Old Sep 28, 2012, 09:27 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Originally Posted by 3Daddict View Post
I will have to check this, how do I find out if it was the battery?
thank you,
3Daddict
usually one cell will have a much higher IR, but it is strange that it happen after being at idle
3drcparts is offline Find More Posts by 3drcparts
Old Sep 28, 2012, 10:00 PM
3Daddict is offline
Find More Posts by 3Daddict
Addicted to 3DHS and EF
3Daddict's Avatar
United States, FL, Bonita Springs
Joined Oct 2010
That is why I am thinking it might be my speed control. If it is my speed control I will have to hang this plane up for a while as I do not have any cash left after buying the parts for a 57'' extra. This plane is tough as nails though, other than the LG and prop there is not even a scratch on this plane and it fell from about 12 feet.
3Daddict is offline Find More Posts by 3Daddict
Old Sep 28, 2012, 10:29 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
I was flying my slick today and was doing a flat spin. I went to about tree top level like I always do and went to give it power and I had none. I have the hacker X70 pro, thankfully all I broke was the LG and my prop. Anyone have any ides as to why my speed control would not start my motor. It seems to be working now. I am clueless and at this point am thinking I might have to buy a new speed control that I do not have the money to spend on right now.
I had that happen a few times on my 1st 51. Kept yanking motor bullets apart during knife edge spins. Double check the motor lead bullets... I directly solder most of them now, and if not I at least make sure I re-do the factory bullets on both ends and then tape the bullets together with high quality electrical tape. Never had any problems since doing these methods.
ryan_m is offline Find More Posts by ryan_m
Old Sep 28, 2012, 11:15 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I prefer heat shrink over the bullets..no nasty gunk to remove after a while....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 28, 2012, 11:52 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
I have found that I have the same problem with my hacker pro 70!! Same exact scenerio happened exept for I backed off the power and then hit it again and the prop spun the correct direction. Every since that happend I always make sure I am running a slight throttle when doing a flat spin! I cant stand how it does that!
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Sep 29, 2012, 12:01 AM
Joined Jan 2012
Also I have been told that this is typical with the ESC. If you are completly shut down and just barley throttle up sometimes it will spin in reverse and the only way to get the prop to spin the correct way is Power Down and then power up again. (Sorry I should have been more specific on the last post with what happens to mine all the time.
Old Sep 29, 2012, 01:32 AM
edf_rookie is offline
Find More Posts by edf_rookie
edf_rookie's Avatar
Australia, QLD, Brisbane
Joined Mar 2011
Originally Posted by 3Dplank View Post
Use the ones that came with the plane hardware bag.
Excellent, thanks for that
edf_rookie is offline Find More Posts by edf_rookie
Old Sep 29, 2012, 01:53 AM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
Is anyone looking for a V1 motorbox? I bought one brand new off a member here on rcg thinking it was V2. Sure enough it isn't, and I need to get a V2 (or would like to.)
Anyways, if you want it toss me an offer, its in New condition.
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Sep 29, 2012, 03:22 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Yep, I had to deadstick land a few times when I was using a similar ESC. Trying to power up from a situation where the prop has stopped, the prop just 'judders' back and forth and the motor cant power up. It's caused by the ESC not being able to read where the rotor is when it's not spinning . It's a inherent weakness of all sensoreless ESC's but most work around it very effectively, a few like the Hacker seem to struggle sometimes.
What some do is program an idle so that the prop can never stop. They seem happy with that work-around but they might still have issues starting the motor at the beginning of a flight. Personally I went to a ZTW ESC.
It doesn't sounds like a failing battery to me. That would usually show up by LVC activating when you went to WOT, not by the motor refusing to start up from a dead stop situation.
Here's a video of what the ESC start up problem looks like:
Brushless motor stutter ESC (0 min 9 sec)
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Sep 29, 2012, 05:54 AM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
Originally Posted by JetPlaneFlyer View Post
What some do is program an idle so that the prop can never stop. They seem happy with that work-around but they might still have issues starting the motor at the beginning of a flight...
This do not only solve the startup issue, but also give a lot faster throttle response from idle to full, at least on the HobbyWing ESC:s that I use. It are making some maneuvers a lot easier and is very handy when the need to bail out arises.
Stark is offline Find More Posts by Stark
Old Sep 29, 2012, 09:04 AM
Joined Jan 2012
Do u mean put a small amount of throttle curve on?
Old Sep 29, 2012, 09:16 AM
Stark is offline
Stark's Avatar
Joined Sep 2001
Yes. I use the throttle curve function on my Futaba 6J and create a curve with idle at about 8-10 procent, just enough to turn the prop around in a steady pace. I then switch to this curve when I'm ready for take off and after landing and taxiing, flip the switch to stop the prop.
tacdriver is offline
Find More Posts by tacdriver
tacdriver's Avatar
United States, CO, Fort Collins
Joined Dec 2010
I do this, and found the plane also handles downlines better, with a more consistent speed. It acts like slight braking, pretty cool.
You can do it a couple ways: program a throttle cut to a switch. Plug in batteries with the throttle cut activated, let the ESC arm. When you enable the throttle, you'll get an idle automatically with the Hacker esc's. Don't know about others.
You can also just arm with the throttle trim all the way down to zero. Then bump up the trim until you get an idle.
I personally like the throttle cut switch because it prevents "oops" moments on the ground.
tacdriver is offline Find More Posts by tacdriver
Old Sep 29, 2012, 09:33 AM
Aberdeen
Joined Mar 2006
That's true, even the best ESC's have to start from dead stop by applying low power until the ESC can sense the position of the rotor, and only then go to full power. This means spool up takes a few moments.
Some RC cars get around it by using ESC's that use sensors in the motor to determine rotor position, so they can go straight to full torque from dead stop. I'm not sure you would want that sort of acceleration in planes, it might tare the motor box out.
What puts me off programming an idle is the risk that I might forget to 'kill' the motor if I ended up nosing over on landing and so I might burn the motor.
Old Sep 29, 2012, 09:52 AM
Stark is offline
Stark's Avatar
Joined Sep 2001
Yes, therefore I don't dare to use it on my foamie.
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
