Old Jan 11, 2003, 10:52 PM
Carl Farrington
Guest
n/a Posts
Sceadu alternate tail boom brace mounting
This solves a common problem, but also raises a question.=
If anybody has a recent-ish copy of MHW (Model Helicopter World), take a
look at the Sceadu advert on the back page.
Notice how the in-flight pictures show the tail-boom braces mounted ABOVE
the fuel tank. This makes the machine look FAR sleeker and sexier. I've been
calling this (admittedly only to myself) 'Freya style mounting', since all
the (admittedly not that many) pictures I've seen of Freyas have this
mounting.
This overcomes the problem of the bolts rubbing on the bottom of the fuel
tank, although granted one can simply shorten the bolts with a cutter to fix
the problem, but at least this way the problem isn't there to begin with.
I naturally assume that mounting in this way offers less boom-support than
the lower mounting position, naturally, I think its to do with leverage, but
I think anyone would agree on looking that the LOWER mounting position
offers a stronger fixation for the boom in the Y axis (up & down).
The Sceadu 30 manual that I have, does not even mention the existence of
these mounting holes, nethermind the choice to use. It just tells you to
mount the supports into the lower holes.
Does the group think this indicates that they should NOT be used ? Or would
the manual specifically say NOT to use them ? Can anyone forsee problems
using the upper mounts ? I myself am only hovering in the back yard, and so
if there is a possible issue then it would perhaps apply less so to me, but
I'm sure others given the choice would mount above the fuel tank.
Unfortunately the upper mounting hole is also a great place to mount a
Header Tank, so the tank doesn't like to be held infront of the boom
brace/support... more thought needed on this.
Old Jan 12, 2003, 03:02 PM
Carl Farrington
Guest
n/a Posts
Re: Sceadu alternate tail boom brace mounting
Did I come across as a bit of an impersonal twat in that post ? I didn't
mean to, sorry.
Do any sceadu owners out there mount their tail boom supports above the fuel
tank ?
I only really want to do it for the look.
thanks,
Carl
"Carl Farrington" <carl@000compsup000.net> wrote in message
news:avqro7$7kr$1$8300dec7@news.demon.co.uk...
been
> mounting.
fix
but
would
so
but
Old Jan 12, 2003, 04:12 PM
Andy Carpenter
Guest
n/a Posts
No. Not a twat
I don;t use the higher holes. I figure the lower ones will give a more
rigid set-up. I know the Freya has both positions too. The *original*
prototypes used the lower holes. Now they use the higher ones !
I reckon if you are just learning it probably won't make too much difference
to you. I would suspect that only the hardcore super experienced three dee
pilots would notice.
BTW - Have you seen the angle of the boom supports on the 3DNT ?
Carps.
[http://www.carps.co.uk]
news:avsk2a$a5p$1$8302bc10@news.demon.co.uk...
> mean to, sorry.
fuel
> tank ?
> thanks,
> Carl
ABOVE
> been
all
> > mounting.
fuel
> fix
with.
than
> but
> would
> so
> but
Old Jan 12, 2003, 04:22 PM
Carl Farrington
Guest
n/a Posts
I hadn't noticed the three Dee NT boom supports, but I just went to their
website.. I can't even see any! - are they really that small ?
cheers Andy. I think I'll move them back above the tank, now that I've
mounted my header tank elsewhere
"Andy Carpenter" <andy@REMOVEcarpsTHE.coUPPER.ukCASE> wrote in message
news:avso6m$num$1@helle.btinternet.com...
> No. Not a twat
difference
dee
> Carps.
> > mean to, sorry.
> fuel
> > tank ?
> > thanks,
> > Carl
a
> ABOVE
I've
> > been
> all
> > > mounting.
> fuel
to
> > fix
> with.
> than
leverage,
> > but
of
to
> > would
problems
and
> > so
me,
> > but
Old Jan 12, 2003, 04:33 PM
Andy Carpenter
Guest
n/a Posts
They are not small. It is just the angle between them and the boom is only
about 5-10 degrees !
Carps.
news:avsp1t$hh4$1$8302bc10@news.demon.co.uk...
> > No. Not a twat
> difference
> dee
> > Carps.
didn't
> > > mean to, sorry.
the
> > fuel
> > > tank ?
> > > thanks,
> > > Carl
take
> a
> > ABOVE
> I've
> > > been
since
> > all
this
> > > > mounting.
> > fuel
cutter
> to
> > > fix
> > with.
boom-support
> > than
> leverage,
> > > but
position
existence
> of
you
> to
Or
> > > would
> problems
> and
> > > so
> me,
> > > but
a
Question SCEADU Tail boom contact303 Electric Heli Talk 4 Jan 23, 2007 02:41 AM
Discussion trex tail boom brace Jasonscott Mini Helis 4 Jan 27, 2006 05:36 PM
Hirobo Sceadu 30 Tail Boom Question tioli Fuel Heli Talk 4 Nov 29, 2005 10:38 PM
Logo Tail boom Brace crux12 Electric Heli Talk 0 Sep 11, 2002 07:28 PM
Mounting tail boom? krajesj Power Systems 1 Feb 11, 2002 10:48 AM
