sure this setup is pulling 55-60 amps.
Old Sep 11, 2009, 09:40 AM
Pro Bro #1008
Joined Sep 2003
I got me a ICE 50, or Ice 75 to use..
Old Sep 11, 2009, 09:59 AM
davidsons's Avatar
Joined Feb 2004
Use the 75 unless you plan to prop down.
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
