Old May 13, 2012, 06:43 PM
razortoe is offline
Find More Posts by razortoe
Keep it Simple Stupid
razortoe's Avatar
United States, NC, Raleigh
Joined Jul 2011
Lolz, let's just say I don't cut, polish, and smoothe my toenails frequently enough for me ole lady.
OIC, that makes perfect sense. I stumbled across an old episode of "Dogfights" on Netflix the other day about the flying tigers. I never knew that's where the sharkteeth originally camefrom and they were Chineese aircraft (well technically at least). Fascinating! Keep up the good work!
razortoe is offline Find More Posts by razortoe
Old Jun 08, 2012, 01:33 PM
Slow & Low is offline
Find More Posts by Slow & Low
Slow & Low's Avatar
Canada, ON, Brantford
Joined Apr 2007
Slow & Low is offline Find More Posts by Slow & Low
Old Jun 09, 2012, 04:49 PM
D.English is offline
Find More Posts by D.English
Hemet California
Joined Jul 2009
Nice.
Where did the wing mold go ????
DE
D.English is offline Find More Posts by D.English
Old Jun 09, 2012, 07:24 PM
Slow & Low's Avatar
Joined Apr 2007
Originally Posted by D.English View Post
Nice.
DE
100 times on the blackboard for you my eager friend.
"Patience is my hobby; haste, my rival. " - Slow & Low.
Old Oct 06, 2012, 04:31 PM
Slow & Low's Avatar
Joined Apr 2007
New shop - new building season
Wing Mould - Section #2
Flooring Laminate
Old Lamp (tubing)
Furniture Sliders
1/4-20 thread inserts
Aluminum T-slot Extrusion
Carnauba Wax
Hold on....here we go again
Old Oct 06, 2012, 11:02 PM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
Good to see you back at it!
-hutch
Hutch is offline Find More Posts by Hutch
Old Oct 08, 2012, 11:02 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Originally Posted by Slow & Low View Post
PS. - I purged those tanks very carefully first with air, then with water - I am not promoting this sort of thing - take them to your Fire Department and ask for their help
Liquid propane in it's gaseous state is heaver that air. Fill the tanks with compressed air, invert them (valve down) and open the valve. That should get rid of any propane. You will still have to deal with the stink from the mercaptan (the stuff that makes it stink) though. Flushing with water is ok, just follow up with some alcohol to remove the remaining moisture.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my Senator.....
Old Oct 09, 2012, 12:14 PM
Slow & Low's Avatar
Joined Apr 2007
These air fittings will be filled with clay and cast in place along with the o-rings. I'll rough up the OD's with a file first to ensure adhesion.
Inexpensive, yes; effective, time will tell.
Old Oct 09, 2012, 03:57 PM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
Are those to help separate the mold halves once everything inside is all cured up?
-hutch
Old Oct 09, 2012, 06:59 PM
Slow & Low's Avatar
Joined Apr 2007
-hutch
That's the idea Hutch - I had the o-rings under the bench and the fittings cost me under $10 in total. Each of them will be pushing down on a wooden insert cast into the lower half. It might work, it might blow the inserts out of the lower section, it might crack the lower cavity, it might do all of the above to the upper tool, and it may just look silly in the end, but l'm gonna find out - slowly as I turn up the pressure mind you...
I opted for the barbed fittings so that it's easy to configure with 1/2" hard vacuum hose. With a pneumatic control valve, and an actuator it might be possible to alternately apply vacuum to help with mould assembly after trimming and prior to joining or alternately positive air pressure to open the mold post cure.
Old Oct 10, 2012, 01:20 AM
Slow & Low's Avatar
Joined Apr 2007
Clay holds O-ring flat to face. (8 places)
Barbed part ejector port also included in saddle area.
Old Oct 16, 2012, 12:31 AM
Slow & Low's Avatar
Joined Apr 2007
well, it better be right 'cause it's kinda permanent...
Old Oct 16, 2012, 01:36 AM
Slow & Low's Avatar
Joined Apr 2007
surface veil to prevent the heavier weaves from showing through over time
Old Oct 16, 2012, 11:47 AM
Slow & Low's Avatar
Joined Apr 2007
6 Oz Tape - Outer Flange Support
9 Oz Cloth - 1st Layer
Old Oct 17, 2012, 12:41 AM
Slow & Low's Avatar
Joined Apr 2007
no point in throwing another $100 in epoxy and cloth at reinforcing this section until I've seen the cavity - if all turns out well, I can always rough it up with a cup wheel on the grinder and lay down a few more layers of heavy cloth
hopefully this will set up enough to remove the forms tomorrow - now we wait....lol
Black Widow wireless video - how good? CactusJackSlade Aerial Photography 125 Aug 02, 2003 12:11 PM
Looking For Slow Stick w/ IPS-400 Video Superman Parkflyers 2 Jun 03, 2003 07:46 PM
JSF SC Jr w/ IPS stunt video up! hardlock Parkflyers 0 Jun 26, 2002 07:36 PM
S&E Mags w/Electric Airshow Video chadtyro Aircraft - Electric - Airplanes (FS/W) 3 Apr 27, 2002 02:04 PM
Lil Litestick W/EDf motor video! pohlmeyr Parkflyers 6 Mar 24, 2002 12:15 PM
