Old Jan 13, 2003, 11:32 PM
Ian Easton is offline
Find More Posts by Ian Easton
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
Can you help identify this sailplane?
My son won this electric sailplane at our club xmas raffle. It was in a pretty scabby state when we got it but he stripped it all down, recovered it and repainted it. The problem is we don't know what plane this is and it would help us find out more about it if we knew what it was. Any suggestions?
Specs
Span 60"
Chord 8" at root, 5.5 " at tip
Tip flares up
Slight dihedral , wings have ailerons.
Wing area 405 sq in = 2.81 sq ft
Length 39"
Weight with a 480 and 7 cell 600 pack is 39ozs
Wing loading 13.9 oz/sq ft
Prop 6 x 3 graupner folder.
Jeti 180 speed controller
Apart from what model is this, will this motor power combination work? Should I go to 8 cells?
Ian Easton is offline Find More Posts by Ian Easton
Old Jan 13, 2003, 11:34 PM
Ian Easton's Avatar
Joined May 1999
Profile view
The fin and rudder was actually squared off, but we rounded them to clean up the bad bits and to make it look better.
Old Jan 13, 2003, 11:49 PM
Ian Easton's Avatar
Joined May 1999
Note to self
Time to redo tile grout
Ian
Old Jan 14, 2003, 12:04 AM
Peter Boyd is offline
Find More Posts by Peter Boyd
New South Wales, Australia
Joined Aug 2002
Ian,
I'm not sure about the plane but can I come to your next Christmas party? We only get c**p!
Pete.
Peter Boyd is offline Find More Posts by Peter Boyd
Old Jan 14, 2003, 12:38 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I think I've seen something similar at the field near me. Could it be a Wendy with modified wing?
Up&Away is offline Find More Posts by Up&Away
Old Jan 14, 2003, 12:43 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Here she is... From NESail.
On second thought, no it's not a Wendy. Wings are straight and un-tapered, tail surface is rounded... sorry
Old Jan 14, 2003, 02:25 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
If the fuselage is plastic, it could be something from Graupner or Robbe. Look into Hobby Lobby International and see if you get a match.
With the 480, 8 cell is OK, but the Jeti 180 might not able to handle the high current draw.
Brian
bhchan is offline Find More Posts by bhchan
Old Jan 14, 2003, 06:04 AM
vario is offline
Find More Posts by vario
large member
vario's Avatar
beside the highway market
Joined Jan 2003
wendy
sure looks like a wendy fuse to me ,maybe with a differant wing
vario
vario is offline Find More Posts by vario
Old Jan 14, 2003, 06:34 AM
jimmy6819 is offline
Find More Posts by jimmy6819
North Aurora, IL
Joined Mar 2000
That would be an older Graupner "UHU" sailplane, circa mid-90's. It was a kit with a "perfekt-fertigrumpf" (plastic) fuse and a built up wing. Good flyer......Call Hobby-Lobby or search the Graupner webpage. I had a few of these years ago but no longer have any info.
jimmy6819 is offline Find More Posts by jimmy6819
Old Jan 14, 2003, 08:28 AM
Ian Easton's Avatar
Joined May 1999
Thanks for the feedback guys.
It does indeed have a plastic fuselage.
Pete,
If you had seen this when we got it ,you would have said the same about our xmas parties!
I think my son did a really good job restoring it - it's the first time he's done anything like that.
It does look a lot like the "Wendy," but I see what you mean about the tail, although the fin/rudder was that shape before we altered it.
It also came with a second slightly different wing. I need to check - maybe we put the wrong wing on it, but I know this one fit the best.
Old Jan 14, 2003, 08:35 AM
Ian Easton's Avatar
Joined May 1999
Just checked on the Wendy - it's a lot smaller and lighter than this one, also the wings are foam core with cut out sections. I know that didn't come out in the photo too clear.
Old Jan 14, 2003, 12:23 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Close, but no cigar... It's a Graupner "Akro Junior" , an aileron version of the Junior. The "Electric Uhu" was it's predecessor. Nowadays the have the Junior Sport (without) and the Junior Sport Plus (With ailerons, but still double dihedral). That is if it has 2m wingspan. This 'new' version has 1.6m wingspan:
WimH is offline Find More Posts by WimH
Old Jan 14, 2003, 02:47 PM
Ian Easton's Avatar
Joined May 1999
That looks a lot more like it!
Thanks again guys - I knew I could count on you!
I'll do some checking to try and confirm it.
Discussion Can you help identify this plane? flyingvranch Scale Sailplanes 8 Apr 08, 2007 09:40 PM
Help! Help Identify This Sailplane Kalim3ro Sailplane Talk 0 Apr 06, 2006 03:19 PM
Discussion Help identify this sailplane suwito Sailplane Talk 5 Mar 05, 2006 07:04 PM
Cool Is it a P-40? Can you help me identify this aircraft temp_oct Parkflyers 1 Jan 04, 2004 11:46 PM
Can you help name this movie Mike C Life, The Universe, and Politics 3 Dec 09, 2003 11:23 PM
