Old Apr 25, 2008, 07:39 AM
Robse is offline
Find More Posts by Robse
Denmark, Europe
Joined Jul 2007
Help!
Hull-making, resin and fiber..
Hi guys. :-)
I have almost completed the plug for a mold for my 1:220 scale model of Emma Maersk. Now (Well, real soon) I need to put wax (?) on the plug, and then cover it in a thick layer of glassfiber. This way I should get an inverted version of the hull; a mold. In this, I can make hull after hull. (I hope)
However.. Do I just apply mold-wax (Seen in shop selling different things for boat repair) to my hull (or call it 'plug') and then put layer after layer of resin and cloth on top of that? I need to be "pretty sure" that the two parts do come apart once the resin cures.. :-O Any tips, idears or warnings? Anything welcome..
Thank you in advance, guys. :-)
Robse is offline Find More Posts by Robse
Old Apr 25, 2008, 07:56 AM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
Robse. Go to the http://www.fiberlay.com/ site and they have the tutorial for mold making and materials to use. It is a great help and will take you through the whole process. Jerry J.
jerryj98501 is offline Find More Posts by jerryj98501
Old Apr 25, 2008, 12:25 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
After you wax (and polish, and wax, and polish) the plug (what you made), you apply PVA (polyvinyl acetate - aka "white glue") BEFORE you apply resin and fiber to make the mold.
A little googling will provide you with many references, likely even quite a few in your native tongue.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Apr 25, 2008, 01:16 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Robse, If you work carefully and follow instructions, you can make a mold with very little trouble.
First, apply several coats of wax to your master, polishing between coats.
Next, mount the master to a sheet of plywood, or sheets, if there are several decks.
Once mounted, spray on several coats of PVA (polyvinyl acetate, (also known as polyvinyl alcohol) allowing to dry between coats. A hair dryer or heat gun helps in accelerating the drying.
Apply the gelcoat or tooling resin, whichever you're using, and allow to cure. Allow the gelcoat to overlap onto the mounting base. This will form a flange to reinforce the edge of the mold. I always put on two coats.
Once this has cured, you are ready to begin building up the layers of fiberglass to make the mold. I prefer using mat rather than cloth, as it conforms to the surface better.
Attached are some umages of the process.
(for some reason these did not come up in order)
der kapitan is offline Find More Posts by der kapitan
Old Apr 26, 2008, 05:55 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
When managing the attachments, you can give the pictures numbers in order to make them appear in the order you want.
Nice molds BTW!
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Apr 26, 2008, 07:38 AM
Joined Jun 2005
Nice molds BTW!
Regards, Jan.
Jan, I did number them, and added annotations to each image, but all this disappeared in the process of getting them up on the screen.
Perhaps electronic gremlins?
Old Apr 26, 2008, 08:27 AM
graphixman is offline
Find More Posts by graphixman
ΜΟΛΩΝ ΛΑΒΕ
graphixman's Avatar
Coastal Maine
Joined Jun 2007
Trust Der Kapitan on fiberglass molds, and hulls. I have one, and seen many others. They are first rate and he knows what he is doing.
Cheers
p.s. Kapitan, what is the hull you have the photos of just a couple posts ago? I like her lines.
graphixman is offline Find More Posts by graphixman
Old Apr 26, 2008, 01:53 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Originally Posted by graphixman
...They are first rate and he knows what he is doing.
Having a few of his hulls, I agree completely!!!
Aerominded is offline Find More Posts by Aerominded
Old Apr 26, 2008, 01:54 PM
Joined Jun 2005
Graphixman, that is a 110' WWII subchaser, for which you can find the details listed on my website.
Old Apr 26, 2008, 01:58 PM
Joined Jun 2005
Aw shucks, Aero---.
Flattery will get you everywhere---.
Old Apr 28, 2008, 01:16 AM
Robse is offline
Denmark, Europe
Joined Jul 2007
Hi guys :-)
Thanks for all your replys :-)
One question though: Do you guys use epoxy or the smelly stuff.. polyester?
I plan to use epoxy (West systems) cause I know this from building my sub. (One-off, no mold.)
Sincerely,
Robert.
www.robse.dk
Old Apr 28, 2008, 01:29 AM
Sneek, Netherlands.
Joined May 2004
Epoxy.
Regards, Jan.
Old Apr 28, 2008, 07:21 AM
Joined Jun 2005
Robse, I use polyester rather than epoxy, as it's less costly, and for commercial work, one must stay within a budget. Also, from my experience, polyester cures faster.
A well-ventilated workshop is a must, however---.
Old Apr 28, 2008, 06:31 PM
pops52 is offline
Find More Posts by pops52
pops52's Avatar
United States, OH, Richfield
Joined Aug 2007
Excellent site Robse! Just spent the better part of an hour enjoying your Ohio.
pops52 is offline Find More Posts by pops52
Old Apr 29, 2008, 07:02 AM
Robse is offline
Denmark, Europe
Joined Jul 2007
Thanks, Pops. :-) Please notice, that the site will be updated shortly, as I'm currently rebuilding the inside modules to be quite simpler. :-)
-and yes, polyester DOES smell a lot, but isn't it havier too?
Sincerely, Robert :-)
Submarine freak that went topside...
Depron + (Resin + Glass fiber) = ? hate Foamies (Kits) 1 Jul 03, 2005 11:37 PM
