Old Apr 02, 2012, 11:39 PM
Slow & Low is offline
Find More Posts by Slow & Low
Slow & Low's Avatar
Canada, ON, Brantford
Joined Apr 2007
moving along...
Slow & Low is offline Find More Posts by Slow & Low
Old Apr 05, 2012, 04:27 PM
Slow & Low's Avatar
Joined Apr 2007
Old Apr 06, 2012, 04:23 PM
Slow & Low's Avatar
Joined Apr 2007
...another breadcrumb
Old Apr 06, 2012, 11:34 PM
Slow & Low's Avatar
Joined Apr 2007
Old Apr 09, 2012, 12:20 AM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
Good idea having your layup schedule written out! I have made the mistake in my schedule before and really wanted to kick myself. Nice work, getting to the gravey.
Where's Paris??
George
geostomp is offline Find More Posts by geostomp
Old Apr 13, 2012, 11:08 PM
Slow & Low's Avatar
Joined Apr 2007
These joins are all prepped with 80 grit and alcohol.
Join Rear Lower Fuselage Seam
Insert Ply Dowel Bulkhead
I was having to wait for the ply bulkhead insert to cure so that I could remove the saddle sections for access when joining the firewall chin subassembly.
Cowl mount blocks held in place temporarily with quick 5 minute epoxy
Next time I will have access to allow attaching the firewall chin in the same operation as the lower rear seam and dowel bulkhead.
Old Apr 20, 2012, 03:41 PM
Slow & Low's Avatar
Joined Apr 2007
...not a lot of time today, but I did find the hour and a half to assemble the chin to the main fuselage - now we wait.... I know, I know, what else is new
Old Apr 21, 2012, 09:11 AM
Slow & Low's Avatar
Joined Apr 2007
Canopy Frame Serial 000002
Old Apr 21, 2012, 01:22 PM
Slow & Low's Avatar
Joined Apr 2007
How do you arrive at a unique airplane?? You nique up on it of course!
Slowly, but rest assured, assuredly, I am moving toward something here. lol
Green leaves a lot to be desired in the way of opacity.
Untrimmed Weight - 820 grams or approx. 1.8lbs
Old Apr 22, 2012, 08:44 AM
Slow & Low's Avatar
Joined Apr 2007
I've carved enough hard balsa block and melted enough plastic in my mother's old oven to know that waiting overnight for a canopy frame to set up is almost too good to be true!
Not bad for #2, but canopy #3 will be even better...
Old Apr 22, 2012, 10:08 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Awsome.
Old Apr 23, 2012, 01:52 AM
Slow & Low's Avatar
Joined Apr 2007
I've got something cooking tonight - wanna take a guess??
Old Apr 23, 2012, 11:16 AM
Slow & Low's Avatar
Joined Apr 2007
You guessed it - that's a lower cowl section.
The tool in all rights should have been at least a two piece mould with the forward section pulling straight off the nose.
Don't be fooled by the test part, rather let it convince you of the durability of the materials involved. I stood on the mould and pulled and twisted that thing with all my might.
Pile it into the ground, dust it off, pop out the dings and stick it back on.
Lets see you do that with an ABS cowl - NOT!!
We conquered the opaqueness issue with a couple of coats of automotive paint in the mould.
So the next fuselage will get brown camo followed by green paint.
Old May 10, 2012, 06:23 AM
razortoe is offline
Find More Posts by razortoe
Keep it Simple Stupid
razortoe's Avatar
United States, NC, Raleigh
Joined Jul 2011
Great looking plane, and thanks a TON for the vids and buildlog, you inspired me to start scratch building (starting with foam though, to build experience).
Pardon the n00b question, but could you explain why you decided to make the lower cowl a separate part from the fuse? Is it for durability, so you can replace just that part after a minor crash?
razortoe is offline Find More Posts by razortoe
Old May 13, 2012, 10:41 AM
Slow & Low's Avatar
Joined Apr 2007
razortoe?? I hope that isn't anything like cameltoe!!
The short answer is that it removing the spinner to access the engine bay is a lot of work if you're going to do it more than once. Hope that helps, and good luck on your build!
Black Widow wireless video - how good? CactusJackSlade Aerial Photography 125 Aug 02, 2003 12:11 PM
Looking For Slow Stick w/ IPS-400 Video Superman Parkflyers 2 Jun 03, 2003 07:46 PM
JSF SC Jr w/ IPS stunt video up! hardlock Parkflyers 0 Jun 26, 2002 07:36 PM
S&E Mags w/Electric Airshow Video chadtyro Aircraft - Electric - Airplanes (FS/W) 3 Apr 27, 2002 02:04 PM
Lil Litestick W/EDf motor video! pohlmeyr Parkflyers 6 Mar 24, 2002 12:15 PM
