Old Apr 21, 2008, 09:31 PM
poochies is offline
Find More Posts by poochies
United States, NM, Santa Fe
Joined Aug 2006
where do you get the screw to hold on fan for LSJS 3mm plug?
Didnt find one with my Alpha A4 kit or with the motor or plug, would a regular 3mm machine screw work? Do I need a toothed washer? Thanks for the help-
poochies is offline Find More Posts by poochies
Old Apr 21, 2008, 09:50 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
You should've gotten one with the stock fanunit in the box....same bag the green locktite came in.
Anyway, its a small countersunk head type of screw without a washer.
Whatever you use replacing it with (toothed washer included) make sure it doesn't distort the rotor when you tighten it down.
Bruce
bmiller is offline Find More Posts by bmiller
Old Apr 21, 2008, 09:54 PM
poochies is offline
Joined Aug 2006
Thanks a lot, I'll look again for that screw...
I would assume you would lock tite this screw... I will- thanks again-
Andy
Old Apr 21, 2008, 10:12 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
No locktite on it!
That green stuff was to glue the stock plug to the motorshaft, it's almost permanent!
Don't use it on anything else!
I smear some clear silicone on the threads but the screw holds pretty well without anything.
Thats on a stock power setup.
If you're running a hipower setup(like a LSJS).
Add a dab of CA under the rotor. It helps keep it from slipping.
Old Apr 21, 2008, 11:20 PM
rcboosted is online now
Find More Posts by rcboosted
Joined Sep 2006
I used green threadlocker for the plug, and blue threadlocker for the screw, it's not permanent. I've had it come off before. Also, I'd recommend using a flat washer. If you notice, the countersink on the rotor isn't drilled by a machine, it's hand drilled. I had a couple of rotors that aren't drilled perfect and caused the rotor the wobble. The washer keeps it flat no matter how it is drilled.
rcboosted is online now Find More Posts by rcboosted
Old Apr 22, 2008, 08:41 AM
poochies is offline
Joined Aug 2006
Thanks for the info, I meant blue Loctite, not the green...
I've read about how strong the greenstuff is.. I found a 3mm countersunk screw fits perfect, will try flat washer also, thanks again-
Discussion Where do you get that tiny silicone tubing used on HBFP's? generalbacardi Micro Helis 8 Nov 11, 2007 04:19 AM
Discussion Where do you get your press on pinions? BowerR64 Micro Helis 2 May 15, 2007 09:12 AM
Discussion Where do you get your parts for scratchbuilding? Y2kGTP Foamies (Scratchbuilt) 15 May 02, 2007 01:49 PM
Where do you get shrink wrap for lipos? Terkan Batteries and Chargers 3 Nov 20, 2003 06:33 AM
Where do you get brushes for an AP29? sbarrow Electric Ducted Fan Jet Talk 1 Jun 18, 2001 11:32 PM
