Old Feb 24, 2012, 11:06 AM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
Glad to see some updates here again! I really enjoy watching this build!
-hutch
Hutch is offline Find More Posts by Hutch
Old Feb 24, 2012, 09:39 PM
Slow & Low is offline
Find More Posts by Slow & Low
Slow & Low's Avatar
Canada, ON, Brantford
Joined Apr 2007
now I'm havin' f-u-n heaven, I'm in heaven
ply insert is excessively strong...very nice for rigidity
Slow & Low is offline Find More Posts by Slow & Low
Old Feb 25, 2012, 02:17 PM
Slow & Low's Avatar
Joined Apr 2007
All ready to join firewall subassembly to main fuselage assembly.
Although this resin and hardener combination is taking up to 48hrs at 72 F to cure to a point where I would consider demoulding it, I'm in no rush, and it seems to be extremely stiff in the wing saddle cross section when it finally does harden right out to the surface.
I am considering turning this cavity into an integral fuel tank....
Old Feb 26, 2012, 02:10 AM
Slow & Low's Avatar
Joined Apr 2007
3 layers 9 Oz Cloth - 1" wide strips
This will eventually become the inside of the fuel tank.
Old Feb 27, 2012, 09:36 PM
Slow & Low's Avatar
Joined Apr 2007
Oh boy, so much to tell....
This new cheap epoxy is great. It produces a stiffer, stronger part.
Now don't let the ugly test fuselage scare you off, here's some things we learned...
- surface veil for camouflage works great!
- some black sharpie around the perimeter of dark brown camo patches adds a level of detail too
- it is possible to match camo across parting lines
- tempra powder works great and is inexpensive (10% by resin weight)
- 1/4" ply is too heavy for firewall
- 1/8" ply dowel bulkhead works great
- assembly method for inserting chin plate / firewall subassembly works great! (I've been waiting to see if this would work for a very long time now)
- pink P-40's are for girls next time green/blown blend will be substituted for the lighter brown
I've also started on the firewall for the next one.
It will now be 1/8" Ply laminated with aluminum skin.
This aluminum looks to be around 0.020" maybe 0.5mm - it used to be a window awning...
I've also calculated that I can squeeze in around 16 Oz of fuel in an integral tank behind the firewall and centered around the plug in the pictures.
All in all, I'm already started on the next one...
Old Feb 28, 2012, 07:35 PM
Slow & Low's Avatar
Joined Apr 2007
...not a lot of free time today, but here's a pic to motivate some of you to get away from the PC and wander back in the direction of your own workbenches....
how do like my computer skills!?
Old Feb 29, 2012, 11:47 AM
Slow & Low's Avatar
Joined Apr 2007
We need some internals and they need to be inexpensive, lightwight, and easy to install.
I submit exhibit "A" - Aluminum with basswood if you please...11 grams worth
Old Feb 29, 2012, 05:27 PM
Slow & Low's Avatar
Joined Apr 2007
Firstly - we've exceeded our bandwidth allowance for the original photobucket account, so all picture links from here forward will point to a new account that can be found here... http://s1069.photobucket.com/albums/u475/Two_Bulldog/
This is the rear cockpit bulkhead. It provides a vertical mounting surface on the rear face for our rudder and elevator servo mounting brackets. It also provides a shear pocket in the forward face, into which the hardwood blocks that draw the fuselage to the wing saddle will seat.
Please remember that these are prototype parts and although they're not necessarily the prettiest, they are functional and more importantly have provided templates, and benchmarks for all future part revisions.
Making more is easy work...
Old Mar 04, 2012, 08:33 AM
Slow & Low's Avatar
Joined Apr 2007
If refinement is a fool's recipe for success, then I think on the right path...
worn out old uniform pants - could I get any more ironic?? )
Post Script - the missing pics will be back 031012
Old Mar 04, 2012, 02:16 PM
Slow & Low's Avatar
Joined Apr 2007
So our templates for cutting cloth are getting more and more refined, and in addition we now have a complete set including not only the brown areas but also the green. This will allow me to accurately pre-cut and lay down the continuous strand surface veil everywhere as an initial layer. This is what keeps the epoxy concentration and therefore opacity high at the part surface.
