Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
This thread is privately moderated by LOGICAL_PSYCHO, who may elect to delete unwanted replies.
Old Sep 15, 2009, 06:33 PM   #121
oldpilot,
Beautiful job on the "Blackbird"! Brought back memories of Okinawa, 1968, when they flew out heading northwest. I remember looking up at one as it flew over at about 1000 ft and then the pilot kicked it into high gear and it literally disappeared from view in 3 seconds.
Thanks much for the memory,
Hankg
hankg is offline Find More Posts by hankg   Reply With Quote
Old Sep 16, 2009, 12:18 AM   #122
Mcdyvie's Avatar
Here are some plans for the Speed Stick...Sport Flying Foamy.
http://www.rcgroups.com/forums/showthread.php?t=1111879
Mcdyvie is offline Find More Posts by Mcdyvie   Reply With Quote
Old Sep 22, 2009, 10:33 AM   #123
Send a message via Yahoo to horsinaround
cool
horsinaround is offline Find More Posts by horsinaround   Reply With Quote
Old Sep 29, 2009, 06:29 PM   #124
maguro's Avatar
Maguro
Blu-Guppy Sailplane http://www.rcgroups.com/forums/showthread.php?t=1043494 Plans in posts 71 and 78. (An electric powered sailplane using a 96 inch KFM3 wing).
  • Name: Blu-Guppy Flying 15-1.jpg
maguro is offline Find More Posts by maguro   Reply With Quote
Old Sep 29, 2009, 07:42 PM   #125
oldpilot's Avatar
Love that Blu-Guppy, and love building in foam.
Unfortunately I no longer have room for a model that big.
Cheers. Paddy.
oldpilot is offline Find More Posts by oldpilot   Reply With Quote
Old Oct 11, 2009, 02:55 PM   #126
the flying duthman
ninja plans
here or some plans for a wing type
its a good flying type and fast http://www.rcgroups.com/forums/showt...ighlight=ninja
have fun
gr
aws1 is offline Find More Posts by aws1   Reply With Quote
Old Oct 15, 2009, 06:37 PM   #127
davereap's Avatar
Send a message via MSN to davereap
Here are a lot of pusher propjets...nice models free plans
and theres more
http://rc.tomhe.net/
  • Name: 1.jpg
  • Name: 2.jpg
  • Name: 3.jpg
davereap is offline Find More Posts by davereap   Reply With Quote
Old Oct 24, 2009, 07:53 PM   #128
can't wait to fly!!!:)
CG for f-22
Originally Posted by wmcneal
Mattbee, here are the Tomhe F-22 Plans. In my opinion this is the best quick build F-22 plan available. Uses the regular or super park jet motor. Has thrust vectoring for awesome performance. A kit is also available from 6mmflyrc.com if you don't want to cut out parts.
can you please tell me where the CG is on the plans for the F-22 Raptor you gave me back on page 6
thank you,
mattbee
Mattbee is offline Find More Posts by Mattbee   Reply With Quote
Old Oct 24, 2009, 08:08 PM   #129
plans
Originally Posted by oldpilot
To Continue:-
The wings and in fact all the forward facing edges were sanded to a fairly sharp rounded edge. The outer wing panels were treated to a "Droop Snoot" treatment as in the full size and the wing tips were given about 4mm of washout to hopefully reduce tipstall tendencies.
The first flight was very twitchy as the large control surfaces had far too much throw. This was reduced mechanically and also an adjustable movement reducer was plugged in between the RX and the ailerons which allowed fine tuning of the aileron movement.
After that she flew fine. The Yellow tails were good for visibility in the air, but she was still a bit "Stealthy" if you got a bad background.
But this is what she looked like in the sky.
Battery was a Ni Cad flat pack placed right on the CG (for the needed slope soaring weight), four small servos on Y leads, and only a two channel TS was needed. Antenna was routed along the wing under the covering.
Altogether a very simple quick and inexpensive way to get a sharp looking and good flying Slope Soarer.
Cheers. Paddy.
have made any plans if you have I would like to see them I really want to build a SR-71.
Mattbee
Old Oct 24, 2009, 08:26 PM   #130
oldpilot's Avatar
Mattbee
Go back to page 8. Post 109. which tells you how to get the three view. Print it down A4 and take it to your local print shop and have it blown up to the size you want.
Cheers. Paddy.
Old Oct 24, 2009, 09:41 PM   #131
So many planes, so little time
wmcneal's Avatar
Send a message via AIM to wmcneal
thank you,
mattbee
Mattbee,
The CG for the Tomhe F-22 in post #90 is 21 1/4" from the nose of the plane.
wmcneal is offline Find More Posts by wmcneal   Reply With Quote
Old Oct 28, 2009, 01:06 PM   #132
Gorilla Glue,... yummy
warhead_71's Avatar
Send a message via Yahoo to warhead_71
I am starting plans in my Blog for a 50" sport bipe:
http://www.rcgroups.com/forums/member.php?u=127601
Made from 1/2" pink and 1/4" blue foam, or equivalent.
warhead_71 is offline Find More Posts by warhead_71   Reply With Quote
Old Nov 07, 2009, 12:07 AM   #133
Some epoxy & it flies again...
Low Pass's Avatar
Working on this one now:
Scratch built Depron Ki-61 Hien "Tony" plans and build log
http://www.rcgroups.com/forums/showthread.php?t=1136790
Low Pass is offline Find More Posts by Low Pass   Reply With Quote
Old Nov 09, 2009, 08:34 PM   #134
check my BLOG
foam and tape's Avatar
The twins
desinged and flew these, I had fun making the video thanks to the other guys for making plans for me
http://www.rcgroups.com/forums/showthread.php?t=1124466
R/C multi purpose cargo plane (music video) (5 min 34 sec)
foam and tape is offline Find More Posts by foam and tape   Reply With Quote
Old Nov 09, 2009, 09:29 PM   #135
I JUST GOTTA BUILD SOMETHING!!
OK, that video WAS awesome! Very cool stuff and very entertaining.
Towards the end when you were dropping vehicles & the tank was fun to watch. Especially when the tank was dropped in the grass, it lands on it's treads, and then proceeds to drive off.
Again, very cool man.
No I gotta go check the thread & see what gear & supplies I need to buy next!
Jimmy
Jimmy JFlyer is offline Find More Posts by Jimmy JFlyer   Reply With Quote
Alert Free Plans for Foamies (Post links here) JAM Foamies (Kits) 35 Sep 22, 2009 10:36 AM
Question Ideas & plans for 36” scratchbuilt sport plane? cam777cam Sport Planes 40 Apr 12, 2007 06:27 PM
Great free plans for foamies... NetForce2K Foamies (Kits) 5 Apr 28, 2003 05:02 PM
Plans for Fan-Fold-Foamies? ForeverFlying Foamies (Kits) 1 Oct 04, 2002 08:31 PM
Plans for Messerschmitt bf110 from Flair bibblebum Electric Plane Talk 3 Jul 31, 2001 02:23 PM
Bored? Want to fight?
Join the RCGroups clan!
