Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
This thread is privately moderated by LOGICAL_PSYCHO, who may elect to delete unwanted replies.
Old Sep 13, 2008, 11:09 AM   #31
Gelei Imre
Gelei Imre's Avatar
Easy Glider! Plan and build log, and video here!
Building in pictures step by step:
http://www.rcgroups.com/forums/showthread.php?t=921481
  • Name: 2008_0909Trainer0001.jpg
  • Name: Habtanulogep.jpg
  • Name: Hab tanuló tervrajz.gif
Description: The plan for templates. The plan for templates. 55.8 KB · Views: 1195
  • Name: 2008_0911Trainer30022.jpg
Description: Ready! ( without electronic set) Ready! ( without electronic set) 66.6 KB · Views: 912
Gelei Imre is offline Find More Posts by Gelei Imre   Reply With Quote
Old Sep 30, 2008, 07:02 AM   #32
Build, fly, learn!
The Owl-RT 3D Depron lightweight trainer
Hi,
This is the Owl-RT, wingspan 806mm (31.7"). It is built from 3mm Depron (1 sheet), a spruce spar and various other easy to find materials and components. AUW is 240~280g (8.5~10oz) depending on motor and battery, but can be built as light as 200g if you skip the landing gear and use balsa for the spar. A 100~120W motor is recommended, a properly rewound BW is probably perfect.
A detailed build log, plans and flight reports can be found in my blog here at RCGroups.
The main features of the Owl-RT are:
  • Aerobatics and basic 3D capable.
  • Indoors and outdoors (up to 20km/h winds).
  • Easy and inexpensive to build and repair.
  • Small enough to easily fit on the back seat of my compact car.
  • Can fly very slowly with full control authority.
  • Very gentle stall (nose tips down).
  • Unlimited vertical with the right motor.
  • Good documentation.
  • Name: Owl-RT_no03_pose_4a.jpg
Description: This is my third Owl-RT. This design lends itself to experimenting with different airfoils, CG location, control surface deflection, etc. This is my third Owl-RT. This design lends itself to experimenting with different airfoils, CG location, control surface deflection, etc. 69.1 KB · Views: 1255
  • Name: Owl-RT profile_1a.jpg
  • Name: Owl-RT profile_predator.jpg
ADB2 is offline Find More Posts by ADB2   Reply With Quote
Old Oct 15, 2008, 08:36 AM   #33
flashsolutions's Avatar
Baisden Bipe
The Baisden Bipe was designed by Don Baisden. The build log is from Larry Fortna (flashsolutions).
This 34" wingspan Bipe is made with 6mm Depron.
http://www.rcgroups.com/forums/showthread.php?t=938795
  • Name: blueandwhite.jpg
  • Name: P7290038.jpg
  • Name: BisdenBipeForTim.jpg
flashsolutions is offline Find More Posts by flashsolutions   Reply With Quote
Old Oct 21, 2008, 08:53 PM   #34
Carot^
Slow flying delta wing. Great for indoors. Plans and Instructions
RC Delta Wing (3 min 30 sec)
  • Name: Carot^.jpg
ronhollenbeck is offline Find More Posts by ronhollenbeck   Reply With Quote
Old Nov 14, 2008, 11:00 PM   #35
Modeloholic
DaDesign's Avatar
BowStick - Basic design, Simple to build, Easy to fly and Absolute fun, fun, fun.
I thought of naming this model “Absolute Fun” because that is exactly what she is!
No abstract exotic design that will change aviation forever. She’s just a basic design, simple to build, easy to fly and an absolute fun, fun, fun foam model. She’s built on a Slow Stick frame but nothing like the old SS. I used a large motor for great performance and she can be easily flown in a small/tight place. She's my favorite and I can’t tell you why she’s my favorite but sometimes simplicity and comfort rank higher than we are unconsciously aware of. Here's my thread...
http://www.rcgroups.com/forums/showthread.php?t=952828
  • Name: P1120879.jpg
  • Name: P1120880.jpg
DaDesign is offline Find More Posts by DaDesign   Reply With Quote
Old Nov 16, 2008, 06:19 AM   #36
davereap's Avatar
Send a message via MSN to davereap
38" Superfly-Megafly clone
This is a close SF copy built using 6mm depron. I had been experimenting with a KFm4 airfoil with the top step at 50% and the bottom step at 40%..
