Old May 13, 2011, 06:44 PM
jirvin_4505 is offline
Find More Posts by jirvin_4505
working to the closest cm
jirvin_4505's Avatar
brisbane australia
Joined Nov 2002
Still followingopc orn:
Thanks for sharing the progress pictures.
cheers Jeff
jirvin_4505 is offline Find More Posts by jirvin_4505
Old May 14, 2011, 01:18 PM
Slow & Low is offline
Find More Posts by Slow & Low
Slow & Low's Avatar
Canada, ON, Brantford
Joined Apr 2007
Don't forget to identify your tools for the day when they're here and you're not....
Slow & Low is offline Find More Posts by Slow & Low
Old May 15, 2011, 09:26 PM
Slow & Low's Avatar
Joined Apr 2007
Just a post of some roughed in clay work. Slow going, but all part of the plan I'm afraid.
Old May 16, 2011, 06:34 PM
Slow & Low's Avatar
Joined Apr 2007
Ongoing clay work...here you can see that there are still a lot of little cracks and crevices to fill - one day at a time - this stuff is worth the extra effort later on
Old May 17, 2011, 09:07 AM
Slow & Low's Avatar
Joined Apr 2007
Somewhere to Pry
I will leave the clay in these pry locations when I flip it over and mould the upper flanges. This will give a nice spot to get the crows foot into when separating the finished upper and lower mould sections. I've tried to target potential problem areas while placing them around the periphery.
Old May 17, 2011, 11:35 AM
Slow & Low's Avatar
Joined Apr 2007
1/4"-20 Flange Bolt Thread Inserts
Be careful not to over tighten the screws. Just pull them down flush.
Old May 18, 2011, 10:56 AM
Slow & Low's Avatar
Joined Apr 2007
Bring it on...if you've got clay, I've got all dang day!
Old May 19, 2011, 01:27 PM
Slow & Low's Avatar
Joined Apr 2007
Yes folks, it was absolutely free afterall!
I'll post a link to the iso file once I get it ripped...
...and here's a supplies link that looks pretty good too
http://www.miapoxy.com/
Old May 19, 2011, 03:55 PM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
greeeeeat !!
FlyDave is offline Find More Posts by FlyDave
Old May 19, 2011, 04:20 PM
Slow & Low's Avatar
Joined Apr 2007
Every time I go to use this mould and I don't have tighten a hundred nuts and washers onto all those bolts, I'm gonna grin from ear to friggin' ear! Just set the clutch nice and loose on the driver and give those 1/4" bolts hell. These thread inserts are going to save so much time it's not even funny.
Old May 20, 2011, 10:04 AM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
So it looks like you are setting this up to be a three piece wing mold. Is that the reason for the wall you are building behind the leading edge there?
-hutch
Hutch is offline Find More Posts by Hutch
Old May 20, 2011, 10:15 AM
Slow & Low's Avatar
Joined Apr 2007
-hutch
You're on the right track Hutch, but I'll also be doing separate sections for the tips on the upper side. This will allow for some processing options down the road. If I need additional access when installing the leading edge and spar, I can leave the upper tip sections off, and get inside there. A strong joint along the spar is more critical than the tip seam which is more of a cosmetic issue and is easily serviced by a straight forward, non-joggled butt seam.
So it will actually be 5 pieces. I hope that made some sense for you.
Old May 21, 2011, 04:55 PM
Slow & Low's Avatar
Joined Apr 2007
These are garage door hinges. I had them laying around from a past project and won't be needing them. I thought this might be a good opportunity to try something new and hinge the two main sections of my wing mould. If it doesn't work out, I will simply remove the hinge pins. I will align their axes with the laser level to give it the best shot at working since they can't simply be mounted flat against the angled back wall.
It's the classic risk vs reward. The question is - are yours big enough to get an angle grinder that close to 3 years work?
I'm not finished cleaning up yet but I needed a break, so here's some pics for today.
Old May 22, 2011, 03:08 AM
dsquire is offline
Find More Posts by dsquire
dsquire's Avatar
Kitchener, Ontario
Joined Oct 2007
Received my Freeman DVD in the mail today. Thanks for the link Slo & Low. I'm patiently watching this bird being born.
Cheers
Don
dsquire is offline Find More Posts by dsquire
Old May 22, 2011, 09:41 AM
Slow & Low's Avatar
Joined Apr 2007
These hardwood blocks were $0.50 ea at the woodshop supply store.
Here's their website. They have lightweight ply too...
www.workshopsupply.com
Notice that I've set the hinge pins to level when the blocks are placed on the mould face where they will become part of the finished mould base.
Black Widow wireless video - how good? CactusJackSlade Aerial Photography 125 Aug 02, 2003 12:11 PM
Looking For Slow Stick w/ IPS-400 Video Superman Parkflyers 2 Jun 03, 2003 07:46 PM
JSF SC Jr w/ IPS stunt video up! hardlock Parkflyers 0 Jun 26, 2002 07:36 PM
S&E Mags w/Electric Airshow Video chadtyro Aircraft - Electric - Airplanes (FS/W) 3 Apr 27, 2002 02:04 PM
Lil Litestick W/EDf motor video! pohlmeyr Parkflyers 6 Mar 24, 2002 12:15 PM
