Old Mar 06, 2013, 06:10 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I got a response from hitec about my servos. Going to try then back on my old 8fg radio and see if that will smooth them out. If not he asked me to send them back to get looked at. He said he hasn't heard of mine and my friends issue before.
Mine were not notchy when l first got them. They were not notchy when my l built my friends 51 but his new 5085s were a bit. Well mine are now very notchy and his are really bad and he is scared to fly his plane because of it. The oonly thing l have done different has been getting a new radio and my friends seemed worse when he got his new radio. With that we both went up in resolution. I have since gone back down to the lower resolution and they are still notchy. I hooked them up to my futaba 7c and they are still notchy. Tried lowering voltage, changing receivers and all. Still notchy.
So last resort is to hook them up to the old radio that l know that they were smooth a few months ago and see if that changes anything.
Wait l just though about hooking them up to the programmer and seeing if resetting the servo will help. Going to try that now. Will let you know.
Point of the story is that hitec did contact me back and is offering to check out my servos and see if they can fix my issue. Way to go hitec!
losifanatic is offline Find More Posts by losifanatic
Old Mar 06, 2013, 08:37 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Losi, check and make sure the deadband is set low... I set mine to 1.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Mar 06, 2013, 10:58 PM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
Thinking of selling my slick.
Motrofly 3615-750
4 Hitec 5085's
don't remember the esc
Everything has less than 10 flights; like new.
What should I ask for it?
marksextra is offline Find More Posts by marksextra
Old Mar 07, 2013, 03:07 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by bryansifsof44 View Post
Yeah I don't understand the same specs at the higher volt... A faster stronger 85 running at 8.4V is what I was referring to. After going HV in my 60 and 71 I feel the slower servos.
Its just like it is with motors, they use a lower Kv to match the power capability of the motor to the higher voltage. Only way to get more power/torque would be to use a physically larger motor.
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 07, 2013, 04:15 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Motrofly 3615-750
4 Hitec 5085's
About 20% less than you have in it would be good IMO.
GoldCraft is offline Find More Posts by GoldCraft
Old Mar 07, 2013, 05:22 AM
joshgluck is offline
Find More Posts by joshgluck
joshgluck's Avatar
United States, NJ, Middletown
Joined May 2012
Motrofly 3615-750
4 Hitec 5085's
$100 on the nj/pa border for pickup and you got a deal ;-)
joshgluck is offline Find More Posts by joshgluck
Old Mar 07, 2013, 07:40 AM
Joined Oct 2011
I just don't understand that they would come out with a HV servo without increasing the performance... only benefit is you could run it off of a 2s pack. Which for me is not a option on this small of a airplane. I run HV servos in my 60" and 71" planes and the speed and power output is significantly more then there lower volt counter part of the same size. We have the technology.
Old Mar 07, 2013, 08:19 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
Thanks for the reply. I don't remember how much I've got in it, but I did a search in the classifieds and it looks like $350 might be the place to start. Beats me.
Old Mar 07, 2013, 09:41 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I'd start at $400 and accept anything greater than $330 or so.
turnerm is offline Find More Posts by turnerm
Old Mar 07, 2013, 10:26 AM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Motrofly 3615-750
4 Hitec 5085's
Ill take he ESC if you'll part out
Park_aviator is offline Find More Posts by Park_aviator
Old Mar 09, 2013, 03:42 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
A long tale of woe and determination!!!
So.... I finally had some time, and a clear work bench, so I decided to get started on my 51" Slick.....as per usual, I opened up all the holes in the covering, then glued in the control arms, then, as I like to do, I mounted the motor after making some spacers with my lathe....then it all went to "hell in a hand cart" as the old saying goes!!!! First thing....the prop shaft of the motor is just a few thousands of an inch larger than it was supposed to be (verified against other motors), and the Extreme Flight spinner won't go on, no biggie.....chuck it up in my lathe and polish the shaft down....easy-peasy..Spinner now fits.....Then I was going to fit the cowl, so, decided to put a block in the landing gear mount area, just to hold the fuselage off of the table, except that when I tried to unscrew the right side screw, the blind nut broke loose!!! Oh man!!! Then I thought, ok...no big deal, I would just re-seat it, and drive the prongs back into the wood disk that is epoxied onto the carbon fiber landing gear re-enforcement...WRONG! there are no prongs, and the screw won't come out, so I cut the head of the screw off, but there was no room to get what is left of the screw and the blind nut out due to the carbon fiber tube......
