Old Jan 13, 2013, 03:19 PM
TimmyC is offline
Find More Posts by TimmyC
United States, MI, Allegan
Joined Aug 2012
I'm using 82mgs and a dynam 60a esc. No binding. I'm going to either put a bec in or swap to an ice 50. These dynams stutter a lot on startup too.
TimmyC is offline Find More Posts by TimmyC
Old Jan 13, 2013, 03:34 PM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Well if I was a betting man I would put it on a brownout... That ESC has a 3amp BEC which is at 3s, so at 4s that rating is even lower. The ice has a 5amp BEC which is also lowered by higher main voltage. I don't use the internal on anything above 4 micros (65mg or equivalent). Used the internal on a 500 pro which worked great all summer long and when temp got below 35F I had a brownout. Installed a CC 10 amp BEC found here which eliminated issues and can be found for around $20. Good luck.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jan 13, 2013, 03:41 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
The Dynam ESC is just a re-labelled Hobbywing Pentium. Turnigy Plush are also just re-labels of the Hobbywing. They are all decent enough ESC's for the price.
It has a switch mode BEC, which is a good thing, but it's only rated at 3 amps which is a bit marginal for a plane of this size. I'd go with an external BEC, the castle Creations 10A peak BEC is hard to beat.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 13, 2013, 04:17 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by turnerm View Post
Repeat after me...
My name is "jetinteriorguy" and I have a problem..."
I currently have a 71" Slick, 58" Edge, 57" SC, 48" Super Vyper, UMX 3D Sbach, UMX 3D Beast, QQ Edge, and a Crack Yak and I already get RC ADD every time I'm heading out to fly.
That should be....
"My name is _________ (insert name), and I have a problem....
I own ___________________________ (insert names of planes)....
But then....What's the problem????
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 13, 2013, 04:57 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Originally Posted by SteveT. View Post
That should be....
SteveT
Steve... I think if anyone needs an intervention it would be you my friend!!
But I have to say - I'm jealous as hell of your hangar. Too bad your WAY over there on the West coast.
turnerm is offline Find More Posts by turnerm
Old Jan 13, 2013, 05:25 PM
Mmarshall is offline
Find More Posts by Mmarshall
Hey... watch this...
Mmarshall's Avatar
Herndon, Virginia, United States
Joined Feb 2003
OK guys I did a search and see some posts about 65 degree's of throw on the elevator, I am getting 55 using a HS85MG and feel it is not enough for waterfalls and knife edge spins.
My EF 48 Edge has at least 65 degree's and spins like crazy but my slick is hitting the bevel at 55.
Are some of you spacing the elevator back a bit on the hinges to get 65 or have you done something else?
Mine is nice and tight to prevent flutter and I would either have to re-hinge it or remove the covering to increase the bevel then recover to get more.
Advice?
Mmarshall is offline Find More Posts by Mmarshall
Old Jan 13, 2013, 05:27 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Yup....and you would be welcome to a pull on any of them....
I'm just waiting on Bigfoot....and then that will probably be it for a while......but I am possibly selling the Yak 54....
SteveT
Old Jan 13, 2013, 05:43 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Advice?
Yea... I set mine up to have a rather healthy hinge gap so I can get max throw. Although I didn't measure it, my buddy has to have nearly 70-80 degrees!!
Old Jan 13, 2013, 05:56 PM
TimmyC is offline
Joined Aug 2012
Good to know that the esc is decent. I agree on the brownout. I will put a bec in the next one. I'm not sure if I can fix this one or not. I might try anyway.
Old Jan 13, 2013, 06:59 PM
stormz is offline
Find More Posts by stormz
United States, NC, Clayton
Joined Feb 2011
just completed my build on the 51, I set my gap to get about 50 to 55 is that not enough to get a tight ke spin on this plane
stormz is offline Find More Posts by stormz
Old Jan 13, 2013, 07:29 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Yes its more than enough. I can get a tight ke spin with 45* and tight waterfalls too. I have a neutral cg. I do how ever have 64* out of mine to get crazy with every now and then. I normally fly on mid rate (50* elevator and 35* ailerions)unless l am doing something extremely violent.
losifanatic is offline Find More Posts by losifanatic
Old Jan 13, 2013, 07:45 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
We need to see an extremely violent Losi video!!
Old Jan 13, 2013, 07:54 PM
Sippin the Koolaid!
Joined Oct 2007
Agreed will see what l can do.
Old Jan 13, 2013, 08:04 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Don't forget to duck.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jan 13, 2013, 08:09 PM
Sippin the Koolaid!
Joined Oct 2007
LOL Yeah that wasn't one of my better moments don't think it was one of safetyhawks either
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
