Old May 19, 2011, 11:03 PM
ultra stick is offline
Find More Posts by ultra stick
ultra stick's Avatar
yuma arizona
Joined Apr 2010
Lovin the smoke!!!!
ultra stick is offline Find More Posts by ultra stick
Old May 19, 2011, 11:06 PM
yuma arizona
Joined Apr 2010
ok battery just finished charging that I maiden her with and it put in 961mah's in on my 2200mah.Flew for bout 2 and a half minits.So I could fly for 4 minits pushing it?
Old May 19, 2011, 11:08 PM
heligrom is offline
Find More Posts by heligrom
Sippin' on Kool Aid
Long Island NY, USA
Joined Dec 2005
80% rule.
2200x.8 = 1760. That's about 4 minutes or so. I wouldn't go much farther then that.
heligrom is offline Find More Posts by heligrom
Old May 19, 2011, 11:09 PM
yuma arizona
Joined Apr 2010
ok I'll set my timer for that.thanks
Old May 19, 2011, 11:13 PM
Eric V is offline
Find More Posts by Eric V
Ocala, FL
Joined Jun 2007
Originally Posted by heligrom View Post
80% rule.
+1 on the 80% rule. Fried quite a few batts in my noob lipo days.
Eric V is offline Find More Posts by Eric V
Old May 19, 2011, 11:33 PM
yuma arizona
Joined Apr 2010
I've almost dun that to.
Old May 20, 2011, 12:02 AM
Eric V is offline
Ocala, FL
Joined Jun 2007
Question... Do the white nylon wing bolts included with the V2 Slick seem softer than the black V1 ones?
Old May 20, 2011, 12:58 AM
Eric V is offline
Ocala, FL
Joined Jun 2007
Really, Bad wing bolts now this. The axles didn't even try to thread into the nuts. It's like I got the wrong sizes. Anyone else having these kind of issues? This is my 3rd kit from 3DHS and I have never had this kind of poor QC.
Old May 20, 2011, 01:03 AM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
I had trouble threading one of my axles... went and bought a stainless steel nylon lock nut from the hardware store and it went right on with no trouble.
FireyFate is offline Find More Posts by FireyFate
Old May 20, 2011, 01:13 AM
Eric V is offline
Ocala, FL
Joined Jun 2007
Found the problem, look at the nut on the right. The question is now can I fix the axles and have solid gear? Or do I need replacements?
Old May 20, 2011, 02:11 AM
Eric V is offline
Ocala, FL
Joined Jun 2007
And 2 of the motor nuts are so caked with glue the bolts crossthread? Are you fornicating kidding me! Im up at 2am trying to put this thing together and at every turn i run into crap hardware. Not feeling the happiness I came home to. Anyone from 3DHS care to comment?
Old May 20, 2011, 05:51 AM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
If you have a spare 3mm bolt (I think it's 3mm), just run it through all the motor mount nuts and back them out again. Glue should not strip threads really. Just have to clear it out of there. Better to have too much glue than too little. As far as the gear nuts, just grab another from Lowe's or Home Depot. Should be a pretty easy fix. If you are still not happy, call Ben and the guys and try talking to them about it. They are very good about taking care of any legitimate issues. One of the most helpful and easy to reach bunch of guys in the hobby. An you aren't talking to some QC person that has no clue what they are talking about. Usually get to talk to the man himself.
Wamsy and everyone else, thanks again for the help with CG. When you talk about the sheeting on the wing, are y'all talking about the balsa ply that forms the leading edge?
StormJunkie is offline Find More Posts by StormJunkie
Old May 20, 2011, 06:48 AM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
Eric V,
3dhs is known for their quality. While there may be an occassional issue, just call them and they will more than adequately address your issue in a friendly, knowledgeable and professional manner.
Attempting to flame them on the forums likely is not the best method for problem resolution.
Just move on to other parts of the build that you can complete until you can call 3dhs.
KE Spin is offline Find More Posts by KE Spin
Old May 20, 2011, 06:55 AM
refugeefromcalif is offline
Find More Posts by refugeefromcalif
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
I was greeted by a big brown box with my third slick in it today! Spinners not included anymore?!?
IIRC, Spinners have Never been included as part of a kit.
Instead of Venting on here, You might be better off sending a PM or email, to 3DHS.
George
refugeefromcalif is offline Find More Posts by refugeefromcalif
Old May 20, 2011, 07:24 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Eric sorry to hear about your issues man. Its not normal. I have built 30 3dhs arfs in the last 2 years and never had an issue
losifanatic is offline Find More Posts by losifanatic
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 05:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 01:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 02:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 03:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 10:57 PM
