Plans should be downloadable from Slofly.com http://slofly.com/index.php?smit=135 |
Latest blog entry: Quick Stick
Oakland/Berkeley CA
Joined Oct 2007
The acromaster will break, but it is also easy to fix.
I have tried the EPP Revolution 3D- it is definately crash resistant, but I did not like how it flies. http://www.rcgroups.com/forums/showthread.php?t=541910 It kind of felt like I was flying a wet rag I much prefer the Flash 3D- not quite as robust, but a much better flyer. http://www.rcgroups.com/forums/showt...light=Flash+3d It can also act like a sloppy pattern plane- that is it can handle speed, which is why I like flying it. I have repaired the flash with strapping tape numerous times. It is at the point now where it is a little too heavy. I will probably get another, since I liked it so much. |
Try the Parkzone Typhoon. It's EPP foam, very stable, and has lots of power (hovers well). Very crash resistant and easy to fix if you do break something. Gorilla glue and you're good.
http://www.horizonhobby.com/Products...ProdID=PKZ4300 The only caveat is that the supplied ESC is reported to be dicey, (some instances of out-of-box failures). There is a PNP version available too. I love mine. |
You might take a look at the Mountain Models Panic 3D. Made of EPS/Depron. Looks very tough. Check out the video under the "Images" tab. It has some crashes at the end to show the durability.
http://www.mountainmodels.com/produc...roducts_id=234 Here is a link to a thread here on the Panic 3D: http://www.rcgroups.com/forums/showt...77#post3357577 Regards, Gary |
Ken |
Thanks anyway. I'll try somemore later. Ray |
You really need a balsa or depron plane with a glass motor mount.
Do not use EPP because it is too floppy like a nerf ball and it if it rains the wings will droop. Do not use a prop saver because a rubber band holding a prop on can kill someone when it comes loose. Make sure your batteries are over 600mah in size so that the nose impacts will break the motor. Make sure to use nicad because the new lipolys are a fire hazard and wrapped in cellophane that can leak toxic chemicals on your hands. When lightly poked they have shot thousand degree flames out. Do not use outrunners because they are less efficient and have less torque than a geared setup. The friction in the gears is very little and you get used to the noise. EPP will never offer the rigity of depron, balsa or fiberglass or kitchen glass. Do not try to replicate what old timers have worked years on by trying to get away with EPP of any form combined with usage of carbon rods, tubes and flat carbon. If have built hundreds of EPP planes from IFO style to square sheets to 3D planes and none compare to the most simple out of the box balsa or depron plane. In fact most crashes resulted in the EPP plane tearing or sun melting it in the car while the balsa planes stand up to crash after crash. Keeping the plane under 6oz is a bad idea because the lighter they are the lighter they fall. Also the lighter it is the more of a thrust to weight ratio you get and that means faster vertical, less throttle to hover and longer battery life each flight. Beware of fads. There was a lot of resistance to EPP, building techniques and 3D mock ups of built up fuselages using EPP. This is just an attempt to get you to buy a toxic substance which is made for car bumpers. Some planes to you need to beware of: The Blade The Slofly Series The IFO and things shapes like it- one is the Bug I am reviewing this plane: Airworks Silent 3D EPP http://www.slofly.com/index.php?smit=299&mid=2942 They sent it in the mail to me. Just wait till I post how soft these wings and fuse are and when you see the wings flip up and down at 3mph you will know that this EPP is just a fad created by brainwashing advertisers who want to make a buck selling empty airspace. |
| Thread Tools | |
| New Product Magic Butterfly, 3D-Trainer, Crash proof! | AUSTARSMODEL | 3D Flying | 0 | Nov 09, 2007 08:35 AM |
| Discussion What is the most crash proof 3D plane? | Dave K | 3D Flying | 14 | May 21, 2006 09:03 AM |
| T3D CAP 5oz. Indoor/outdoor 3D trainer | hsuusa | Parkflyers | 529 | Sep 16, 2003 04:13 PM |
| It is simply a Kick-aRound 3D trainer! | KonstantKrash | Parkflyers | 22 | Jun 14, 2003 06:44 PM |
| list of most crash restistant models | quietfly | Electric Plane Talk | 21 | Sep 18, 2001 07:50 PM |
