This thread is privately moderated by LOGICAL_PSYCHO, who may elect to delete unwanted replies.
Old Dec 21, 2011, 04:07 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I used QCad. Great simple 2D drawing program, and I export all my plans to PDF using CutePDF.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Dec 21, 2011, 09:29 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Do you have a power/parts list?
Rickflaguy is offline Find More Posts by Rickflaguy
Old Dec 22, 2011, 10:51 AM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
Hey Sumu_pirate ever think of doing a B-17 using this build style? Would love to have plans for one.
larryross is offline Find More Posts by larryross
Old Dec 22, 2011, 12:50 PM
pappaflyer is offline
Find More Posts by pappaflyer
pappaflyer's Avatar
Joined Oct 2010
"DaBongo" a 26" Foamy.
"DaBongo 2",
A 26" Foamy designed by Paul Phillips Saint John model Flying Club.
pappaflyer is offline Find More Posts by pappaflyer
Old Dec 22, 2011, 12:59 PM
pappaflyer's Avatar
Joined Oct 2010
"DaBongo 2"
Here is the build file.
Old Jan 03, 2012, 01:48 PM
wsamoset98 is offline
Find More Posts by wsamoset98
I Feel The Need For Speed!
wsamoset98's Avatar
Joined Oct 2011
are there any full fuse ww1 biplane plans that are made out of 6mm day-pron or some other type of foam that size?
i bet ive scoured the internet looking for the right plans for over 10hours.
any sugjestions???
wsamoset98 is offline Find More Posts by wsamoset98
Old Jan 03, 2012, 10:41 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Jetset's DR1 ?? or how about the combat thread
Wilfor is offline Find More Posts by Wilfor
Old Jan 04, 2012, 08:25 AM
Sumu_pirate is offline
Find More Posts by Sumu_pirate
Adventure is just bad planning
Sumu_pirate's Avatar
India
Joined Dec 2009
60" B17 foam plans coming soon...
@Larryross: Sir! Your B17 is taking its shape in my computer. Here are photos of my progress in this project. Fuselage is almost done. Engine Nacelles and Wing remaining. Hope it fits your expectations...
@Other members: The .pdf files coming soon.
The dimensions would be as follows:
Wing Span: 60"
Wing Area: 468 sq. Inch
Length: ~45"
AUW: Can't tell you exactly...
The plan would be mostly 5~6mm Depron foam based.
I will upload the plans in ".pdf" format once I am done.
Sumu_pirate is offline Find More Posts by Sumu_pirate
Old Jan 05, 2012, 02:08 PM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
Painting
Built my two scratch built F-16 and F-22 out of
OWENS CORNING FOAMULAR [pink foam]. I understand it is the same as their BLUE FOAM.
Does anyone know of a paint that can be used to paint these planes. I have tried the
KRYLON. It does not work
You all will make fun of me if I am flying a PINK fighter jet.
SARG5
SARG5 is offline Find More Posts by SARG5
Old Jan 05, 2012, 02:33 PM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
Originally Posted by SARG5 View Post
Painting
SARG5
i cant seem to find owens pink foam in any size below 3/4 inch, ive been to several home depots in the local area. any suggestions?
kremecheze is offline Find More Posts by kremecheze
Old Jan 05, 2012, 02:34 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I paint all of my jets with regular old Testors spray paint. It comes in military colors, and I've used it on everything but the pink foam without issue.
Pat
Old Jan 05, 2012, 11:11 PM
7up is offline
7up
Find More Posts by 7up
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
Krylon H20 paints work great. They are water based and won't melt the foam.
Don't mind the pink, real men can fly pink, lol.
-Buk
7up is offline Find More Posts by 7up
Old Jan 06, 2012, 07:44 AM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
I am being told that Lowes [BLUE FOAM] is the same stuff.
OWENS CORNING. -- FOAMULAR in the Pink, Not sure what it is in the Blue.
Home Depot should be able to order some in for you. BUT. do not know if they would order any in under a FULL PALLET .
Have you talked to their staff. I would think the 1/2 in. , they would keep on hand at all times.
SARG5
Old Jan 06, 2012, 08:11 PM
Joined May 2011
I have an idea that my students might be able to make a glider or even design one. Anyone have a good tutorial? I have heard there is a free cad and Google SU. I looked at Google and realized I need some help. Referral to a SIMPLE link is good too.
Rick
Old Jan 19, 2012, 08:49 AM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
SARG5 here
Had my RV in for repair at the NuWa RV factory in Chenute, Ks. this past few days. While there saw stacks of BLUE FOAM that they use inside their walls RV construction.
Talked to their eng. dept. They use this foam because of strength and dense.
STYROFOAM
Panel Core 20 Insulation
Extruded Polystyrene Foam
DOW CHEMICAL COMPANY
www.dowbuildingsolutions.com 1-989-636-4400
Do not have a clue at this point in time. I picked up a sheet of their 3/4 in. and some scraps to play with.
This stuff looks VERY STRONG, Much more then the pink or blue foam from local lumber yard.
As we speak I have a message in to DOW to see if they want to play with us RC builders.
side note
I would think that any of us could check with any of our local RV Dealers, or RV repair locations. I would think that many would use a much better foam then the lumber yard.
However NuWa folks said they were about the only one in the ind. that used this more expensive foam in their build.
I also picked up qt. of the glue they use in const.
PASSING THIS ON FOR YOU BUILDERS TO LOOK AT.
Will be testing .
SARG5
Alert Free Plans for Foamies (Post links here) JAM Foamies (Kits) 37 Apr 02, 2010 06:55 AM
Question Ideas & plans for 36 scratchbuilt sport plane? cam777cam Sport Planes 40 Apr 12, 2007 05:27 PM
Great free plans for foamies... NetForce2K Foamies (Kits) 5 Apr 28, 2003 04:02 PM
Plans for Fan-Fold-Foamies? ForeverFlying Foamies (Kits) 1 Oct 04, 2002 07:31 PM
Plans for Messerschmitt bf110 from Flair bibblebum Electric Plane Talk 3 Jul 31, 2001 01:23 PM