It has surpassed all my expectations, it will fly hands off upright and inverted for a considerable distance. It has a wide speed range and is very manouverable.
The double KF step has produced a very strong and stiff wing..With its tape covering it will take a lot of abuse
more info and pictures here http://www.rcgroups.com/forums/showt...9#post10752219
google sketchup construction files in post 52 if you use the google sketchup program you can scale this to any wingspan in just a few seconds..below is the lines.skp for sketchup in the zip
Youtube video here
Depron Superfly 38 clone KFm4 (4 min 46 sec)
  • Name: Superfly-lines.gif
  • Name: superfly-086.gif
davereap is offline Find More Posts by davereap   Reply With Quote
Old Nov 16, 2008, 06:45 AM   #37
davereap's Avatar
The Octagon 29.5" a variation on a Nutball
This large NB variation is built from 6mm depron and has a KFm2 profile...that is a 50% top step.
The build notes start here and the info applies to any of the KF stepped wings..
http://www.rcgroups.com/forums/showt...1#post10942681
If you dont like the octagon shape make it as a circle at 32" diameter...This is my BIG nutball ....Both fly superbly as R.E.T controlled planes..
The original nutball started as a 17" dia epp construct...and is one of the most fun things to fly...If you havnt built a nutball .. read the thread ..then add one to your fleet ..they really make you smile
The youtube video is here..
The octagon or 8ball - a Nutball version KFm2 (3 min 34 sec)
.Dont be put off by the one in the picture which is tatty..This was made by cutting up a different version...Like the nutball it flys very very well, from exteemly slow to wild and fast
  • Name: octagon4 fitted out.gif
Old Nov 16, 2008, 07:06 AM   #38
davereap's Avatar
Flying Wing 43" span a zagi type using the KFm4 profile
17 1/2oz AUW ... span 43"... 11.1 2200 lipo ..9x5gws prop ...large bell motor from overlander UK ...esc and rec ..the motor draws about 11A full power on this setup, and gives 24oz thrust....so it goes well
I was trying to compare it to my zagi, but in every way it goes better.
top speed much the same, but ive a more expensive faster motor on the zagi.
slow speed, as it is so much more stallproof, you can get it to high alpha, and walk it by..
glides great, hands off flat glide..in the glide you can get it to full up elevator no power without any problems, it just hangs there in the breeze, the zagi stalls like a good'n if your speed gets too low, and thats still easy flying speed for this wing.
Rolls fine.
Loops are a bit larger than I like, but my cog is in a very safe forward position, and will probably stay there. It has plenty enough elevator authority for turns and landing.
overall cost ...a better solution ...+..cheap 9gm servos, cheap motor etc... airframe total cost about £10.... a zagi costs about £30
construction notes here http://www.rcgroups.com/forums/showp...postcount=1955
video here..
Double KF wing KFm4 (4 min 43 sec)
Ive since fitted it with my removeable UC for rise off ground, which I prefer...
UC build here
http://www.rcgroups.com/forums/showt...6#post10725116
this undercarriage is used on the superfly , octagon/nutball , and my wings
  • Name: 43inch-KFm4-wing.gif
Old Nov 17, 2008, 02:55 PM   #39
davereap's Avatar
A simple F22 similar to my su27 or eagle
http://www.rcgroups.com/forums/showt...02#post9560802
  • Name: f22-002-(2).gif
Old Dec 07, 2008, 03:50 PM   #40
Dismembered Member...
arx_n_sparx's Avatar
49" DeHavilland Beaver
http://www.aerosquare.com/content/ca...20/50/lang,en/
arx_n_sparx is offline Find More Posts by arx_n_sparx   Reply With Quote
Old Jan 15, 2009, 05:22 PM   #41
My plans are in my blog
Rusty-Gunn's Avatar
I have plans in my blog, of some of my cartoon fatties, and other planes.
