Old Jun 01, 2001, 04:50 AM
Tyson is offline
Find More Posts by Tyson
Mie oo Karjala poikii
Tyson's Avatar
Ruokolahti, Finland
Joined Apr 2001
Speed 280BB - direct drive or not?
My Pfalz somehow managed to hit a rock and now I've got a Simprop Speed 280BB with a broken 5:1 gearbox. According to my knowledge, Speed 280BB needs a gearbox to be effective and is not very good as direct drive.
I would like to know if someone has got experiences (good or bad) from direct drive Speed 280BB? Which prop/batterypack to use, etc.? Or should I forget the idea and buy new gearbox instead?
Thanks in advance!
-=Mike=-
Tyson is offline Find More Posts by Tyson
Old Jun 01, 2001, 06:06 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I'm "using" one in a DMA flea, direct, with the Graupner 4.7x2.25 folder. No flights, or even a final choice on cell count, yet.. Thinking 7 cells..
..a
Old Jun 01, 2001, 07:31 AM
Jim Ward is offline
Find More Posts by Jim Ward
L.L. N.M. U.S.A.
Joined Apr 2001
Tyson:
I am flying my Flea with the 280BB using 7/600ae's,Grapuner 4.7x 4.7. Don't have all the tech. stuff to ck. amps. etc. But can say
it flys for about 6min. with some throttle mgmt. and is not too hot after flight, I don't think you could pull a big slow fly prop without the gear box. Appels & Oranges!
Andy are you EVER going to finish that Flea?
Jim Ward is offline Find More Posts by Jim Ward
Old Jun 01, 2001, 07:59 AM
Dr. Jet is offline
Find More Posts by Dr. Jet
H301 Libelle Pilot
Dr. Jet's Avatar
Oceanside, California
Joined Sep 2000
Andy,
Are you ever going to finish and fly those Fleas?
Dr. Jet is offline Find More Posts by Dr. Jet
Old Jun 01, 2001, 08:26 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Tyson
I've used Speed 280BBs without gearboxes, but they're kind of marginal. The problem is that a Speed 400 weighs only an ounce more by the time that you come up with a 7 cell 600 AE pack. The motor actually does fine on 8 cells too, but doesn't match the power output of a Speed 400.
I've also tried Speed 280BBs on either an 8 cell 720 NiMH pack and 7 cell 350s. In both cases, the airplane flew, but it was always a little lacking in zip. I think the right batteries are the Panasonic 650 mAH NiMH cells (8 maybe 9 cells?) which handle more current than the 720 NiMH cells.
Realistically though, on the same batteries and propped appropriately, an Astro 010 is a better choice direct drive. On the other hand, I've got 3 of the Speed 280BBs geared (MTM wasps) and they work very well. I'm scratching my head as to why gear the Astro motor when this combo is available.
Sam Brauer
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Jun 01, 2001, 10:55 AM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
A plane like the Flea is about the only thing out there that the 280BB will work well in as direct drive. The Flea is sort of a mini pylon racer and since it has such low drag and goes fast the 280BB can use a small prop that will let it spin at high RPM.
The 280BB is only efficient at higher RPMs so it really needs gearing to be effective. I have a mini X250 (70% scaledown) that I use a 280BB in with 4:1 Horst gearbox and 8x720mah NiMH cells. Even this plane is pretty fast and turns a 7x7 speed prop.
In another plane, a Guillows SE5A Biplane which is a conversion from the rubber powered kit, I run a 280BB on a 4.4:1 box but with a 9x6 slowflyer prop. In this case its only on 7 of the NiMH cells.
In my 1/16 scale P-38 Lightning I'll be running twin 280BBs with 5:1 gearing to turn 3 bladed 9x7 props.
Don't even try to fly your Pfalz with the motor direct drive. At best it won't fly, at worst you'll put too much prop on it and burn up the motor. Just get a new gearbox, you'll be needing it for most anything else you want to use the motor in if not the Pfalz.
Gerald is offline Find More Posts by Gerald
Old Jun 02, 2001, 04:01 AM
Tyson is offline
Tyson's Avatar
Ruokolahti, Finland
Joined Apr 2001
Originally posted by Gerald:
Don't even try to fly your Pfalz with the motor direct drive. At best it won't fly, at worst you'll put too much prop on it and burn up the motor. Just get a new gearbox, you'll be needing it for most anything else you want to use the motor in if not the Pfalz. [/B]
I was thinking about using it in my scratch built 'pylon racer'-style plane (I did not even think to use it in Pfalz).
Maybe I should just try it. It's the only way to find out whether it's suitable or not. Do you think 5x3 prop would be too large?
-=Mike=-
Old Jun 02, 2001, 03:28 PM
Gerald is offline
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
A 5x3 will work but I don't know of any that size except the Cox prop. The Graupner 4.7x2.4 Cam folder that Andy W. mentioned works well, I've seen the flea fly with this prop. 7 600AE nicad cells is about the limit for direct drive with that prop. You should keep the max current below 8 amps. For all-out top speed the Cam 4.7x4.7 speed prop will draw about 8.6 amps static on 6 of the nicads.
[This message has been edited by Gerald (edited 06-02-2001).]
Old Jun 04, 2001, 05:59 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I just posted on this subject in the slow flyers area. I'm currently using a 280BB direct drive with the CAM 4.7x2.3 folder and 6x500AR. Static current draw is about 9.4A, I get 6 min aerobatic flights (using throttle) in an o/d 28" span model, AUW approx. 12 oz. Have also used 7x720 nimh, current draw was a lot lower (about 7.4A), flight time about 8 mins.
Bill Glover is online now Find More Posts by Bill Glover
Old Jun 04, 2001, 06:12 AM
Tyson is offline
Tyson's Avatar
Ruokolahti, Finland
Joined Apr 2001
Thanks a lot guys!
I'll try with the CAM 4.7x2.3 folder and 6x500AR and 7x600AE packs.
-=Mike=-
Speed 300 Direct Drive Slow/Fast Flyer? Dave Hederich Electric Plane Talk 15 Jul 27, 2001 04:57 PM
gear drive or not? sms Parkflyers 4 Jul 12, 2001 02:11 PM
How this happened ? Speed 400 Direct Drive System jnyoun High Performance 2 Jun 04, 2001 04:43 PM
