Profile RA-5C Vigilante
This is my first profile jet pusher. I'm really into vintage supersonic jets. If all goes well it will go up tomorrow morning. Really busy all the time so it's tentative. 6 & 9 mm depron. There's some thing I don't like about my workmanship so I'm calling this one the prototype. I'll put markings on the next build. I don't know what else to say... there it is.
Wing Span: 24.5" Wing Area: 177" ^2 Motor: hexTronik 1300kv Propeller: APC 7x5 E Battery: 700 mah 3 cell Servos: 2 (mixed tail-eron) Link to video Link to plans |
Way too windy to fly but here's the video link.
http://www.rcgroups.com/forums/showthread.php?t=852708 |
Glad that worked out for you, My A model was similar, I toned down the pitch, but now my roll rate is a bit slow, but not enough that I have played around with it to change anything. Good Job.
Frank Quote:
Latest blog entry: Spaceship One
That's interesting, I've found that ailerons, especially strip type can cause a wing stall as you get to very slow speed and large deflections, when I'm doing high alphas I find the tailerons will allow large deflection control and the plane won't drop off one way or the other. Might be that you've had to tone down the throw too much, on all my tailerons, I'm running pretty large deflections.
Frank Quote:
Yeah, I saw your video that shows the deflection on yours. That's how I originally mine but have it about half that now. I'll play with it some more. Normally the air is nice in the morning here but there was still a 10-15 mph breeze. I'd like to get some flights in some dead air to really dial it in.
I'll make tracings from my templates and post plans. I literally had the smallest 3-view to work from (wingspan is like 3 inches on the 3-view) and the height and length of the camel-back is questionable. After construction was complete I thought it would be more clear if it was the right size, but I'm still not sure. It looks cool so I guess it's ok. Plus I forgot to add the camera pod on the belly. I know the is sacrilegious, but I think I might want a higher wing-loading. hahaha. I might move the battery back under the wing and just put some lead in the nose. |
Got 3 flights in this morning in dead air. 700 mah packs at 10 minutes each. Not sure how much is left but I'd guess I could have went at least 5 minutes more. I'm really digging this plane. It's fast, has a tiny bit more than 1:1, and loops in about 5 feet. Roll rate is moderate but that fits my style so I'm happy with it. It turns on a dime and doesn't lose too much air speed.
My buddy is much better at 3D than me and he was getting it to hover by torque rolling... which looked ridiculous. haha. He did some high alpha and low passes. I got some good video while he was flying. I'll get it online late tonight or tomorrow. I'm a little confused by the prop I'm running but I'm no expert in power systems. 7x5E on a little 1300 kv outrunner and 8 amp esc. It has more than 1:1. I see way smaller props on more powerful motors. |
that prop sounds right, I'm running a 6x4 on small 1500-1700kv motors,
and a lot of the parkjet motors are 2Kv or better, so they are happy running a small diameter prop very fast. Frank Quote:
That's great! That's what I love about profile pusher jets, you can fly them like a jet, or you can fly them Not like a jet
And then just plop them down on a small patch of grass when done. I think they are even more fun in a little wind.Frank |
That was my buddy flying. Normally I'm a soul surfer and just love to cruise and make big turns. He put it through it paces yesterday. Now he wants me to cut some cores for him plus one other person.
I need to figure out why my camera won't focus too. Normally it works great but apparently not for small flying objects. |
| Thread Tools | |
| **EBAY** RA-5C Vigilante | ronfree | Aircraft - Electric - Airplanes (FS/W) | 0 | Jul 04, 2004 11:40 PM |