Rusty-Gunn is online now Find More Posts by Rusty-Gunn   Reply With Quote
Old Jan 16, 2009, 05:54 AM   #42
Foamies (Scratchbuilt) > Plans For Scratchbuilt Foamies
Action was fast and furious from the first horn. Northwesters were in tough and they fell. Harris and Dick Salter went out as did Matheny, Rush,Wilson and Green. Day 2 saw Rein, Burdick, Milissa and Tony Huber, Richie Salter and the Alien fight hard but soon they were dropping. In the final nine only one local remained, Richie Salter. Mike Evans, Andy Mears, Ron Colombo, Chris Jensen, Steve Stewart, Allen DeVeuve, John Duane and the Alien were the rest.
casino is offline Find More Posts by casino   Reply With Quote
Old Jan 30, 2009, 03:45 PM   #43
RC since 1968
birdofplay's Avatar
Pix and plans are in these threads
MAYBZ - MDC F-14 - swingwing F-14 ~ 12 oz
http://www.rcgroups.com/forums/showthread.php?t=769451
Maybx - YF-23 pusher prop or DF
http://www.rcgroups.com/forums/showthread.php?t=782198
Birdofplay - Foamoni - sortascale Moni Power glider 2M span
http://www.rcgroups.com/forums/showthread.php?t=983757
Birdofplay - SU-47 - Pusherprop with or without canards
http://www.rcgroups.com/forums/showthread.php?t=805188
Birdofplay - folded depron Paper Airplane
http://www.rcgroups.com/forums/showthread.php?t=553480
Birdofplay - Old Timer Buccaneer
http://www.rcgroups.com/forums/showthread.php?t=760383
Birdofplay - PTerracat
http://www.rcgroups.com/forums/showthread.php?t=580316
birdofplay is offline Find More Posts by birdofplay   Reply With Quote
Old Feb 06, 2009, 09:13 AM   #44
Birger de la Peña
bdelapen's Avatar
Depron MXS
MXS - Plans and pseudo-build thread for a full fuse, airfoil wing, Depron MXS 37".
Build Thread is here: http://www.rcgroups.com/forums/showthread.php?t=933423
Current Plans are here: http://www.rcgroups.com/forums/showp...2&postcount=43
Regards,
- Birger
  • Name: MXS 2-View Green Flames.gif
  • Name: MXS-71.jpg
  • Name: MXS-70.jpg
  • Name: MXS-84.jpg
bdelapen is offline Find More Posts by bdelapen   Reply With Quote
Old Feb 06, 2009, 03:54 PM   #45
adbradley's Avatar
18" F22 Profile
Plans on first page
http://www.rcgroups.com/forums/showthread.php?t=795691
  • Name: f22 r3 3d 1.jpg
adbradley is offline Find More Posts by adbradley   Reply With Quote
Alert Free Plans for Foamies (Post links here) JAM Foamies (Kits) 35 Sep 22, 2009 10:36 AM
Question Ideas & plans for 36” scratchbuilt sport plane? cam777cam Sport Planes 40 Apr 12, 2007 06:27 PM
Great free plans for foamies... NetForce2K Foamies (Kits) 5 Apr 28, 2003 05:02 PM
Plans for Fan-Fold-Foamies? ForeverFlying Foamies (Kits) 1 Oct 04, 2002 08:31 PM
Plans for Messerschmitt bf110 from Flair bibblebum Electric Plane Talk 3 Jul 31, 2001 02:23 PM
Bored? Want to fight?
Join the RCGroups clan!
