if you are having trouble getting it to flat spin, maybe you need to look at your setup. I've got mine exactly like the directions call for and it tumbles and spins like a drunken monkey.
My Slick will blender, and if I nail the power it drops into wicked knife edge spin. That is actually the best way for me to enter a ke spin with the Slick. Other ways aren't as efficient for me. Another nice one is fly in a knife edge and outside snap it, then hold the rudder and elevator in and center the ailerons. I did that today and it was so violent that I thought the thing was going to explode. Flat spins aren't so hard that you need s lot of good technique. You just get it spinning and hang on. If you're having difficulty getting it to go in, your CG is probably off or you might be nose heavy. You also need all the rudder movement you can steal. Now, if you want it to totally flatten out and spin fast....and you aren't going to believe this, try it on low rates. The big cotrols with a lot of deflection are a lot of drag, and than makes it difficult for the plane to go in. Try it on low rates by entering a conventional right rudder/right aileron/up elevator control imput, and then center the ailerons after a rotation or two. That should flatten it out reasonably well, but if you want more, center the elevator. Then you can push in down to speed the spin up, or up to slow it down. Be warned that when you get a plane into this sort of deep spin it won't want to come out of it without a few more turns after you release the sticks, but you can stop the spin fairly precisely with reverse rudder. |
Latest blog entry: Extreme Aviation Has A New Home
Palmdale, CA
Joined Oct 2008
I can get the flat spins going fairly well, but it seems prone to fall out of the knife edge spin for me. It will spin a few times but then will fall on its back and flatten out and start flopping around. I get into from a full power waterfall. I am still experimenting with the right amount of rudder and aileron. The funny thing is, every once in a while it does it perfectly with seemingly the same inputs.
Also been flying some Zippy 2650 20 C packs and I am less than impressed with these batteries. 5 minutes of the same flying style and I can tell the batteries are falling off. Makes me nervous not having the extra punch when you might need it. David |
Palmdale, CA
Joined Oct 2008
Gofly,
It's generally safe to use up 80% of the capacity, so if you're putting back less than 2100mah then you're okay. One formula that I have found to be true from testing on my setups is that the current draw at WOT is about 3X that of hover throttle. So, the position of your left stick makes a huge difference in flying time. |
Palmdale, CA
Joined Oct 2008
I was able to get the Velox to do a wicked knife edge spin from a waterfall with full power, but it doesn't seem to work as well as on the Slick. |
If the Slick tries to get on its back you can goose the aileron to get it back on its side...you just have to play with it a bit to see what works best in different power senerios. 1/2 to 3/4 throttle is the easiest range to for me to keep it in with no aileron once its in. |
Flat spins are awesome.
Easier to do than many manuvers I do them all the time on all my planes, just love the look and sound of them. But, like any trick, practice nets results. I now know instintevly how much of A, E, R & T to put into each plane to net a good flat spin. The best to date has been the 47"SHP...by far. The Velox is 2nd, Slick 3rd, 55Edge 4th, but all do it well. I judge "best" by flatness and roation speed. So, really, it all depends on the set up. "It all depends on everything realy." ![]() Make sure to go left rudder for upright and right rudder for inverted. Once you get the hang of the stick inputs needed for each specific plane. Do a couple with pulsing throttle. Maybe one strong pulse per rev. Takes a couple of pulsing revs to start to see the results, so start hi. Continue to time a strong pulse once per rev and just keep at it. This often nets a faster rotation. We never see enough flat spins in vids. We all post our crazy 3D moves, but a good flat spin is good to watch. It takes up some time so is something to see. Many of the more vilolent 3D moves are over very quickly. A flat spin can be held for many seconds as the altitude drop is slow. Never see enough of them in vids do we? CooHead |
hehe yea i love a flat spin too.inverted are my fav..i flat spun my extreme flight yak all the way to the ground hehehe yea was a while ago,but i think i felt ben had a better plane for the power system in it.so the hard landing,inverted,on the prop,was not that big a deal..lil glue and was ready to beat on some more lolol
Latest blog entry: Lil repair work.
| Thread Tools | |
| Discussion Need New 3d Plane from Previes gear. | NoMercy | 3D Flying | 2 | Jun 06, 2006 04:07 AM |
| New 3D planes from GWS? | assib | GWS (Grand Wing Servo) | 4 | Feb 24, 2005 12:34 AM |
| Sneak Peak At NEW 3D Plane from Dick Rankin | thechosen1one | Foamies (Kits) | 5 | Oct 11, 2004 01:27 PM |
| New 3D Planes from Fliton | LTChip | Parkflyers | 1 | Jun 19, 2003 02:17 PM |
| New "3D Aircraft" Discussion Group Proposal | Tim H. | Foamies (Kits) | 1 | May 02, 2003 09:57 PM |
