Old Apr 08, 2011, 10:34 PM
JeffSchre is offline
Find More Posts by JeffSchre
The loose nut behind the TX
JeffSchre's Avatar
Gladstone, MO
Joined Oct 2010
That it could be...I'll know for sure when I get the white EF spinner I'm planning to replace the red one with...red would have looked better with the old scheme but just doesn't look quite right with the new color scheme.
JeffSchre is offline Find More Posts by JeffSchre
Old Apr 09, 2011, 06:28 AM
mazjag is offline
Find More Posts by mazjag
Marietta GA.
Joined Jan 2011
Guys, I have got this thing and I love it, but have one small problem..I can`t get the elevator to trim properly. If my last move was a inside loop, it comes out and needs a click or two of down trim.. vise versa if it was outside..The servo is a new Hitec HS85mg..could it be this thing is not centering very well?? it looks fine on the ground and the linkage is ok. but something isn`t correct..I have tried a few different CGs....it just doesn`t track well pitch wise...thx..Jason
mazjag is offline Find More Posts by mazjag
Old Apr 09, 2011, 07:06 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
Hey guys Rob at ADC Hobbystore sells an aluminum oversize prop nut that eliminates the need for a washer. Take a look on page 973. And it doesn't chew up the aluminum prop adapter like a steel nut.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Apr 09, 2011, 07:25 AM
kenelder is offline
Find More Posts by kenelder
kenelder's Avatar
USA, FL, St Petersburg
Joined Dec 2003
Think I'd try a different servo, shouldn't be doing that....
kenelder is offline Find More Posts by kenelder
Old Apr 09, 2011, 08:25 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
I have found that the 82's and 85's get "sloppy" over time and don't center perfectly. is your 85 new? If so, return it. A new gear set would probably mine , i just have not tried it yet. It could be that i am hard on them. Kind-a-like red headed step children
Gravitycheat is offline Find More Posts by Gravitycheat
Old Apr 09, 2011, 08:28 AM
mazjag is offline
Marietta GA.
Joined Jan 2011
Yeah, I just ordered another one...Its new and I don`t see anything wrong, but maybe its a bum one..Other than that I love the plane...I`m not all that good and I can make the plane dead still in a hover..
Old Apr 09, 2011, 08:32 AM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Swap it with an Aileron Servo and see if the problem moves or improves. Sounds like a bad servo, (If pushing the Elevator Pushrod by hand, disconnected from the Servo and the Elevator has No Binding) that is.
heritageflyer is offline Find More Posts by heritageflyer
Old Apr 09, 2011, 10:15 AM
mazjag is offline
Marietta GA.
Joined Jan 2011
yeah, I though of that, but didn`t want to swap for a roll problem instead..I`m just putting a new one it, but I don`t see anything wrong..thx..J
Old Apr 09, 2011, 12:06 PM
heligrom is offline
Find More Posts by heligrom
Sippin' on Kool Aid
Long Island NY, USA
Joined Dec 2005
Had some fun yesterday after class. Nothing like 85 degrees, 5 mph winds, and then hordes of cheerleaders swarming into daytona beach.
heligrom is offline Find More Posts by heligrom
Old Apr 09, 2011, 12:36 PM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
I miss living in DB.
blakevan is offline Find More Posts by blakevan
Old Apr 09, 2011, 12:38 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Check for any binding in the elevator hinges, and control linkage. if the quick links on the servo arm or control horn are to tight it will not center, same for any binding in the hinges. every thing should move with out any friction.
if every thing is free try switching servos just to make sure it is a servo problem.
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Apr 09, 2011, 01:27 PM
refugeefromcalif is offline
Find More Posts by refugeefromcalif
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
I miss the women in So Cal. but, I prefer Living in Alabama.
George
refugeefromcalif is offline Find More Posts by refugeefromcalif
Old Apr 09, 2011, 01:47 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
I don't think he means permanently, I think he means so you can isolate the problem. If the elevator trim issue continues after you swap servos, it's most likely a binding issue....and it the trim issue follows the servos to the aileron then its the servo.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Apr 09, 2011, 03:48 PM
Azlodaniel is offline
Find More Posts by Azlodaniel
Azlodaniel's Avatar
United States, AZ, Mesa
Joined Dec 2010
Just started putting my slick together and went to tighten down the set screw for the pull pull cable and couldn't because there weren't enough threads for it to grab. So I Drilled it deeper, what do you guys think, will it be strong enough? I can tighten it down with out any issues.
Azlodaniel is offline Find More Posts by Azlodaniel
Old Apr 09, 2011, 03:59 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Yeah that will be fine!
losifanatic is offline Find More Posts by losifanatic
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
