I use the same Flightmax 2650s that you are...you should have close to a neutral CG with aft (rearward) end of the battery sitting just on top of the landing gear formers. I marked up one of you pics to show where I have the rear of the battery with my setup. See light blue lines on attached pic below. Only difference between our setups is I'm running an Airboss 80. |
Latest blog entry: Well...
This is where I put mine and works great for me. YMMV |
I fly mine with the CG very far back and its great.
No need to worry since you using the recommened setup, the Cg should be right on the money. |
Latest blog entry: 72" Extra Flying
With a 4s 2650 Flightmax Pack I normally set the CG with the front of the battery with the leads facing to the tail slightly less than an inch away from the end of the battery tray.
This makes it pretty neutral leaning towards the tail heavy side. I have flown it slightly forward also and it still great. I have even flown it WAY to forward and it still wasn't to bad. |
Maybe I should search youtube to see if anyone has posted on how to fix things the way Phil did... hopefully they show their technique used and tools. |
Joined Jul 2008
Hey everyone,
I just ordered the 51" slick running a hacker 30-12XL and a airboss 80 amp esc with 85mg servo's. I was woundering if this batt fits in the plane? http://www.hobbyking.com/hobbyking/s...dProduct=11920 |
Not a big fan of the nanos anymore. I like this short stubby thing..
http://www.hobbyking.com/hobbyking/s...idProduct=9320 About the size of some hyperion 2600 vx I run to. Gens ace 2600 has been real nice to. |
hopefuly those will get more air time.
| Thread Tools | |
| Discussion Need New 3d Plane from Previes gear. | NoMercy | 3D Flying | 2 | Jun 06, 2006 04:07 AM |
| New 3D planes from GWS? | assib | GWS (Grand Wing Servo) | 4 | Feb 24, 2005 12:34 AM |
| Sneak Peak At NEW 3D Plane from Dick Rankin | thechosen1one | Foamies (Kits) | 5 | Oct 11, 2004 01:27 PM |
| New 3D Planes from Fliton | LTChip | Parkflyers | 1 | Jun 19, 2003 02:17 PM |
| New "3D Aircraft" Discussion Group Proposal | Tim H. | Foamies (Kits) | 1 | May 02, 2003 09:57 PM |