Alright, you may have noticed that I keep chopping things up into smaller and smaller operations. This is because I'm only one person. I will focus on producing one section at a time and joining them post-cure. There's been no issues with the strength of any seam thus far and this will allow me to take my time.
so first it's brown camouflage portside on cssv
Old Mar 04, 2012, 08:29 PM
Slow & Low's Avatar
Joined Apr 2007
Well, there's another 8hrs....I love this! Cosmetically this part should be ABSOLUTELY STUNNING!! :P
Old Mar 04, 2012, 11:55 PM
Slow & Low's Avatar
Joined Apr 2007
This is 6 Oz tape. You don't want to know how cheap I get this stuff surplus.
One man's trash....
Talk about saving time!
Old Mar 05, 2012, 12:15 PM
Slow & Low's Avatar
Joined Apr 2007
OK time to do a 'splainin' - what am I doing!?
There are a few things going on here at once but I'll do my best to take some time and explain my approach. I could lay down 2 layers of 6 Oz cloth, peel ply, blotter, bag it, and be done with it. Does that sound like me?? HECK NO!!
No, I want to capture that late 20th century, industrially manufactured, moulded-in, toy-like, monotonal opaque plastic look that people are drawn to and they don't know why.
The other thing I'm trying to do is make an airframe with a factor of safety of 1.1 - what's that mean? - that means just strong enough and that's it.
The main intent here is to saddle the firewall to the wing. In the following photos you can see where I've added 2 layers of a heavy 9 Oz cloth where the firewall and also the wing mounting blocks at the rear of the cockpit will be installed. Essentially they are 4" wide composite integral bulkheads. They are directly connected again by 9 Oz cloth through the chin plate in the firewall subassembly and also 2 layers of heavy cloth in the aft portion of the wing saddle.
Another concern are tail loads. Pitch loads are handled pretty well by the inherent "egg" cross section of the rear fuselage, but this capacity will be greatly enhanced when the port and starboard subassemblies are joined using 1" stips of 9 Oz cloth.
Yaw loading is transferred down the sides of the fuselage wall through and into the reinforced wing saddle by the 6 Oz tape that I've also overlapped along the centerline to form an integral longeron for additional beam strength.
If you look closely you will notice that there are areas where the fuselage will be only the thickness of the saturated cssv that forms the camouflage surface. Will this be enough?? Honestly, I don't know. That's why I tried it in a couple of small areas that are supported peripherally. I can say this much - I expect it to be as puncture resistant and as strong in tension as any iron on film.
I've also improved the flow through the integral exhaust manifolds.
Old Mar 11, 2012, 09:45 PM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
Nice work!
geostomp is offline Find More Posts by geostomp
Old Mar 11, 2012, 10:22 PM
Syntax is offline
Find More Posts by Syntax
Medical IT Geek
Syntax's Avatar
USA, MN, Rochester
Joined Jul 2007
Same here.
Syntax is offline Find More Posts by Syntax
Black Widow wireless video - how good? CactusJackSlade Aerial Photography 125 Aug 02, 2003 12:11 PM
Looking For Slow Stick w/ IPS-400 Video Superman Parkflyers 2 Jun 03, 2003 07:46 PM
JSF SC Jr w/ IPS stunt video up! hardlock Parkflyers 0 Jun 26, 2002 07:36 PM
S&E Mags w/Electric Airshow Video chadtyro Aircraft - Electric - Airplanes (FS/W) 3 Apr 27, 2002 02:04 PM
Lil Litestick W/EDf motor video! pohlmeyr Parkflyers 6 Mar 24, 2002 12:15 PM
