Old Dec 27, 2012, 09:47 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by alexjschauer View Post
Hmm that's interesting!!!
The ones I got we're TERRIBLE!!!
Terrible in actual use, or was it just the internal design issues which you listed?
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Dec 27, 2012, 01:29 PM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Just ordered these for my son's we got him for Christmas. Did you have to open the hole anymore or did they drop in?
Robert
Originally Posted by JetPlaneFlyer View Post
Just a follow up on this warning I got about the Solar D658 servos I used in my Slick.
I've been using them since august and they have been fine. They are pretty fast have plenty of torque and centre well. I did open one up to check out the reported issues. Here's what I found:
  • Plastic gear - yes, there is one plastic gear which is the small gear that is driven directly from the motor pinion. I don't see this being great weakness as the torque at that point in the reduction gearing is very low. FWIW the much trusted and recommended Hitec HS-85MG has a plastic gear in exactly the same position!
  • Gear rubbing on the pot - I found no evidence of this.
  • Wire relief - Yep the wire comes straight from it's solder points on the PCB and exits the case. I'm not sure if this will ever prove to be a problem as the wire is gripped by the bottom case cover and the solder points on the PCB are very robust. Only if you were really hauling on the wire constantly could I imagine it causing a problem.
4 months of use probably isn't enough to draw any positive conclusions but so far so good....
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Dec 27, 2012, 06:42 PM
tacdriver is offline
Find More Posts by tacdriver
tacdriver's Avatar
United States, CO, Fort Collins
Joined Dec 2010
Originally Posted by SteveT. View Post
Put gas in....flip prop till engine starts, taxi out, restart engine after it dies waiting to take off, fly until gas is low or engine dies, land, taxi n (if engine is still running)....repeat as needed....what else do you need to know?
SteveT
A good pilot knows how to setup and run both!
tacdriver is offline Find More Posts by tacdriver
Gravitycheat is online now
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Robert
For what it is worth. I have been running the Solar d657's for a few months now and love em. Not sure of the differance between the 658 and 657. I have no issues at all. have one in the Slick tail and the others in my Twisted Hobbys big Sbach.
Gravitycheat is online now Find More Posts by Gravitycheat
Old Dec 27, 2012, 07:45 PM
stormz is offline
Find More Posts by stormz
United States, NC, Clayton
Joined Feb 2011
SteveT
I think this dle was easy to tune, never had that issue so far anyway.
Here is a short vid of plane when I first got it. A great buy at $800 though
3DHS 74 edge (3 min 30 sec)
Steve L
stormz is offline Find More Posts by stormz
Old Dec 27, 2012, 08:37 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
SteveT
Guys....
I was just being a little facetious when I posted this, but was also joking, certainly meant no offense to anybody.....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 27, 2012, 08:59 PM
stormz is offline
Joined Feb 2011
none taken / was just stating the dle 30 on this plane runs well
Old Dec 27, 2012, 10:54 PM
Mr_McGlue's Avatar
Joined Sep 2011
Just got them today and they do look pretty nice. A little larger all around so will be breaking out the dremel tool everywhere
Robert
Old Dec 28, 2012, 04:05 AM
Aberdeen
Joined Mar 2006
Robert
Robert,
Yes, I had to open the holes up slightly but the mounting screws still picked up the plywood mount plate ok. I just trimmed the hole out with a modelling knife, I'd not like to take a Dremel to it personally, too hard to control for my liking.
Old Dec 28, 2012, 04:13 AM
Aberdeen
Joined Mar 2006
The 657 and 658 are virtually identical. The only difference in spec I can see is that the 658 is a little bit faster (0.08s vs. 0.1s) and 1g heavier. Torque and case dimensions are the same.
Old Dec 28, 2012, 05:37 AM
Joined Dec 2009
Old Dec 28, 2012, 07:16 AM
Mr_McGlue's Avatar
Joined Sep 2011
I've done it successfully on my Osiris but I do understand what your saying
Dropping some thin CA in the screw holes helps too.
Robert
Robert,
Old Dec 28, 2012, 09:41 AM
tacdriver's Avatar
Joined Dec 2010
http://www.youtube.com/watch?v=raU8k...ature=youtu.be
Steve L
What a beautiful grass runway!
Old Dec 28, 2012, 10:16 AM
tacdriver's Avatar
Joined Dec 2010
I've got a couple of Solar D658's unopened if anyone wants them. $10 each? Also a couple D771's $15 ea? So buy all 4 and I'll pop for the priority mail. Brand new, in the bag, unused. One D771 bag was opened and servo plugged in to a receiver to test it, that's all.
Old Dec 28, 2012, 11:02 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
SteveT
Well at least the planes are getting to the field. To hot, to cold, to windy, to, to, to. Some dudes at our field to get out there, then they stand over their chargers the whole time. first to charge, the to discharge.
I am just being a little facetious.
robj is offline Find More Posts by robj
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
