Old Apr 29, 2008, 05:25 AM
Peterfly is offline
Find More Posts by Peterfly
Peterfly's Avatar
Joined Mar 2006
Please consider, can this apply for micro brusshless motor?
http://www.utc-ic.com/spec/UH276.pdf
It's easily found in cooling fan of PC equipment.
Peterfly is offline Find More Posts by Peterfly
Old May 04, 2008, 11:18 AM
Pgarrett is offline
Find More Posts by Pgarrett
Joined May 2004
Peterfly
I may be wrong but I can see it being used in a 2-coil setup where it could alternately switch the current from one coil to the other and thus double the power stroke per shaft revolution using the present 2 phase 180 degree magnet that we are now using.
Paul
Pgarrett is offline Find More Posts by Pgarrett
Old May 07, 2008, 10:36 AM
Peterfly is offline
Peterfly's Avatar
Joined Mar 2006
Thank you for replying. Today, I test it by using original board form PC's cooling fan. It comprised with that IC, 1 capacitor and 1 diode.
The original board use 12 V power but I test with Lipo 1 cell. The coil and magnet, I used, from 6 mm pager motor. The result is it only huanting, maybe cuased by the 2 coils from pager motor is 120 degree or by the value of capacitor not matched, I'll check the data sheet.
Discussion Can this be for real? Dragonfish Micro Helis 8 Jul 16, 2007 11:40 PM
Question Please help identify this seaplane for me pbjones81 Fuel Plane Talk 2 Jan 18, 2007 01:17 PM
Discussion Please fill in this questionaiire for school gcse project- will only take a minuter flumpy20032000 Chit Chat 5 Jun 05, 2006 05:23 PM
Is this good for a 400 motor corey Power Systems 7 May 15, 2004 08:34 AM
How would this be for a airplane motor? Mike Hall Power Systems 7 Jul 25, 2002 03:20 PM
