Old Jan 10, 2013, 01:37 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Thanks for the info. I'm always looking to improve my methods. Will you be using ribs, spar etc or an hollow wing?
acesimmer is offline Find More Posts by acesimmer
Old Jan 10, 2013, 11:08 PM
Slow & Low is offline
Find More Posts by Slow & Low
Slow & Low's Avatar
Canada, ON, Brantford
Joined Apr 2007
Slow & Low is offline Find More Posts by Slow & Low
Old Jan 12, 2013, 11:21 PM
Slow & Low's Avatar
Joined Apr 2007
These leading edges should be nice and light.
All they have to do is deflect air over the spar.
Old Jan 12, 2013, 11:39 PM
acesimmer's Avatar
Joined Oct 2011
Thanks good info. Could you please post pics on the internals prior to joining the wing halves. It really helps to see how others build and swipe techniques off them. I like the way you are providing the cloth weights etc. Keep it up I'm really looking forward to your build.
Old Jan 13, 2013, 12:22 AM
killercando is online now
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
I agree. It is exciting to see the parts finaly coming together. Looks great. Thats a whole lot of rivets. Lee
killercando is online now Find More Posts by killercando
Old Jan 13, 2013, 10:49 AM
Slow & Low's Avatar
Joined Apr 2007
Old May 21, 2013, 10:01 AM
Slow & Low's Avatar
Joined Apr 2007
So strong they’re scary and so light it makes you look twice when you pick one up…
Al/GRP Laminated D-box Leading Edges
Old May 21, 2013, 01:30 PM
acesimmer's Avatar
Joined Oct 2011
Glad to see you back on the build. Keep us updated.
Old May 22, 2013, 10:58 AM
Slow & Low's Avatar
Joined Apr 2007
Less is more....
Old May 23, 2013, 08:55 AM
Slow & Low's Avatar
Joined Apr 2007
Old May 24, 2013, 04:10 PM
Slow & Low's Avatar
Joined Apr 2007
Crude initial hand layup 410 grams or 14.5 Ounces or 0.9 lb
Part looks great. Still stiffening up a bit.
Old Feb 18, 2014, 04:51 PM
Slow & Low's Avatar
Joined Apr 2007
Year Six I think ??
Clear packing tape is not very good in compression but applied around the periphery like this it works very well in shear.
There are no internals here. By taping this up for a quick touchy-feely session, it should be quickly apparent that little internal structure is required at this scale. The inherent beam strength of the cast trailing edges coupled with the rigidity cast into the lower skin by including the wheel and flap bay details yields an empty shell that is almost strong enough without internals. Very promising, not to mention motivating and satisfying to stare at...
[a href="http://s1069.photobucket.com/user/Two_Bulldog/media/P82000012_zpsfc4ad5fa.jpg.html"][img src="http://i1069.photobucket.com/albums/u475/Two_Bulldog/P82000012_zpsfc4ad5fa.jpg" style="max-width:100%;"][/a]
Old Mar 05, 2014, 02:41 PM
Slow & Low's Avatar
Joined Apr 2007
I couldn't find my old homemade hotwire cutter. (an old battery charger, a block of wood, two copper pipes, and a guitar string worked just fine for many moons...)
This is a small investment that will save many, many, hours of cutting balsa ribs, or paying for the laser cutting etc...
I have to say, it's a beautiful little tool that I should've bought 30 years ago.
The wires it uses can be bent to shape. A small Vee profile around the perimeter of a rib might do well to hold the cabosil/milled fibre goo in place during assembly.
What you see in the photos is the aluminum cutting template in white and the foam rib in blue.
I first printed paper templates to scale and later transfered the paper template to the aluminum shown here.
Here's a tip - check your yellow pages for custom eavestrough - they buy aluminum sheet stock by the roll...
Proxxon Tools, Hotwire Cutter Thermocut 12/E (12v DC)
Voltage
12v, 60w, 50/60Hz
Cutting Wire Temperature
300 - 660 ºF
(150 - 350 ºC)
Maximum Extension
7.9" (200mm)
Cutting Height
5-3/4" (150mm)
Wire (NiCr8020)
11.4" Long, 20 gauge
Weight
0 lbs (3.0kg)
Black Widow wireless video - how good? CactusJackSlade Aerial Photography 125 Aug 02, 2003 12:11 PM
Looking For Slow Stick w/ IPS-400 Video Superman Parkflyers 2 Jun 03, 2003 07:46 PM
JSF SC Jr w/ IPS stunt video up! hardlock Parkflyers 0 Jun 26, 2002 07:36 PM
S&E Mags w/Electric Airshow Video chadtyro Aircraft - Electric - Airplanes (FS/W) 3 Apr 27, 2002 02:04 PM
Lil Litestick W/EDf motor video! pohlmeyr Parkflyers 6 Mar 24, 2002 12:15 PM
