| Thread Tools |
| This thread is privately moderated by RobinBennett, who may elect to delete unwanted replies. |
Boomerang
I spent most of the winter planning a plane for windy days and came up with this. It's inspired by a club-mate who electrified a slope plane, and a free plan from RCM&E (which also donated the name).
I'd always liked flying wings for windy weather, but this design should have the following advantages: * A thinner, higher aspect ratio wing for speed, * More separation between the motor and the wing, to reduce the noise. * More protection for the battery * Better pitch stability, for trim-free inverted flight. * 3 servos, so I can mix flaps and spoilers/airbrakes. It has a 50" span, and weighs only 500g - with 200W it should be quite quick but still easy to land. There's plenty of room for a second battery if I ever need more power. The thread starts here |
RCM&E have a web site here http://www.modelflying.co.uk/
You can get back issues of plans at customer.services@magicalia.com The booms are depron (6mm foam) with a 3mm carbon rod on the bottom and a bamboo skewer on top. I've built a similar model for a friend and used 3mm square spruce on the top and bottom, which was much cheaper but may not be as tough as the carbon. Tape covered foam is pretty tough, as it can bend but the tape stops it cracking. The curved tail is a fairly standard technique - I covered the outside of the foam with tape to prevent it cracking and bent it around a paint tin. I then held it in place and heated it with a hot-air gun to set it in shape. |
