Personally I have 2 reasons why I purchased an Inverter Generator over the traditional design. First the noise level is important, these generators operate at normal conversation levels because they can throttle down and only provide what's required. Second is the clean power though I am pretty sure I could charge off most regular generators. They are more expensive but I can't imagine it going over well at an electric-only event like SEFF (next week!) for folks to crank up the cheap (and loud) generators that most folks own for home use. So for that reason primarily, I decided to go quiet and at the same time benefit from power meant to run computer-type equipment. As for running a PS from an inverter, unless the power is coming from a generator, I don't see the point. To convert the DC to AC back to DC again seems pointless plus there is no advantage gained from a power POV since watts are watts. In the end your just losing some available watts from the conversion process back and forth. If you have a 12-volt power source, why not just run your charger(s) from that? Jack |
The MasTech 5020 is my charger and runs off 120VAC.
No problem at my home field; when away from AC I plan to use a power Inverter off my idling Explorer. The MasTech charges the A123-10S2P pack in my ECQ (electric converted 1/4 Cub) @ 20amps (36volts). This is 1:1! Fly for 10 minutes and its recharged in 10 minutes! So my need is for AC 1st. My other planes use A123s too: 1/5 -- 5S2P & FreeStyle 6S. |
This is all getting to be a problem--if I want under 10 min charge times . |
Zip by 3s! A freind is doing a 12S plane as two 6s, zipping with two Pbs in series. MasTech, of AC, Inverter, or generator. Another friend say just be done Jim, get a Honda geneartor. Dapters N chargers. use my 1010C and or Dapter too. |
Zip charging : well I Zip charge a 3S A123 at 25 to 30 amps. start and 20 amp. average from two 12v dep cycles in parallel.(250 Ah) and also run other chargers from them. My 3S A123 is charged at over 200 watts average. Some are Zip charging 3S8P (24 cells) at over 50 amps. or approx. 550 watts. FYI I often pull over a 50 amp. (600 watts) load from my deep cycles. Charles |
You can certainly get the same wattage from very high end computer power supplies. So obviously the amps are there. The voltage however would need to be doubled up or something.You're going to pay something nasty for such a regulated power supply at those levels. http://www.surplussales.com/PowerSupplies/PowerS-5.html or http://new.tanicpacks.com/index.php?cPath=76_53 |
I am not familiar with this generator inverter solution have you a link to the one you bough or similar spec type For the original question is there eneogh headroom on 1000wat output and 400 watts consumption the probable answer is most likely but conversion rates with generator power output and inverter losses can be as high as 25% losses or more...if the quality of the electronics components is low and they are under high load factors I am using a run of the mill $50 inverter 12v to 110v / 220V to run my laptop with a car 12 volt solution with the car engine running with no ill affects from spikes etc Inverter is 150 watts and laptop demands 100 watts at 220 volts as the laptops battery is broken My experience of Generators is they are often over stating their specs and you typicaly find a ~1000w is only ~800watt in continuous load and ~1000watt is short time peak loads such as ~1000 hand drill machine making holes with rests in between The cheaper crud made in China ~1000 watts generators can be as low as ~600watts continuous Also my guess is that most run of the mill petrol generators will with direct plug in 110v chargers will work without smothers or inverters whatever if the generators automatic speed up system is overridden and the gas is jammed at full speed as its the surge load pick up time that causes the equipment the most problems running on low voltages Ok that will make more noise My preference if I was going that direction is to get a cheaper 2kw generator( some can be had for $500 new ) and run a long lead say 100feet to the place of charging The bigger 2kw generator wont be so affected with 400 watts demands and it will run at lower quieter speeds but will be a bit heavier to lift and use a tad more fuel A few simple cheap capacitors will make a fairly effective smother for those nervous of spikes for their chargers Other solutions would be to run 110v battery chargers like 10 amp types direct onto normal deep cycle batteries and then use 12 volt type chargers to charge the model planes cells and the battery will act as a smoothing circuit This would be my own preferred solution I will opt to use Its lighter simpler and cheaper and can be used to run several zip chargers for A123 packs or similar solutions Others might use the 1kw or 2Kw AC 110v generator's with computer power supplies which do 13.5 volts to the charging I agree with your solution as being probably most secure but it sounds pricey what did you pay for it roughly Others might prefer cheaper easier solutions so I outline them as possible alternatives Ralf |
Here is the link to the one I got, it was a toss up between the Honda and the Yamaha. There is another reason I got this one, portability. It weighs only 27 pounds dry, that's easy to haul around and get in and out of the SUV. The noise really sold it though, 52dB is normal conversation. Yamaha EF1000ISC Inverter Generator Jack |
| Thread Tools | |
| How many amps can Deans Ultraplugs/Sermos connectors take?? | Jason M | Electric Plane Talk | 13 | Jul 30, 2006 10:59 AM |
| How many amps can a cp1700 handle? | Grimlok75 | Power Systems | 10 | Mar 21, 2002 10:36 AM |
| How Many Amps can an Aveox 1010/4y Take | martin johnson | Electric Plane Talk | 2 | Feb 18, 2002 09:58 PM |
| How many amps can different batteries take? | squelchF18 | Electric Plane Talk | 3 | Dec 26, 2001 06:58 PM |
| How many amps can I pull from Sanyo 1400 ae's? | slowflyer | Power Systems | 9 | Jun 01, 2001 12:30 AM |
