| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 | ||||||||||||
Wow That's Cool!
X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2
With the Poll - X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion hitting over 2,500+ posts ... I think it is time to split the thread group again ...
Part 1 showcased the X-3D Brushless Quadrocopter and this thread should continue on as a support thread of discussion . See below for the recap. There is a planned successor to the X-3D gyro board to be available soon ... info here ... http://www.asctec.de/main/index.php?...g=en&cat=hobby Some interested parties have asked "how much soldering is involved with this kit"? Quote:
Wealth of Quadrocopter/Tricopter Info links This discussion is not limited to the X-3D Brushless Quadrocopter, but also should include anything X-UFO, X-Tuning, or Quadrocopter (or even Tri-Copter) related ... so continue on with these topics of general discussion as well. Jump To Thread Links (Table of Contents ... work in progress) Here are some pics of jimcking's El Tape/Wire mod ... http://www.rcgroups.com/forums/showp...&postcount=892 and http://www.rcgroups.com/forums/showp...&postcount=941 and http://www.rcgroups.com/forums/showp...&postcount=993 Recommendations for X software loading sequence and Part 2 and Part 3 Latest X Software Update Source Lipo C Rating explained FlyCam2 V2 info Hacker Motor info 2.4 Ghz Fasst mod OMM Jim's take on the different Quadros more to come ... Khaled X-CSM Arm Repair Procedure Guidoco X-CSM arm fix mod Damon's FunPilot Review Berg 4L Manual for Failsafe setup X-3D BL LED Support Explained Happy Flying ... --Eric-- <my landing strut + NAV mods > Here's a recap from Part 1... Quote:
#2 |
It definably feels allot more stable and responsive and the sound of the props minus the brushed gears is awesome. Even with the quick stock frame mod it came out the hole level and strait.. I dont really see a dramatic power increase tho, or it seems it doesn't accelerate that much faster. I hope this is because its been in acc mod. Or maybe even a dying lipo pack, Iv been using the same one since day 1 and its starting to get a little puffy. Ill change up the acc1 to hh1 and see what results that gives. I noticed this with the brushed motors allso, Cant remember if it i noticed it befor or after the installation of the acc board.▲▲
#3 | |
Wow That's Cool!
--Eric-- |
#4 | |
I used the data cables from digi-key, they were about a half inch shorter than the one that came from the shop but they seem to work fine. the wires snap into the connectors easly no cremping needed.All so, one of the motors doesnt spin as freely as the other 3. Not sure what to make of it. Doesnt seem to affect the controll of the quad, but im wondering if that mite have something to do with the acceleration drag i think i got. Maybe the controllors make the motors rev up only as fast as its slowest motor to maintain controll? I got a new spar. I may swap it out. Ill post some pics tomarrow. Thxs for all the help guys, I like it!
#5 | |
Wow That's Cool!
... forgot to say nice pics in the prev thread ... --Eric-- |
#6 | |
quadrocopter pilot
The X-Base uses what's called DTC (Dynamic Thrust Control) which essentially limits your power output to all motors in effort to match the limits of the weakest motor in the bunch. This is what makes flight more stable than the Chinese mobo, but also you suffer a performance penalty if one of your motors is underachieving. There is a good chance this is what you are experiencing, as you should see a sizable increase in power going from brushed to brushless.
One other thing to make note of is that I definitely noticed that it took more stick to get get into the air than with the brushed setup. This was because the brushless software was made with a linear throttle curve whereas the brushed version used a parabolic curve making it seem as if it took off with less power. On the high end of the stick however, you should see a sizable difference in static thrust skewed towards the brushless setup. With the brushed software, you'd get quicker response off the line, but the top end was much weaker. The sound of the BL is awesome, isn't it? ![]() Damon Quote:
#7 |
@Chessman21 ... this is really very good news ...can't wait for the photos showing how you modified your frame to accommodate the motors ...
![]() @saturnine .... DTC Dynamic Thrust Control .... this is way cool... if I knew this from the beginning I would have switched to the X-base from day 1 .. it would have added few hours to the lifespan of my 1st set of brushed motors ![]() Thanks Khaled |
#8 |
I wonder if the updates released by the Jast and his crew at the German forum for fixing some issues are put in place in the software section at www.asctec.de or I have to hunt for them in the thread ....because it seems that the latest update is very essential
Thank you all ...
