Old Apr 28, 2011, 01:15 PM
Azlodaniel is offline
Find More Posts by Azlodaniel
Azlodaniel's Avatar
United States, AZ, Mesa
Joined Dec 2010
Originally Posted by roadhogtri View Post
I have the monster power .32 and get 750+ watts constant at 46 amps with a xoar 14x7E prop and a 4s pack
I will keep the 32 in mind, I went ahead and ordered the 25 just to try it. I am going to put a a 14x7 on it and see what it pulls watts wise. Thanks for the info.
Azlodaniel is offline Find More Posts by Azlodaniel
Old Apr 28, 2011, 02:20 PM
Azlodaniel's Avatar
Joined Dec 2010
Did the motor mount right up to the current blind nuts on the 32
Old Apr 28, 2011, 05:46 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
FB = Flat Black. Its the new stealth night flying Slick.
_OZ_ is offline Find More Posts by _OZ_
Old Apr 28, 2011, 05:56 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
FB = Flys Beautifully
KE Spin is offline Find More Posts by KE Spin
Old Apr 28, 2011, 05:59 PM
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
As long as it's not a FaceBook version. I'm on social networking overload already as it is.
FireyFate is offline Find More Posts by FireyFate
Old Apr 28, 2011, 06:07 PM
_OZ_ is offline
It's gone...
_OZ_'s Avatar
Joined Aug 2004
Bwaha, that a good one too
Old Apr 28, 2011, 10:15 PM
Eric V is offline
Find More Posts by Eric V
Ocala, FL
Joined Jun 2007
sweeeeeeeeeet!!!!!!
Eric V is offline Find More Posts by Eric V
Old Apr 28, 2011, 10:24 PM
roadhogtri is offline
Find More Posts by roadhogtri
Bakersfield, Ca
Joined Nov 2004
Actually, I have the AJ Fliton 51". I've had it for a few years with a Saito 56, but converted it back to electric. I rebuilt the firewall for the saito and now I used carbon rods for standoffs on the electric motor. Here's a pic.
Be careful with these motors, I've heard bad and good about them. The armature came unglued on mine. Probably cause I put 960+ watts through it. I only did two or three short burst and that's all she took. It got hot real fast. I had to jb weld it back together.
This is an old plane, so I'm experimenting with this motor. Hopefully this weekend ill have it in the air. If I were you, I'd go for a quality motor. The Slick is to nice to put a motor that might fail on you in the air.
roadhogtri is offline Find More Posts by roadhogtri
Old Apr 29, 2011, 12:03 AM
sgomes is offline
Find More Posts by sgomes
Alameda, CA
Joined Dec 2006
I am in the process of gathering data on my Dan Sny wound Scorpion 3026-710, and would be very intetrested in watts and rpm for the various setups.
Anyone have any such data they would like to share?? And I will do likewise when I get mine.
Thx.
Steve
sgomes is offline Find More Posts by sgomes
Old Apr 29, 2011, 11:21 AM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Steve - If it's a Dan motor, those are pretty rare, and so I'd be surprised if anyone else in the thread has any test data...but I've had a couple of Dan's custom-wound motors and the amp-limit is incredible. The 160gram motor he wound for me was subjected to 85A spikes on many occasions and never burned up. Amazing.
blucor basher is offline Find More Posts by blucor basher
Old Apr 29, 2011, 11:44 AM
sgomes is offline
Alameda, CA
Joined Dec 2006
Ben,
Thx, yeah I wasn't clear on what I wanted.
I am hoping to see how the Dan motor compares to others like the 12xl or perhaps a stock 3026 or motrolfy.
Currently, using an Ice 75A, APC14x7, Hyp 4s 2650 35C I'm peaking out at only 750W and 7600rpm. I'm surprised the motor isn't pulling more amps, but if others are turning the same rpm, then maybe not??
More confusing yet to me, is I'm getting almost exactly the same 750w but at 7100rpm on a 15x8 - it's almost like there is some amp limiter in the programming of the esc that I have not addressed??
Also, I seem to recall one of your posts sometime in the past dealing with not getting full throt out of some brand of Castle esc. Does that issue persist, or has it been corrected with later firmware releases?
Thx for the input.
Steve
Old Apr 29, 2011, 12:04 PM
Joined Jun 2003
Steve - throw a 16" or 17" prop on there and take full wattmeter readings...will be terribly interesting to see what's going on. It is possible the battery voltage is falling off and just happens to be producing the same watt reading..or not. Let us know if you can.
Old Apr 29, 2011, 10:39 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by sgomes View Post
Ben,
Thx for the input.
Steve
i ran one of those i think in my 55 katana.Dan wound it for me back then and If i remember right with a good 4s battery I got like 1100-1200 watts from that thing.That motor may still be around here somewhere.Ran it on my 51 slick for a time after my reaper screwed up too.forget the amps tho.15x8 prop on the kat i think.
Manta1 is offline Find More Posts by Manta1
Old Apr 29, 2011, 10:54 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Anyone want a nice high res desktop of AJ flying a low-ish roller at SEFF?
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Apr 29, 2011, 10:56 PM
Joined Jun 2003
<raises hand>
I do.
so awesome.
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
