Corte Madera, CA
Joined Mar 2001
Greg: Check out the GWS Picos. They are around $20 - 22 and the same size as the HS-50s.
n/a Posts
I have both the Viper and the new P-40. Since I changed the motors in my KP fan's
I have two of the stock motors. They fit perfectly in both planes and are rated on 4 cells. Pull feels pretty good but they sure eat through 4 110's in a hurry. think I should try them? I can use 270 cells the weight increase is not so bad because the motors work best on 4 cells. Also has anyone tried the P-40 yet? It's really pretty and is pre painted in the Flying Tigers scheme. Same size as the P-51. What in your opinion's with all the experience you've had, is the best motor to use? Really enjoy flying micro as a break from all the heavy scale and EDF birds. It's fascinating. Always wondered when I kid if one day we would be able to fly models the size of plastic kits. I don't wonder anymore. Steve Neill |
Sure - the P40 is just as easy. I used tilerons on mine with GWD DX motor direct on the P40 prop, CS-10 servos, 6x150mah NiCad, GWS micro receiver. Flew well but I think the stock dihedral kept it from rolling real well. It still flew, but the roll authority was not as goos as it could have been. Add a GWS heatsink to the motor and cut the scoop open for maximum cooling
![]() Have fun! It's a great conversion that looks quite well. Steve |
n/a Posts
Been in RC planes for 16 years, electric only 3, however most of this has been with
sp 400 and up and EDF. I'll run 6-7 cells on the pot but the KP EDF fan's stock motors can only be run on 4 cells or they burn out. Actually the EDF's that I've scratched built use these units and 7 cells seems to be best. 8 cells burns them up pretty fast, there were lots of threads on the KP fans talking about the stock motors. The instructions that come with the fans ask for 4 cells max. with a single fan unit. I just happen to have these motors laying around because I replaced them with DMC motors. Thought they might work on the micro stuff. I was also wondering if the POT 2a would work in these little guys because I have one of these as well. I'm a little new to micro size planes but love them. Steve |
Rochester, NY, USA
Joined Aug 2000
rkissin,
I'm glad to hear that your pavement-seeking plane was only scratched. It reminded me of my 4lb Helio Courier landing last weekend when I hit the top of a parking lot lamp post. You couldn't do it again even if you tried! I'm not familier with your Westek servos. I plan on using HS-55 servos. Have you done the wing undercamber mod. with DEPRON as on Mike's site? |
Corte Madera, CA
Joined Mar 2001
Greg,
If you can, go with the GWS Pico or HS-50 servos, save yourself half a dozen grams. Makes a difference! LS-2.5 servos can be found on David Lewis' site, www.homefly.com. A slightly bigger model, the LS-3.0, is available from Todd Long at www.toddsmodels.com. The LS-2.5s weigh only 2.5 grams compared with 5.9 grams for the Pico/HS-50s and 7.8 grams or thereabouts for the HS-55s. Haven't tried the undercamber mod, waiting for new inventory to arrive (i.e., more planes to play with). |
Rochester, NY, USA
Joined Aug 2000
SteveM,
Are you using the stock batteries in your Viper or did you replace them? rkissin, That price looks better, thanks! I'll check out Balsa Products for them. I keep ordering those GWS R4P receivers from them for $28. I'm still getting used to the HS-55s on my last two projects. Going smaller is very cool! I just finished my mini-Zagi and started my Acro Champion from Hobby Lobby this morning. The Viper is next on my list after that. This micro-flight aspect of R/C is addicting! |
Corte Madera, CA
Joined Mar 2001
Postie just deliver an order of GWS props including a 4.5x4 that's just slightly larger but with greater pitch than the Viper prop (which I'd guess is a 4x3). It can also easily be reamed out to accomodate the pinion on the GWS motor. I'm going to have to give this a try...
| Thread Tools | |
| Flaps and spoilerons one more time | davidleitch | Electric Sailplanes | 14 | May 04, 2006 06:48 AM |
| One more time before Ebay: Tricked out Housefly. | Jim McPherson | Aircraft - Electric - Airplanes (FS/W) | 4 | Jan 29, 2003 06:39 AM |
| One more time-GWS Beaver dihedral ? | Tom Smith | Parkflyers | 4 | Oct 25, 2002 10:37 PM |
| One more time: Should I upgrade to CP to learn? | Spaulding | Electric Heli Talk | 4 | Feb 19, 2002 10:29 AM |
| Calculating Incidence, one more time | MtnGoat | Power Systems | 4 | Sep 19, 2001 04:58 PM |