#9 | |
Kahled,
Jast is putting it in the Xtuning thread. Here: http://forum.xufo.net/bb/viewtopic.php?t=9006 There is still no update package for the XBL with ACC. Cheers, Jim Quote:
#10 |
Thank you very much , Jim
is there any sequence I should follow when updating the X-3d , X-base , X-BL .. to get it updated right ?? Thank you Khaled |
#11 | |
Khaled,
My recommendations that have worked well for me: 1. Load the X3d [*.ufc] firmware first (it can be attached to the x-base or not at this point) After removing the bootloader pin and rebooting, load the parameters [*.ini] that you desire in each 1-4 window (i.e., beginner or VACC, or advanced, etc.; if you have an ACC module, then make sure the ACC parameters are in the ACC 2 and 4 positions, Hint: the ACC parms will have an PITCH/ROLL/height_d angle of "0") note: The gyro data stream on an x3d loaded with xbase firmware will not work unless the x3d is mounted on the xbase and power is on. 2. Load the X-Base firmware [*.xbs]. After flashing the firmware, remove the bootloader pin from the xbase and reboot. Then cal your TX and ACC if you have one. Check the motors for the proper position on the arms and that they are turning in the proper direction. Adjust by dragging from the right window to the arms of the graphic if required. The first time you drag to arms that have ESC's assigned, it will clear two arms. Then drag it again to the proper arm and both cleared arms will be filled with the correct ESC address. 3. Load the XBL firmware if required [*.blc]. Make sure you don't have the boot loader jumper on the X-base or X-3d when doing the XBL firmware (ESC) flashing. Be sure to select all on the left window that you want to reload. This can be finicky. If it can not find the motors/ESC's when you first do the search, first close the X-control app, then cycle the power off/on on the quad, and try again. If it still can't find them, remove 3 of the four black/blue I2c wires and cycle power back to on and try again. If you load the "music" you may or may not get a "finished" prompt. It loads these very quickly, so just cycle power on the quad and you will see that it has flashed the music anyway. Note: The X-Control is "usually" pretty good about telling you what to do next, or what the problem is. Make sure you read it closely when you do an action and do read the processor response window at the bottom. The common mistake most folks make is to forget to click the correct tab when doing a firmware or parameter update. Not clicking on the proper tab will get you the "not connected" or "can't find" response. Just click on the right tab and you will be back in business Hope that helps! Cheers, Jim Quote:
#12 |
Jim ,,,,thank you very much for the detailed answer ... I guess I will copy your post and save it in a text file for future reference ....
#13 |
Heres a few pics, I havent done any agressive flying, this is basicaly just a tester, the motor is bolted onto a plate thats "hot glued" to the stock motor holder seems to hold but i dont trust it !00%, I dremeled the suport shafts off the props and hot glued them inplace to catch the 2 of the four grooves that are made onto the rear shaft adaptor that came with the motors. And why are we waiting for new or beter software for the acc/bl config? Whats it not doing now that it could do? Seems like it flys like the brushed acc setup to me.
#14 | |
Wow That's Cool!
Looks like a good mod ... but switching from brushed to brushless, you should be noticing more power than you are seeing ... was thinking of using something (maybe CF plate) like that to extend the distance on the X-CSM arms to accommodate the bigger Hacker style 20-22Ls and larger 10X4.5" props. moti is using those hackers on his brushless DF ... http://www.rcgroups.com/forums/showp...postcount=1418 --Eric-- |
#15 | |
Question: About this 3-4 times the power, i changed out the motor that didn't spin as freely as the others and I didn't really tell a differ in the acceleration. My battery pack is a 1050mah "12c continuous 20c in short burst" and i have hh1 loaded with the "beginner" setting. Think either one of these scenarios may be the reason i don't see the dramatic power increase?
| Thread Tools | |
| Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion | tend2it | Multi Rotor Helis | 2529 | Apr 26, 2008 08:45 PM |
| Discussion X Ufo 3d | idtoto2001 | Coaxial Helicopters | 2 | Oct 11, 2007 02:41 AM |
| Discussion Silverlit X-UFO (w/X-3D Piezo Gyro Upgrade pt 2) and BL UFO Upgrade | tend2it | Multi Rotor Helis | 1026 | May 19, 2007 02:25 PM |
| Discussion Silverlit X-UFO (w/X-3D Piezo Gyro Upgrade) | tend2it | Multi Rotor Helis | 1024 | Mar 31, 2007 12:50 AM |
