Old Jan 12, 2003, 06:02 AM
K & C
K & C
Guest
n/a Posts
High band or low? Freq/Rx
Hi,
I, still somewhat of a rooky, noticed that receivers and freq crystals
are sold in either high band (chan 36-60) or low band (chan 11-35). Is
there any advantage or disadvantage to using one over the other?
Kevin
Old Jan 12, 2003, 06:32 AM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Re: High band or low? Freq/Rx
There is no "advantage" to either. Check with the local flyers to see if
there is any known interference and avoid those channels.
"K & C" <tugalug@webtv.net> wrote in message
news:2842-3E214A48-350@storefull-2315.public.lawson.webtv.net...
> Hi,
> Thanks,
> Kevin
Old Jan 12, 2003, 12:02 PM
Linda Parker
Linda Parker
Guest
n/a Posts
Futaba designates their receivers as high or low band. This simply
indicates that the receiver was tuned to either the high or low end of the
band and should use the corresponding crystals. Most other manufacturers do
not set limits on what crystals may be used. I don't know of any advantage
of using either high or low channels, but it is always a good idea to check
with other flyers at your field to determine if any particualr channels have
a history of interferrence. It is also a good idea to avoid heavily used
channels so that you don't have to wait for other flyers.
Ken
K & C <tugalug@webtv.net> wrote in message
> Hi,
> Thanks,
> Kevin
Old Jan 17, 2003, 07:02 PM
Charles & Peggy Robinson
Guest
n/a Posts
Pick channels without a history of interference PLUS pick channels tha
are the least populated at your regular field. I'm the only one on
channel 21 at our club field, heh, heh.
CR
Question HFD-08RD RX - high band & low band? Endor Hitec/Multiplex USA 2 Mar 21, 2006 06:53 PM
Discussion High $$$ 20C or low $$$ 12C batteries Milton Batteries and Chargers 11 Jan 08, 2006 05:46 PM
Himaxx 2025 -4200 High Pole or Low Pole Count Baracus Castle Creations 2 Dec 02, 2004 07:28 AM
High KV or Low KV RockyTse Power Systems 2 Apr 26, 2004 09:51 AM
