Old Jun 25, 2008, 09:12 PM
Prashanth is offline
Find More Posts by Prashanth
Bangalore Hindustan, India
Joined Apr 2003
I tried the GPS comparison again with google earth this morning with an unobstructed view of the sky and the data was off when referred to google earth
read from ublox: lon: 77.557871, lat13.030098
coordinates from google earth: lon: 77.332827, lat13.014822
any suggestions or thoughts on this.....
Prashanth is offline Find More Posts by Prashanth
Old Jun 25, 2008, 10:14 PM
AntonK is offline
Find More Posts by AntonK
Joined Nov 2005
4 satellites is hardly a fix. The receiver will give you a 3D, but in my experience its never very good. Also, its possible that Paparazzi and google earth use different spherical models, but we use google earth imagery and it couldnt explain 24 km. I would guess its because you only had 4 sats and you are in india.
AJ
AntonK is offline Find More Posts by AntonK
Old Jun 25, 2008, 10:53 PM
bmw330i is offline
Find More Posts by bmw330i
David1
bmw330i's Avatar
USA
Joined Mar 2007
...another good reason to get the LEA-5H in the air. They are so much more sensitive. Anton any more suggestions? If you could extract the config from yours I could load it into mine and help me determine what's going on. Someone on IRC today was having issues with theirs...you know in u-center just save the GPS config to a file...I'll do the reverse and be able to pre-program the Tiny2.11 I sell with the proper config...win win for everyone.
bmw330i is offline Find More Posts by bmw330i
Old Jun 25, 2008, 10:57 PM
Joined Apr 2003
Hi AJ
This morning I had 8 sats and had a 3D fix, but still was off in comparison to google earth...could it be that something is wrong with the congifg file as I am using a LEa4H module and the config file is for a Lea 4P...could not find a config file on the wilki for LEA4h. The only difference I thought was the LEA4h was much more sensitive than the lea4p
Old Jun 26, 2008, 09:17 AM
Joined Apr 2003
later I reinstalled google earth and tried again, this time it worked fine, dont really know what changed though...now the ublox is quite accurate with the cordinates matching the location of my house in google earth... next on to the IR sensors...
Old Jun 26, 2008, 01:11 PM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
I am in the middle of a post office strike and still i haven't got the stuff from mouser.
The receiver is ready, the plane is ready and flew already but the connectors and modems are still not here.
Chris
hendrix is offline Find More Posts by hendrix
Old Jun 26, 2008, 05:51 PM
bmw330i is offline
David1
bmw330i's Avatar
USA
Joined Mar 2007
Strike, that suxs, sorry to hear. I just have to set my CG and do a test flight myself. No big open areas near my house (at least not that's public land) so I will try this weekend.
Old Jun 26, 2008, 11:05 PM
bmw330i is offline
David1
bmw330i's Avatar
USA
Joined Mar 2007
LEA-5H setting....
Hey all,
Someone on IRC the other day was having issues with their LEA-5H tiny 2.11. I didn't have this handy but now I do so I'm going to post it. This is the line in the aircraft file that is supposed to allow the LEA-5H to work.
Code:
ap.CFLAGS += -DGPS -DUBX -DUSE_UART0 -DGPS_LINK=Uart0 -DUART0_BAUD=B38400 -DGPS_USE_LATLONG -DGPS_LED=2
ap.srcs += gps_ubx.c gps.c latlong.c
It also makes the greed LED blink when a 3D fix is found.
This line is down in the <makefile> section at the bottom of the file.
I have used it without success buy hey, worth a try if you have an LEA-5H based Tiny2.11 so let us know if it works for you. Remember, as with all changes here you'll have to re-compile the aircraft and upload it to the Tiny.
-David
Old Jun 27, 2008, 02:10 AM
Joined Apr 2003
has anyone made a simple light weight antenna for the 900 Mhz 9xtend modem....
a simple dipole or a ground plane antenna at 900 Mhz should be about 7.9 cm in length of each element...on the wiki there are some pictures of copper foil antenna for 900 mhz but no details of how one goes about making one. RC cam has a goof proof antenna that can be made for 900 Mhz good for the ground station but difficult to mount on a plane
any working solutions for 900Mhz antenna
I would like to use the 9xtend but with a light weight antenna...
Old Jun 29, 2008, 10:53 PM
gravesm28 is offline
Find More Posts by gravesm28
Joined Jun 2008
Prashanth,
question for you...
I have been working with the 9xtend with the development kit. However, I'm looking to trim down the profile even more by dropping the development kit and strapping the modem directly onto my laptop cover. The problem that I'm running into is I can't get computer the recognize the modem via the USB connection without the development kit. Have you had any success? Is so, are you using the power from the USB for pins 2 and 7 or are you utlizing an external power source?
gravesm28 is offline Find More Posts by gravesm28
Old Jun 29, 2008, 11:03 PM
AntonK is offline
Joined Nov 2005
graves,
in order to do this you need to use an FTDI cable. This will take the serial data from the xtend and convert it to USB. The Xtend does not do standard USB comms. I believe most FTDI cables pass the 5V rail through so you could power the modem off it. Be careful though, must laptops have a half amp limit, and at 1W Im not sure what that thing will pull.
AJ
Old Jun 30, 2008, 11:37 AM
Joined Apr 2003
Dear graves
I still dont have an ant for the 9xtend so havent powered it on, hope to get is soon, I think it will draw abt 800ma of current at default setting with 1w power output, if you plan to power it from the USB power you need to set the power output to less than 500mw.
Old Jul 01, 2008, 11:56 AM
bmw330i is offline
David1
bmw330i's Avatar
USA
Joined Mar 2007
Update: Arf
Well, I just wanted to write a quick update for those following this thread.
Current status hasn't changed. I need to find someplace to fly in manual then when I get the IR sensors working I'll try auto1 and mechanical trimming.
I think the Single IR sensor is the issue. If I unplug it the GCS attitude display (artificial horizon) seems to work. With it plugged it does not. I will try without. I'm not sure how many people even use it.
That's about it. I did take it outside and power everything up including the GCS and all but the attitude sensing seems to be working perfectly.
Oh, I guess I do have one more thing. I have to assign switch G to the autopilot mode switch in the radio config file per Anton (thank you Anton again).
-BMW
Old Jul 01, 2008, 01:29 PM
AntonK is offline
Joined Nov 2005
BMW,
Im guessing you are trying the Z sensor stuff indoors? The reason it doesnt work is quite simple. Simplified, the math is something like roll angle = roll_ir_sensors/z_sensor.
if you have the z_sensor plugged in, its probably reading the temperature difference between your floor and your ceiling(about 0 degrees). so you have a divide by 0 case. making roll angle measure 90+ degrees. When you unplug it the ADC remains active, but reads a random voltage, unsually like 1.6ish. so the attitude display will kind of work. The Scale wont be right, but it should show direction. I hope that helps. As far as who uses it. Everyone! in fact Im not sure the code would even work anymore without it.
AJ
Old Jul 01, 2008, 09:16 PM
Joined Apr 2003
BMW and AJ
I read in the wiki somewhere that with the IR sensors one has to do the cupboard test (put the autopilot with sensors in a strofoam box etc) and get the neutrals....
after doing this calibration for the ir sensors would it still behave like how bmw is describing?
