Old Apr 13, 2008, 12:17 PM
ooby's Avatar
Joined Jan 2006
J-Class, Endeavour
Here are a few pics as the build progresses. LOA is 97.375 inches, mast is 115.5 inches above deck. Jib boom, 36 in, Main boom, 49 in.
Beams are 1/4 in Basswood, while those supporting the mast, jib and back stays, are 1/4 in Russian Baltic Birch plywood. Sheet line braces and mast step are 1/4 in and 3/8 in oak, epoxy/glassed to the bulkheads.
Rudder and swing arm winch are next.
ooby is offline Find More Posts by ooby
Old Apr 13, 2008, 01:04 PM
Joined Aug 2006
Hello
JayDee1 is offline Find More Posts by JayDee1
Old Apr 13, 2008, 09:47 PM
ooby's Avatar
Joined Jan 2006
The hull was purchased from www.classicsailboatmodels.com
The winch from http://www.servocity.com/html/servo_...gearboxes.html
Sails from www.carrsails.com
Aluminum mast from www.ludwigrcyachts.com
Wooden booms from www.pondboats.com
Brass fittings from www.modelyachtfittings.com
Ballast totals 63.7 lbs, in three separate pieces, all of which will be removable.
This boat is for recreational use only. I am trying to replicate the majesty of the "J"s, therefore, the mast is precisely scale length. Though the real ones did not use a jib boom, mine will be attached sort of close to the bow at 8.9% of LOA, unlike some model racing "Js" at around 13%. The sail plan is individual, and mine will carry a full measure, which will limit it to light air.
Of the 10 America's Cup racing Js, I chose the 1934 Endeavour because of its quintessential lines. Simply gorgeous.
I'm happy to answer any more questions.
Ooby
Old Apr 13, 2008, 10:26 PM
Joined Dec 2007
That's just not right. A boat like that belongs in MY living room. POOF! there goes my rebate.
RC-Archer is offline Find More Posts by RC-Archer
Old Apr 13, 2008, 10:33 PM
Joined Feb 2008
hey Rc archer to heck with your living room i want it in mine that is a work of art I think one set of smaller sail to improve the wind range might be in order not to race just to dazzle the locals with it's majestic perfromance Doug [casy]
casy is offline Find More Posts by casy
Old Apr 14, 2008, 11:18 PM
Joined Dec 2007
Does the plans come with the hull? Available separately?
Old Apr 15, 2008, 11:28 AM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
ooby,
The J boat is looking good, it's to heavy for me to move around. I think I will build a 36" version of the J boat when I finish the EC-12.
Check out this web site of the 36" J boat.
http://www.freewebs.com/heroncomposites/yankeeiii.htm
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old Apr 15, 2008, 04:20 PM
ooby's Avatar
Joined Jan 2006
Plans? Getting started?
RC-Archer,
To the best of my knowledge, there are no kits or semi-kits of an AMYA "J".
www.deltamyc.com/boat%20building.htm will take you through the process of building a Shamrock V, which later won the J-Class NCR. Its LOA is 89.75 in vs Endeavour's LOA of 97.375. Since these boats are 1:16 scale, you'll see these types of differences through out the ten "J"s.
The first step is to decide which J to model. The next decision will be to scratch build from line drawings, or purchase a glass hull.
Line Drawings of individual hulls and decks in 1:16 scale are available from Rene Serrao, 650 Ketch Harbour Rd., Portuguese Cove, N.S. B3V1K1 Canada
In answer to your question above, if you decide to go the glass hull route, my advice is to call the prospective seller and get comfortable with the info provided. In my case, Bob Sennott was absolutely great to work with and provided hand written illustrations of critical areas and measurements. These boats are scratch built and highly individual. "How" you build one is essentially up to you.
John Hanks, current AMYA J-Class Secretary wrote a series of 5 build articles, beginning with the Spring, 2000 AMYA quarterly. I recommend obtaining past issues, volumes 119, 121, 122, 123, 124. He also wrote an article on building a planked deck in volume 149.
I hope this helps. I'll do my best to answer any further questions.
Ooby
Old Apr 15, 2008, 04:40 PM
ooby's Avatar
Joined Jan 2006
RC-Archer and Casy,
Since you both want "J"s in your living rooms, how about adding this book to your coffee table, Enterprise to Endeavour, The J-Class Yachts, by Ian Dear.
ISBN 0-7136-5176-8 (UK)
ISBN 1-57409-091-7 (USA)
Old Apr 15, 2008, 04:59 PM
ooby's Avatar
Joined Jan 2006
Ed, like you, I've thought of a smaller J to pack around...get in more sailing. Don't know much about the Yankee III, but will keep my eyes open.
I'm considering: http://canterbury-j-class.org.nz/home.html
Old Apr 16, 2008, 09:55 AM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
ooby,
Thanks for sharing the information on the Canterbury J boat. I emailed Simon and asked how much the J boat will weigh when fully rigged, it comes in at just over 14 lbs. At 48 inches and 14 lbs it is easy to transport and carry. I emailed him back to find out the cost to ship it to U.S from N.Z.
Ed
Old Apr 16, 2008, 02:30 PM
ooby's Avatar
Joined Jan 2006
Ed,
Here's some more info on it. www.pmycsail.com/catalog_1.html
I'm anxious to hear what you learn.
Thanks, Ooby
Old Apr 16, 2008, 04:40 PM
Joined Aug 2006
Hello
Old Apr 16, 2008, 08:41 PM
Joined Dec 2007
Originally Posted by ooby
Ed,
Thanks, Ooby
Me too, but .......97" long!!!!! OOOOOOOOOOH!
ooby's Avatar
Joined Jan 2006
Discussion Revival of the J Class breakwater Sailboats 54 Feb 07, 2012 08:13 AM
