Old Apr 25, 2008, 11:29 AM
Cdr.Instigator is offline
Find More Posts by Cdr.Instigator
Tom Bass Park RC Nonconformist
Cdr.Instigator's Avatar
USA, TX, Houston
Joined Dec 2007
Glassing Dollar Tree Foam Board?
I recently started a Light Mod 22" P51 Foamy with no paper skin. I removed all the paper covering and made the fuse out of 4 Ply of this foam. The wings are 2 Ply of this foam too, with air foiled wings to boot. Now, I did noticed that now that I have done 1/2 of the build.. the foam is very soft and easily scored by almost anything.
I ordered some .75 glassing cloth from this place
http://www.thayercraft.com/Style%20106.htm
@ $14.00 for it I couldn't pass on the price. Has anyone ever glassed a foamy this small before? Would it even be worth it? Might be able to last a little longer than having nothing at all to protect it from the inevitable bad landing or wing to ground contact..
I tried to do a search on the subject but, found little to no real answers.. Any input would be greatly appreciated..
I will post pictures of the 51 later tonight.. There are no plans at this point, but will post the name from which plans I got the idea from...but did no follow for the most part.. The original plan called for ribbed wings and compartmented fuse etc.. I just traced the outline and started with a profile Foamy.. ended up with a 1/2 full fuse... Go figure !!!
Cdr.Instigator is offline Find More Posts by Cdr.Instigator
Old Apr 25, 2008, 11:43 AM
smkn951 is offline
Find More Posts by smkn951
smkn951's Avatar
United States, HI, Kapolei
Joined Jan 2007
CI, i'm really looking forward to see the pics and see how it turns out.
i have been curious for awhile but, since i have never glassed anything before i am afraid that i'll do it wrong and waste some $$.
goodluck, hoping everything turns out great.
smkn951 is offline Find More Posts by smkn951
Old Apr 25, 2008, 12:08 PM
DRITCH is offline
Find More Posts by DRITCH
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
Haven't glassed, but had good luck on foam using Water based polyurethane spray and tissure paper. The colored paper is great.
DRITCH is offline Find More Posts by DRITCH
Old Apr 26, 2008, 04:32 AM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I am also interested in this idea. Never done a plane this way before.
Dritch... Does the tissue material add a bit of surface hardness? I must assume fiberglass will be stronger, yet heavier, but how does the tissue hold up?
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Apr 26, 2008, 03:40 PM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Try this thread, J Morgan is very respected in the pusher Prop section as well in the Warbird area. If J morgan says it I belive him!
http://www.rcgroups.com/forums/showt...hreadid=161218
Also Corsair Nut , another well respected Builder in the various Jet Forums is using Elmers Woodworking glue thinned with water and says it comes out " wicked Light"
RWCLOUD is offline Find More Posts by RWCLOUD
Old Apr 26, 2008, 04:23 PM
USA, TX, Houston
Joined Dec 2007
OMG !!
The mother of all info I needed.. Thank you very much RWCloud. That's the thread and all the info I needed..
Old Apr 26, 2008, 09:29 PM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
You're welcom
Foam board is a pain Skysailor Parkflyers 8 Oct 23, 2008 05:47 AM
Question dollar store foam board crtaylor Foamies (Scratchbuilt) 16 Mar 10, 2008 08:38 PM
Something I Dreamed up for Foam Board or Sheet d_trafalgar Foamies (Kits) 11 Feb 17, 2002 08:14 PM
$4 R/C Plane - PAP-E Foam Board Model ZAGIZAGI Parkflyers 3 Jan 23, 2002 01:46 PM
A Lil Hornet like foam board flyer. poobs Parkflyers 14 Oct 16, 2001 11:08 PM
