Old Apr 20, 2008, 08:42 AM
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Video
How to roll a Blu-Baby wing
This is a short video lesson on how to roll a fan fold foam Blu-Baby wing.
Tony65x55 is offline Find More Posts by Tony65x55
Old Sep 07, 2009, 06:44 PM
mindpanic is offline
Find More Posts by mindpanic
León (Spain)
Joined Jul 2009
Hi,
I want construct this plane on EPP, how i can roll EPP????
Best Regards,
Javier
mindpanic is offline Find More Posts by mindpanic
Old Oct 10, 2009, 12:02 PM
jp.electrik is offline
Find More Posts by jp.electrik
PunchDrunk ex-Pug try'n fly'n
jp.electrik's Avatar
Joined Jan 2009
Hey I finally got the video to play! That's it? No heat? Do you add a spar?
Sorry to be a pest. Any help would be appreciated.
jp
jp.electrik is offline Find More Posts by jp.electrik
Old Nov 18, 2009, 11:52 AM
Kokopeli is online now
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
Heat and spars are optional.
Heat makes it stronger and better looking - but requires practice.
Spars depend on the wing loading - if it breaks, add tape and spars.
Simple,eh ?
Walt
Kokopeli is online now Find More Posts by Kokopeli
Old Nov 20, 2009, 05:17 PM
Joined Jan 2009
Walt
How to pray tell?
I've gotten pretty good at rolling them, how about heat?
jp
Old Nov 20, 2009, 08:16 PM
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
After you roll it it will have little wrinkles in the skin.
Us a heat gun from a distance and wave it back and forth and work your way closer until you see the wrinkles start to get smooth.
You will see what happens when it gets too hot when you practice.
The trick is to know when to stop - almost always you need to stop before it gets perfect.
I find it hard to stop
Another side effect is that it may take some of the bend you wanted, out
You can harden flat pieces, too.
Walt
Old Nov 21, 2009, 11:36 AM
Joined Jan 2009
Thanks Walt,
If I can find a heat gun I will try it.
One more dumb question, You mentioned heating flat pieces, do you then roll them?
Thanks again. Thanks to Tony too.
jp
Old Nov 21, 2009, 12:47 PM
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
Nope, you roll before you heat.
Heating a flat piece is just to make it harder - not usually done.
Go for it (but practice first),
Walt
Old Nov 23, 2009, 11:56 AM
cid186 is offline
Find More Posts by cid186
At least 2 mistakes high
cid186's Avatar
Ridgeland, MS
Joined Dec 2008
Good info
cid186 is offline Find More Posts by cid186
Old Nov 23, 2009, 01:15 PM
rab is offline
rab
Find More Posts by rab
rab
Grounded in Arlington
rab's Avatar
Arlington, Virginia
Joined Aug 2004
Mindpanic - Here is one way I've found to make EPP to hold a curve http://www.rcgroups.com/forums/showp...31&postcount=5. - Allen
rab is offline Find More Posts by rab
how do you calculate area and wing loading for eliptical wingspan rc capo Modeling Science 6 Aug 20, 2002 03:24 PM
help! How do I shape the front wing for the "and now' plane Richard Hayes Foamies (Kits) 9 Feb 01, 2002 06:07 PM
How do I read a "wing loading" value? xadmin Electric Plane Talk 3 Jan 05, 2002 04:48 AM
Any ideas how to thin an all EPP Wing? rparigoris Power Systems 1 Dec 04, 2001 03:47 PM
Discussion How do you find how many OZ. of lift your wing gets? chlee Parkflyers 3 May 29, 2001 01:48 AM