This leaves only one way to get the blind nut and screw out without cutting the covering on a brand new plane......take the carbon fiber tube out ... Fortunately, I have a selection of long "aircraft" drill bits, so, it was just a simple matter to drill through the length of the tube to take it out. Once the tube was out, the blind nut came out with no problem, except that now I have to fit another one in....guess what...it is one of those small M3 blind nuts, that nobody, and I mean nobody sells (at least not that I have been able to find)....so...I start looking through all my hardware bins, and you have to understand, I have tons of loose screws, bolts, washers, nuts, etc.....that one of these years I need to spend about three days and sort out...So...I start looking, and I must have found 100 or more 4-40 blind nuts, which are physically the same size, but of course you still can't thread an M3 screw in.....now, yes, somebody is going to say.....why not just use a 4-40 blind nut and screw.....yes, I could have easily done that....but I am finicky (anal) about that kind of thing....so, after about an hour of searching..i found ONE!!!! (but then, one was all I needed) Then the next trick,,,,get it down into the fuselage and tighten it....and even though I have very long needle nose pliers, and they would reach, I couldn't open them to hold the blind nut....so...... as I always save those little round discs that come out of laser cut "doo-dads", (like the battery boxes I sell for the Byper), I drilled a hole in one of those, and seated the blind nut into it...but then, I still have to put glue on it, get it in there, and then thread a screw into it to hold it in place while the glue dries.... So...I spray some Zap "kicker" onto the blind nut, and put just a small dab of thick CA on the end of a dowel, which allows me to stick the blind nut down into the fuselage, and screw the screw in...I then used a plastic "pipe-et" to put thick CA all around it..."voila"...the nut is back in....Now to see if I have any carbon tube the correct size.... the first piece I found was too large of diameter, and I thought that was all I had, but I looked some more, and found the perfect size.....So....after about two hours of fussing and cussing..I was right back where I started, except that now I have to clear my building table of all the boxes that I had to look through to find everything I needed...
Sorry for the long tale.....but maybe if anybody else has this problem, they will at least know the steps needed to fix it!!!
SteveT
SteveT. is online now Find More Posts by SteveT.
Old Mar 09, 2013, 06:42 AM
pmackenzie's Avatar
Joined Dec 2002
http://rtlfasteners.com/RC/bn030.html
HK also lists them, but out of stock of course
Old Mar 09, 2013, 06:58 AM
joshgluck's Avatar
Joined May 2012
So.... I finally had some time, and a clear work bench, so I decided to get started on my 51" Slick.....as per usual, I opened up all the holes in the covering, then glued in the control arms, then, as I like to do, I mounted the motor after making some spacers with my lathe....then it all went to "hell in a hand cart" as the old saying goes!!!! First thing....the prop shaft of the motor is just a few thousands of an inch larger than it was supposed to be (verified against other motors, and the Extreme Flight spinner won't go on, no biggie.....chuck it up in my lathe and polish the shaft down....easy-peasy..Spinner now fits.....Then I was going to fit the cowl, so, decided to put a block in the landing gear mount area, just to hold the fuselage off of the table, except that when I tried to unscrew the right side screw, the blind nut broke loose!!! Oh man!!! Then I thought, ok...no big deal, I would just re-seat it, and drive the prongs back into the wood disk that is epoxied onto the carbon fiber landing gear re-enforcement...WRONG! there are no prongs, and the screw won't come out, so I cut the head of the screw off, but there was no room to get what is left of the screw and the blind nut out due to the carbon fiber tube......
SteveT
Awwwwww Nutz!
Sorry Steve that really sucks. Glad you were able to get it sorted. Keep us posted on the build and maiden.
Good luck!
Old Mar 09, 2013, 08:07 AM
pilot_keeter is offline
Find More Posts by pilot_keeter
pilot_keeter's Avatar
United States, GA, Winder
Joined Nov 2008
Sorry to hear about that Steve, I hope I don't have the same misfortunes!
While I'm here... Are their any special circumstances taken to mount the Motrolfly? (for future reference)
pilot_keeter is offline Find More Posts by pilot_keeter
Old Mar 09, 2013, 08:13 AM
richord is online now
Find More Posts by richord
United States, FL, Jacksonville
Joined Jun 2008
3DHS great customer service.
SteveT
That suckz!!!
Sorry you had a heck of time with that.
I had a handful of hickups with my build. But they weren't so invasive as described above.
I would like to say that in spite of a few mis-manufactured pieces, 3DHS provided me with excellent customer service by readily responding to my emails and shipping replacement parts out quickly and without any hassle.
richord is online now Find More Posts by richord
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
