Old Apr 09, 2008, 10:20 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Boundary layer drag
Here's a thought (happened while I was on the can)...
We're dealing with really low RE's, and I'm just wondering whether there is any benefit in going for a slighty rougher finish on our aircraft to reduce boundary layer drag.
Has anyone got any ideas whether I'm barking up the wrong applecart?
Perhaps using mylars isn't the best way to get the most out of our wings.
Curare is offline Find More Posts by Curare
Old Apr 09, 2008, 10:42 PM
annihilator is offline
Find More Posts by annihilator
making it up as i go.
annihilator's Avatar
Stillwater, Oklahoma, United States
Joined Jun 2003
rougher surfaces will cause the boundary layer to transition from laminar to turbulent quicker, thus increasing drag. You are probably thinking about golf balls and other items called "bluff bodies" that experience a drag reduction by adding roughness. roughness is added to trip the BL into being turbulent, where in the case of a golf ball it decreases drag by tripping to turbulent BL which stays attached longer, and in the case of a sailplane wing can eliminate laminar separation bubbles which are generally bad. So in the case of DLG wing laminarBL=good.
annihilator is offline Find More Posts by annihilator
Old Apr 10, 2008, 01:07 AM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
righto!
Gallery Dynamic Soaring in the ground boundary layer MSelig Dynamic Soaring 12 Jan 23, 2007 03:09 AM
