Old Dec 14, 2012, 04:50 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by erkq View Post
Well, if she had destroyed it, you would have deserved it. You're a bad, bad man...
Yup!!! LOL....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 14, 2012, 04:53 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by AeroKen View Post
I have an amazing ability to over think everything and make projects like this take several times longer than they should
Still, I may be able to get to it In the next month, but not in the next couple weeks, and January does get colder, and sooner or later the runway will be snow covered. I'm not going to risk maidening my first really nice plane with freezing fingers or an iffy runway.
Over-thinking on any 3DHS plane is not necessary, just follow the instructions...
SteveT
Old Dec 14, 2012, 05:41 PM
3DNater is online now
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
My first slick took 4-5 hours. I think I could trim a lot off that now.
3DNater is online now Find More Posts by 3DNater
Old Dec 14, 2012, 05:52 PM
AeroKen is online now
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
SteveT
If it was necessary, it wouldn't be over-thinking
Seriously, thanks for the encouragement guys, I probably will try to get it built as soon as I have the time, just in case there is a nice day to fly.
AeroKen is online now Find More Posts by AeroKen
Old Dec 14, 2012, 07:15 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Believe me when I say, I am very "finicky" (some might use another word) when I build a plane, (which is one reason most people have no qualms about buying a plane I have built), and though, yes, there are a few things I do differently, that is not because they need to be done differently, but rather, just because I have my own way of doing some things. For instance, I don't like "swiss cheese" firewalls, and when I install a motor that needs different bolt holes than what is stock, I will usually replace the firewall...No real need to do so...it's just my way of doing things....
SteveT
Old Dec 14, 2012, 08:01 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
And that's why we like ya Steve
losifanatic is offline Find More Posts by losifanatic
Old Dec 14, 2012, 08:09 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Thank you my friend!! But I thought it was for my handsome face and bubbly personality....
SteveT
Old Dec 15, 2012, 02:23 AM
edf_rookie is offline
Find More Posts by edf_rookie
edf_rookie's Avatar
Australia, QLD, Brisbane
Joined Mar 2011
Steve T,
Who mentioned a while back what ply you used and where you got it from but I can't find which thread it was in again. Can you please let me know again.
edf_rookie is offline Find More Posts by edf_rookie
Old Dec 15, 2012, 03:00 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Well....there is Birch plywood and "lite" ply... The Birch plywood is the hard stuff, and lite ply is the "soft" soft stuff. Either one can usually be found in any good hobby shop is thicknesses. You should be able to find Birch plywood ranging from 1/64" up to 1/4" (sometimes 3/8").
You will normally find Birch plywood in 1/64", 1/32", 1/16", 3/32", 1/8", 3/16" and 1/4" thicknesses and in 6"X12" sheets, 12"X12" sheets, 12"X24" sheets and 12X48" sheets.
Lite ply is actually Poplar plywood, usually found in 3/32" 1/8", 3/16" and 1/4" thicknesses in the same size sheets.
Tower Hobbies has a wide selection of plywood's found here..
National Balsa has a wide selection found here...
And Midwest Model products has it, found here...
I am sure you can find model plywood's in Australia, but they may be in metric sizes instead of SAE (fractional inch) sizes.
Neither of these types of plywood's are exactly the same as the plywood's used in Chinese made ARF's, but the Birch plywood can be substituted, at the cost of slight additional weight, but greater strength...
Hope this helps....
SteveT
Old Dec 15, 2012, 09:08 AM
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Steve the only downside of Birch ply is that it cannot be laser cut without major charring... unless there is something we don't know (highly possible). Our laser won't do it. the birchwood is just too reflective.
Old Dec 15, 2012, 12:53 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Well.....it can be cut, but you need a high power laser, and yes, there is charring and smoking. I had a new motor box made for the 70" Velox that I designed for use with a Hacker A60-5XS, and yes, it got smoked pretty badly, but the cuts were not ragged or anything.
Do you know where to find the type of plywood that is used in the Chinese kits? I wouldn't mind stocking up on some, just for that reason.
SteveT
Old Dec 15, 2012, 01:10 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I haven't ordered any, but I had this place bookmarked for that very reason
http://www.aircraftspruce.com/catalo...s/02-28050.php
3drcparts is offline Find More Posts by 3drcparts
Old Dec 15, 2012, 01:21 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
That is still birch plywood, not the Chinese stuff.... It is just in metric sizes. I have used it before.
SteveT
Old Dec 15, 2012, 01:23 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Oh, but at least it is 2mm, what wood is the Chinese stuff?
Old Dec 15, 2012, 04:13 PM
3d NOOBular
3DNater's Avatar
Joined Aug 2010
Steve I know you can find it in China I have scoured the internet for a U.S. distributor. I can only find birch in that 3/32 thickness.
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
