Old Aug 25, 2009, 03:21 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Are those stick on LED's easy to take off and re-apply when you want them on?
G.P. is offline Find More Posts by G.P.
davidsons is offline
Find More Posts by davidsons
davidsons's Avatar
Joined Feb 2004
Originally Posted by blucor basher
That is the sweetness.
Thanks Ben
davidsons is offline Find More Posts by davidsons
Old Aug 25, 2009, 03:22 PM
RedTalon is offline
Find More Posts by RedTalon
The RED filters through
RedTalon's Avatar
Rendon, TX
Joined Feb 2007
Any problems with those white lights screwing up your "night vision"?
RedTalon is offline Find More Posts by RedTalon
davidsons's Avatar
Joined Feb 2004
Originally Posted by DPHOYE
Yep...Steve has quite the lens to get all of these shots. There are a ton more of the Vypers, 42" Slicks, and my 27% Giles 202. Really neat shots.
I need a willing participant to get some of my 42" Slick in a hover. Kirby shot some but not in the hover, was the end of the flight. Giles just stands out in that beautiful sky as does the yellow Vyper but I think my favorite shots are still the Silver Slick.
Old Aug 25, 2009, 03:24 PM
davidsons's Avatar
Joined Feb 2004
Originally Posted by bighead93
Just SICK! Nice work man...so how much to send you my Slick and create some magic?
If you mean the led's, I copied Mr. Basher's plane from the Fly Low In with the exception of the clear strip on the bottom of the fuse. Thanks for the idea Mr. Basher. It's pretty simple to set up with the led tape.
Old Aug 25, 2009, 03:25 PM
DPHOYE is offline
Find More Posts by DPHOYE
DPHOYE's Avatar
Rockwall, TX
Joined Dec 2004
Will add that to the "To-Do" list for Sunday morning dawn patrol. just need to make sure we have some music from The Crystal Method playing in the background.
DPHOYE is offline Find More Posts by DPHOYE
Old Aug 25, 2009, 03:26 PM
davidsons's Avatar
Joined Feb 2004
Not if you use the adhesive backing that comes on them which I did. If you were to leave the backing on or stick paper to it, you could tape them on so you could remove them. I would have done that but at some point, that will probably be a Night Flyer Slick only.
Old Aug 25, 2009, 03:28 PM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
Very nice!
And another shot of Slick Night Flyer
blakevan is offline Find More Posts by blakevan
Old Aug 25, 2009, 03:30 PM
davidsons's Avatar
Joined Feb 2004
Both flights so far have been almost light enough to fly without them with the first flight being a little darker out. I did have issue with the airplane attitude a couple of times and therefore will most likely add some led strip to the horizontal stab as well. Also planning to extend the clear strip on the bottom which wraps up into the nose. I think that will illuminate the white part of the fuse covering from the inside out. If you stare at the led's when you are carrying the plane to the flight line, you will need to look away for a few seconds to let your eyes acclimate b/c they are very bright. I still want to try a 2s pack and/or castle bec on 9v volts. I guess I could put a 9 volt battery in just the same to simulate the cc bec on 9 volts. And, if I can ever get my rear up even earlier, I'll try to get a flight in with it dark dark.
Old Aug 25, 2009, 03:31 PM
davidsons's Avatar
Joined Feb 2004
Works for me.
Old Aug 25, 2009, 03:50 PM
G.P. is offline
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Thanks for the info.
BTW, what 27% Giles are you refering to? Wouldn't be an Ultra RC Giles by chance would it? I have one and would love to see some good shots of one.
Old Aug 25, 2009, 03:53 PM
DPHOYE is offline
DPHOYE's Avatar
Rockwall, TX
Joined Dec 2004
Yep. PM me your email address and I will send to you by email.
David
Old Aug 25, 2009, 03:55 PM
davidsons's Avatar
Joined Feb 2004
Yes....David and I both have one. He liked mine so much that he bought one of the last available ones. He also can fly the snot outta his. He's getting his rollers down real good. Check your pm in a bit.
Old Aug 25, 2009, 03:56 PM
DPHOYE is offline
DPHOYE's Avatar
Rockwall, TX
Joined Dec 2004
or just go here
http://www.pbase.com/stevedavidson/image/116498316
Old Aug 25, 2009, 03:57 PM
DPHOYE is offline
DPHOYE's Avatar
Rockwall, TX
Joined Dec 2004
Sorry Steve...we posted at the same time
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 05:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 01:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 02:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 03:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 10:57 PM
