Old Apr 12, 2008, 10:01 PM
samotage is offline
Find More Posts by samotage
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
Nice 1 Doc.
What provision do you make to ensure the blockeron is mounted square and true?
samotage is offline Find More Posts by samotage
Old Apr 12, 2008, 10:35 PM
winchdoc is offline
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
Notice we are not gluing anything in just yet, we just want to make sure the blocks will fit where we want them and the drive arms clear the inside of the hatch.
Samo- these blocks are square and the bore is true to the sides. Sammy and contender have pretty much flat and parallel sides, so you pretty much shake it in and the sides make it true.
Before we glue it in, we will have the side holes drilled and then use the wing rod to help referance the orthagonality of the layout. That's the beauty of a monoblock; all the precision and rigidity is in the block.
WD
winchdoc is offline Find More Posts by winchdoc
Old Apr 12, 2008, 10:49 PM
winchdoc is offline
winchdoc's Avatar
Joined Jan 2003
Contender fuse is just a tad wider and the sides flex a little bit easier.
The narrow Universal block fits in really sweet. These planes really lend themselves to the monoblock because of their parallel sides.
WinchDoc
Old Apr 12, 2008, 11:02 PM
winchdoc is offline
winchdoc's Avatar
Joined Jan 2003
Even the Xica block I installed in this fuse was pretty much self aligning. This block has taper front to back, but was pretty easy to line up with the wing rod installed, and some simple measurements.
WinchDoc
Old Apr 13, 2008, 01:16 AM
slopetrashuk is offline
Find More Posts by slopetrashuk
You must die! I alone am best.
slopetrashuk's Avatar
The Naughty Corner..Find me tweeting @slopetrashuk
Joined Sep 2003
This is a bit like slopey p*rn....I feel so dirrtty..
slopetrashuk is offline Find More Posts by slopetrashuk
Old Apr 13, 2008, 04:15 AM
fooesboy is offline
Find More Posts by fooesboy
Registered Abuser
fooesboy's Avatar
Hamilton, New Zealand
Joined Oct 2005
Me? I just like to watch!
fooesboy is offline Find More Posts by fooesboy
Old Apr 13, 2008, 04:34 AM
samotage is offline
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
..and Ed rekons he's getting those puppies back.
Old Apr 13, 2008, 05:39 AM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
Those Sammy fuses from Ed are great, tough as nails and a excellent platform for an own design TWF. Didn't know he had Contenders too, Ed you holding out on us?
Doug, thanks for detailing the how-to, looks like a cakewalk (once you've seen it done). Quick question: what is the OD of the tube that get glued in the wing?
Sleedo is offline Find More Posts by Sleedo
Old Apr 13, 2008, 08:13 AM
winchdoc is offline
winchdoc's Avatar
Joined Jan 2003
Ed bought a shipload of Sammy fuses when SIG closed them out a while back.
AFAIK Ed only got 1 Contender fuse from Dane (Dane is the guy that has some of the old CR molds) That's why he really really really wants it back when I'm done measuring on it. I missed out on those fuses
The solid wing rod is 5/16 diameter
The torque tubes are 5/16 ID, 3/8 OD.
THis means that when you build a wing for this hardware, you will need a 3/8 ID tube glued into the wing, flush with the root.
As a final part of the install, the 3/8 OD torque tubes will be glued into the wing with about 1" sticking out past the wing root.
Don't do this yet, it will be the very last step in installing the bling system, and getting it right is pretty important.
WinchDoc
two posts left...
Old Apr 13, 2008, 08:36 AM
Sleedo is offline
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
I see, so is 6" plenty of 3/8" ID tube in the wing construction?
EB
Sorry if I'm jumping ahead, I get so excited(after 8 cups of Melita Classic its hard not to).
Old Apr 13, 2008, 10:15 AM
winchdoc is offline
winchdoc's Avatar
Joined Jan 2003
Check out Jay Decker's write up in this subject at this link:
http://www.slopeflyer.com/artman/pub...ers_1of4.shtml
Old Apr 13, 2008, 08:32 PM
Dale Thompson is offline
Find More Posts by Dale Thompson
F3J-F3K-F3F- What to Fly??
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
Doc,
Are you going to stop at 1000?
Dale Thompson is offline Find More Posts by Dale Thompson
Old Apr 16, 2008, 10:10 PM
winchdoc is offline
winchdoc's Avatar
Joined Jan 2003
OK I shipped a bunch of hardware today. More to go out as I get them assembled.
Meanwhile, here's a link to an old thread on installing the hardware. I'll add more here when I get there.
http://www.rcgroups.com/forums/showt...75#post5024075
WinchDoc
Making life HELL for Kinko's
