Old Dec 28, 2012, 09:23 PM
3DHobbyShop Addict
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Originally Posted by JetPlaneFlyer View Post
Terrible in actual use, or was it just the internal design issues which you listed?
I had one die right when I hooked one up and another one got suuuuper hot just holding it with no load. other two were fine....but that was enough for me to send em all back!
Alex Schauer is offline Find More Posts by Alex Schauer
Latest blog entry: 3DHS 48" Extra Windy Day Flying
Old Dec 28, 2012, 10:50 PM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Originally Posted by AeroKen View Post
I saw a guy at our field carefully start his plane with a starter and all the proper precautions on the starting bench. He taxied out and it died on the runway. And then he got impatient, hand flipped it right there on the runway with no protection, and got his fingers cut. Safety equipment only works when you use it
I fly electric, so no starting worries. But I do keep a rubber band holding the left stick down when I'm not flying. I've thought about a throttle cut switch, but I worry that I'd accidentally hit it during a flight and not fumble it back fast enough to avert disaster. So far dealing with what I want the plane to do, what it actually is doing, two sticks and a dual rate switch uses up all of my available brain power - nothing left over for another switch Maybe more practice will change that.
The switch I use is my throttle hold on my helis, so I am pretty quick with it.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 29, 2012, 12:06 AM
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Originally Posted by stormz View Post
Same here with my 30cc/ not a issue anymore my hand is coming towards me after the flip anyway
I will add one to your hand coming back towards you. (I am also taking a step sideways as I flip it!
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Dec 29, 2012, 10:18 AM
tacdriver's Avatar
United States, Mt, Bozeman
Joined Dec 2010
+1 on getting your hand out of the way, and turning it via the spinner or front of prop to index it before flipping since the DLE will send a spark when the magnets pass, despite any rpm. the OS ignition has an rpm cutoff so the pop won't happen.
hey wait... isnt' this an electric thread? Hah!
tacdriver is offline Find More Posts by tacdriver
Old Dec 29, 2012, 04:32 PM
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Description: Had some excitement the other day. About to take off, gave it full throttle, heard a screech and the motor quit. Then some smoke appeared followed shortly there after by flames. I ripped the battery out with a pair of pliers and a buddy poured some water on the motor box.
Just charred the wood around the motor box and put a small melted spot on the cowl. New ESC and i should be back in the air.
Gravitycheat is offline Find More Posts by Gravitycheat
Old Dec 29, 2012, 04:37 PM
chq28's Avatar
USA, MI, Portage
Joined Feb 2009
Wow, that looks like it was exciting!
chq28 is offline Find More Posts by chq28
Old Dec 29, 2012, 04:51 PM
Joined Dec 2009
It was excitingly scary in a " I wish it had not happened to my plane" kind of way.
Old Dec 29, 2012, 05:11 PM
Fus ro dah!
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Well, there's your problem.
Bigster is offline Find More Posts by Bigster
Old Dec 29, 2012, 05:35 PM
Joined Dec 2009
Originally Posted by Bigster View Post
That's Funny!
Old Dec 29, 2012, 05:57 PM
Addicted to 3DHS.
3Daddict's Avatar
ohio
Joined Oct 2010
Originally Posted by Gravitycheat View Post
Attachment 5405334Had some excitement the other day. About to take off, gave it full throttle, heard a screech and the motor quit. Then some smoke appeared followed shortly there after by flames. I ripped the battery out with a pair of pliers and a buddy poured some water on the motor box.
Did you ever figure out why your speed control caught fire? what brand was it?
3Daddict is offline Find More Posts by 3Daddict
Old Dec 29, 2012, 06:03 PM
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Kitty Hawk
Joined Oct 2007
It caught fire so l would be willing to bet its a castle. Wait crap l have all castle escs
losifanatic is online now Find More Posts by losifanatic
Old Dec 29, 2012, 06:06 PM
Addicted to 3DHS.
3Daddict's Avatar
ohio
Joined Oct 2010
I have several castles and have not had issues. But I have heard of others having problems since they started making them in china. I still feel they are a good speed control. I just ordered a ZTW 50 amp for my 47'' extra because my hacker X-55 was bad out of the box and is out of warranty.
Old Dec 29, 2012, 07:35 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Not Castle....Castle ESCs have red, black and white motor wires (at leas all of mine do)....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 29, 2012, 07:47 PM
SteveT.'s Avatar
San Jose, CA
It's bad enough when it's a 51" Slick.....even worse when it's an 89" Slick!!
SteveT
Old Dec 29, 2012, 11:05 PM
Surrey, B.C.
Joined Feb 2004
This happened on my 51" slick to but it was my Hacker A30-12XL2 that took out my ICE 75.
Lucky for me the damage to the plane was minimal so a new esc + Motrofly motor & I was back in the air
Mach3 is offline Find More Posts by Mach3
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
