Old Sep 08, 2012, 03:42 AM
Surrey, B.C.
Joined Feb 2004
I had to do the same when I put on my Motrofly motor but don't worry it will be awesome. I'm just loving this plane but now I'm thinking bigger is better & my extra my have to grow from a 47" to the 57"
Mach3 is offline Find More Posts by Mach3
Old Sep 08, 2012, 06:38 AM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
One more thing guys. My bolts are VERY close to the motor housing. I can see a visible gap but just barely. Is this OK or should I use a dremel and cut off the end of the bolt a little?
turnerm is offline Find More Posts by turnerm
Old Sep 08, 2012, 06:52 AM
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Kitty Hawk
Joined Oct 2007
Do not dremmal next to the motor. Shavings will mess it up.
losifanatic is offline Find More Posts by losifanatic
Old Sep 08, 2012, 08:26 AM
Inverted-I-Fly's Avatar
United States, CA, Petaluma
Joined Mar 2011
take bolts out, cut/replace
Inverted-I-Fly is offline Find More Posts by Inverted-I-Fly
Old Sep 08, 2012, 10:35 AM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
It probably seems like an obvious thing to most people to take the bolts out FIRST but I'm glad you guys appropriately assumed that I'm an idiot and clarified this because I was gonna do just that - dremel the ends off while the motor is still attached.
So THANK YOU! I'll remove them first. If I'm gonna remove them I might just replace them with slightly shorter bolts anyway.
Old Sep 08, 2012, 12:27 PM
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Originally Posted by turnerm View Post
I'm glad you guys appropriately assumed that I'm an idiot .
jimmy34256 is offline Find More Posts by jimmy34256
Old Sep 08, 2012, 04:14 PM
Joined Mar 2011
just wanted you to learn from my mistake instead of learning from your own
Old Sep 08, 2012, 05:18 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I would not assume you are an idiot.....just perhaps not as experienced as some other folks around here....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 08, 2012, 05:24 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
SteveT
OK. I'll take that.
Old Sep 08, 2012, 05:25 PM
tacdriver's Avatar
United States, Mt, Bozeman
Joined Dec 2010
I think it was Stoops that said "the test comes first in flying, and if you survive the test, you get to learn the lesson"
While not a life and death thing, the Dremel filings would be one of those lessons!
tacdriver is offline Find More Posts by tacdriver
Old Sep 08, 2012, 05:34 PM
SteveT.'s Avatar
San Jose, CA
I like that!!
SteveT.
Old Sep 09, 2012, 01:11 PM
Joined Sep 2012
Which xoar model prop is the correct one for 3d flying. I had a apc 14x7 and it was nice but put on a xoar pjn beechwood series 14x7 and do not think it flew as well. Is that the proper prop?
kinman20k is offline Find More Posts by kinman20k
Old Sep 09, 2012, 01:15 PM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
It is. Most people prefer wood props over APC, what was it you didn't like about the xoar? You can also run a 15x6 if you are using the motrofly 3615. I used and really liked the xoar 14x7(with a motrofly 3615-750)
What motor are you running?
hone1er is offline Find More Posts by hone1er
Old Sep 09, 2012, 01:28 PM
United States, CA, Sebastopol
Joined Dec 2010
The Hacker will run the 15x6 also... it's within the spec. That's what I use exclusively.
erkq is online now Find More Posts by erkq
Old Sep 09, 2012, 01:35 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Agreed. The Hacker felt horrible with a 14x7 and felt GREAT with the 15x6. I think if you're using the Motrofly then (based on my calculations) you will need to use some throttle management to go up to a 15x6.
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
