Old Apr 03, 2011, 08:58 PM
jedoug is offline
Find More Posts by jedoug
jedoug's Avatar
United States, CO, Littleton
Joined Jun 2009
I'm running a Scorpion.
jedoug is offline Find More Posts by jedoug
Old Apr 03, 2011, 10:36 PM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
Originally Posted by jedoug View Post
Doesn't matter your going to love the 51". Ask any ?'s you need as you go through the build.
Can someone remind me the order of components when connecting the ball links? I recall it was important to *not* put a washer somewhere.
Bigster is offline Find More Posts by Bigster
Old Apr 04, 2011, 06:12 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I put the little washer on the out side so the ball link can't poop off. So I went screw ,then washer,ball link, threw control horn, then screw on nut.
losifanatic is offline Find More Posts by losifanatic
Old Apr 04, 2011, 06:38 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
I tend to over tighten things, so I put the washer between the the horn and the ball. Put it on top of the ball on assembly and the ball wore into the horn and the whole thing was loose. And yes I did use CA on top of the nut. The nut was NOT loose. If the washer is between the ball and horn it spreads the "load" over a larger area and doesn't wear the horn. Just my .02.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Apr 04, 2011, 06:51 AM
Sippin the Koolaid!
Joined Oct 2007
Went searching threw the manuals and they state to put the washer on the out side. Its even shown that way in the pics.
EDIT:
Waynes idea isn't all that bad either. Didnt think about that
Old Apr 04, 2011, 07:08 AM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
EDIT:
Use two washers......
jimmy34256 is offline Find More Posts by jimmy34256
Old Apr 04, 2011, 03:00 PM
roadhogtri is offline
Find More Posts by roadhogtri
Bakersfield, Ca
Joined Nov 2004
Anyone know how much right thrust is built in? Thanks.
roadhogtri is offline Find More Posts by roadhogtri
Old Apr 04, 2011, 03:09 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
the perfect amount... why?
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Apr 04, 2011, 03:21 PM
Bakersfield, Ca
Joined Nov 2004
I have the 51" AJ Fliton extra and need to rebuild the motor mount area.
Old Apr 04, 2011, 06:24 PM
Bigster is offline
Bigster's Avatar
Joined Sep 2004
Only problem is when I put two on, there are barely any threads left for the nut to grab onto. I like the idea too, but I'm going with one one the outside. Thanks guys.
Old Apr 04, 2011, 07:10 PM
jedoug is offline
jedoug's Avatar
Joined Jun 2009
The group of guys I fly with upgrade the bolt to a 2mm hardened steel for that reason plusyou have the extra security knowing that the bolt is good quality. Lost my first Slick due to one of the supplied bolts snapped on the elevator.
Old Apr 05, 2011, 09:39 PM
2-Stroke Freak is offline
Find More Posts by 2-Stroke Freak
Joined Jun 2007
Hi guys, new to the wide fuse world. Came home from the Toledo show with a Orange Slick, and a Hacker 30-12XL. I have 4s 3000 TGY Nano packs for batterys.
The kit came with 4 white stand offs. I didn't see anything in the directions, or build vids about them, but when mounting the cowel it seems to be set deep on the fuse as if I should install the stand offs. What gives??
Also, where does the Laser cut RX plate mount ? I'm using FASST.
Thanks!
2-Stroke Freak is offline Find More Posts by 2-Stroke Freak
Old Apr 05, 2011, 09:42 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
congrats, with that motor you don't need the stand offs. the plane is for the rx if you need it. that's up to you.
great plane!
robj is offline Find More Posts by robj
Old Apr 05, 2011, 09:52 PM
Sippin the Koolaid!
Joined Oct 2007
Also, where does the Laser cut RC plate mount ? I'm using FASST.
Thanks!
I just mounted my reciever on the battery tray. All the way at the back by the wing tube.
Old Apr 05, 2011, 10:08 PM
jamesrini is offline
Find More Posts by jamesrini
USA, NJ, West Paterson
Joined Feb 2008
woohooo i just ordered a 51 in orange with the hacker 30 12xl for my bday in a couple of weeks, thanks to the wifey lol
jamesrini is offline Find More Posts by jamesrini
Discussion Need New 3d Plane from Previes gear. NoMercy 3D Flying 2 Jun 06, 2006 04:07 AM
New 3D planes from GWS? assib GWS (Grand Wing Servo) 4 Feb 24, 2005 12:34 AM
Sneak Peak At NEW 3D Plane from Dick Rankin thechosen1one Foamies (Kits) 5 Oct 11, 2004 01:27 PM
New 3D Planes from Fliton LTChip Parkflyers 1 Jun 19, 2003 02:17 PM
New "3D Aircraft" Discussion Group Proposal Tim H. Foamies (Kits) 1 May 02, 2003 09:57 PM
